Save yourself up to $200 and some headaches - Electric Fuel Pump PM - Page 27 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 268 votes, 4.97 average.
Old 11-29-2012, 09:38 AM   #521
Stinger9
My Ride: '04 330Ci
All we want is for your car to run right.
From another post over where Rajaie runs the vanos symposium:
Originally Posted by 2003silver330i View Post
My 2003 330i (140K miles) has a rough idle upon initial cold start and stays like that for a good minute before smoothing out. Every other day when starting it up cold, the engine will run rough for a second and stalls out and dies. As long as the engine is somewhat warm it starts fine and the idle is not near as rough. I did the CCV test where you lay a zip lock back on top of the oil filler hole and it sucks in about an inch so I'm assuming the CCV is good to go.
Is it possible my VANOS seals need replacing? Thanks.
1" on the bag test is good.
Have you already replaced the crankcase vent valve and 4 hoses?
Here are things to consider.
1. Dirty idle control valve.
2. Crack in lower intake boot branch to idle control valve.
3. Crankcase vent valve and 4 hoses.
4. Failing DISA flap. Remove and inspect flap for excessive play.
5. Loose DISA fit to intake manifold. Wrap DISA base gasket with one layer 1/2 width electric tape.
6. Dirty or failing MAF sensor. Spray lightly with MAF cleaner and let dry.
7. Clogged fuel filter.
8. Very dirty engine air filter.
Old 11-29-2012, 11:31 AM   #522
flyty017
My Ride: 2000 328IA
yeah i have codes their were 12 of them. All cylinders misfired and also 2 lean codes. i replaced the MAF sensor as well.
flyty017 is offline   Reply With Quote
Old 11-29-2012, 03:26 PM   #523
jfoj
My Ride: 330CiC, M5, X5, E93
MAF sensor is usually not the fix all, and many non OE MAF's under report airflow and cause lean conditions. Put your original MAF back in until you solve the problems.
Old 12-03-2012, 07:30 PM   #524
Frank_E46
My Ride: 2004 325CI
Thanks jfoj...
Removed/Replaced fuel pump but only after failure. LUCKY for me she died on my driveway. (2005 325ci/110K)
Did some shopping around and BMA w/code had the best price and excellent fitment. The DIY is on youtube (edzgarage). But the one thing that should be included is that the electrical connector has a 'slide' (see pix). Rather than 'monkey gripping' and pulling--just slide and the connector just lifts up.
Frank_E46 is offline   Reply With Quote
Old 12-03-2012, 07:59 PM   #525
jfoj
Glad your car left you stranded in the driveway.
Just no fun if your car is blocking your running vehicles in!!
Thanks for the good picture. This style connector is common on BMW's and other German cars. If you do not mind, I may edit the first post and add this picture for the newer crowd that have not seen these type of connectors before.
Old 12-03-2012, 08:26 PM   #526
Frank_E46
My Ride: 2004 325CI
...please do so jfoj.
I'm glad to humbly contribute to an excellent site...for me, that's the bottom line.
We're here to help each other out vice feed the stealership!
Old 12-03-2012, 10:52 PM   #527
Stinger9
My Ride: '04 330Ci
And get quality workmanship because we're doing things carefully ourselves!
Old 12-03-2012, 11:11 PM   #528
Frank_E46
My Ride: 2004 325CI
...here's a pix of the closed position:
Old 12-03-2012, 11:12 PM   #529
Frank_E46
My Ride: 2004 325CI
...and here's a pix of the open position:
Old 12-03-2012, 11:13 PM   #530
Stinger9
My Ride: '04 330Ci
Exactly the way mine is.
And I wasn't surprised by it because the connector on the back of my stock head unit has a connector that slides sidewise just the same.
Old 12-03-2012, 11:26 PM   #531
Frank_E46
My Ride: 2004 325CI
At the open position, the electrical connector is easily lifted vice 'monkey gripping' and yanking off like in the youtube video.
FYI, replaced the fuel filter at 80K.
This past weekend replaced:
*Fuel Pump: Siemens/VDO
*Fuel Tank Unit O-ring (fit ring in-place prior to sliding fuel pump in tank)
*Fuel Pump Relay
Get a new hose clamp: 1/4"-5/8" worked great.
Use a torx T45/50 to plug the fuel line and prevent fuel spillage.
Everyone has to make a decision 'when' to replace--hopefully, we're all lucky enough to be in a good position when it happens...
Old 12-03-2012, 11:33 PM   #532
Frank_E46
My Ride: 2004 325CI
Glad it was not a surprise for you Stinger9...it was for me.
I like informative threads that help our community and this is one of them.
Once again, thanks to all on this site that make owning, driving, and maintaining an e46 enjoyable!
Old 12-05-2012, 11:57 PM   #533
ralf
My Ride: 330i
Just happened to me.
I was driving and suddenly the car started to fail, I just reached a parking lot inside a mall until my car died. When this happens to you, in a BMW thatīs rock solid dependable you start to think things like: why is this happening? Should i sell this car? but when the calm returns, one just have to think a little and find the cause. Whatīs missing here? fuel or spark? because the crank works but the car is not starting. After a quick check removing the injectors cover i noticed i didnīt have fuel pressure.
So, options are: faulty relay, clogged fuel filter or dead fuel pump. Itīs not the injectors because in that case iīd have a CEL code and I didnīt.
I had to tow the car to my home, search posts about this problem in this gold mine of information forum, and also found a video on youtube that was very handy.
Also, the procedure to change the fuel pump is very easy. When my car was being towed, i was thinking on the trouble to lower the gas tank because itīs over the driveshaft and differential, but when i found about it it really made me smile. The engineers of bmw are geniuses by making this repair that easy. I wonder if changing a fuel pump in an audi or mercedes is that easy.
Checked the relay first, it was ok, checked the voltage on the fuel pump harness and it was ok. but fuel pump was dead. Ordered a replacement and a new fuel filter (it was time to change it anyway) yesterday morning from BMA parts and surprisingly the box arrived today (it took just 1 day to travel from CA to TX) I installed the new filter and pump and my car is running again.
I have to give total credit to the creator of this post, because itīs true, my car is 131K and the fuel pump is the original. I never though on replacing it because it never failed. But eventually they all do. So itīs wise to plan replacing the fuel pump.
Luckily for me, the car failed just a few miles from my home. I imagine the problem if this happens in a road in the middle of nowhere.
So, be wise and change your fuel pump.
ralf is offline   Reply With Quote
Old 12-08-2012, 05:54 PM   #534
01330i
My Ride: 0133i
'01 330i owner.
Car has exhibited the symptoms of the soft fuel pump failure, car ran out of gas still showing 1/4 tank. Put fuel in and it started right up.
Then sure enough my wife goes out to start it this morning and it cranks but no start.
Question, the O-ring for the Siemens / VDO fuel pump...says it needs to be ordered separately---did that---but it shows a "Sending unit O ring" in the description. Is that correct JFOJ?
Also, I ordered the Fuel pump relay and the Filter w pressure regulator.
Last thing, where is this F-pipe / hose you refer to in some other posts?
Thank you.
01330i is offline   Reply With Quote
Old 12-08-2012, 06:14 PM   #535
jfoj
Fuel sender/pump seals/O-rings are the same for both sides so you ordered the correct thing based on your description.
I reuse them all the time without problems, but not a bad idea to replace it.
Stupid expensive for what it is.
As for the F connector, not 100% sure all cars have these. Some cars have fuel pressure regulator connected to side port on CCV as I recall?
Old 12-08-2012, 07:24 PM   #536
01330i
My Ride: 0133i
Sorry ---- I've done several DIY's (window regulators, Blower resistor i.e),,,,and I don't have a clue on even the general area of this (possible) F-connector...? Under the hood? Or underneath the car near the pressure regulator,,,is that what you're saying?
Sorry for being such a pain.
And thanks again. Very much.
Old 12-08-2012, 07:53 PM   #537
jfoj
Sorry for not being more clear. The F vacuum connector is mounted in the upper intake boot, which is connected to the MAF/air filter housing.
Also check/replace the vacuum hose to the fuel pressure regulator located under the drivers floorboard, connected to the fuel filter.
Old 12-10-2012, 09:39 AM   #538
01330i
My Ride: 0133i
Thank you. Much appreciated.
Old 12-10-2012, 09:52 AM   #539
eRock79
My Ride: '02 330Cic 5sp Man
Thanks jfoj...
I just had to deal with a very similar problem that left me 30 miles from home and a tow bill at about $200. I've got the parts on order (fuel filter & pump) but I'm wondering, when installing the new pump, did you have to prime it? If so, how'd you go about it?
Thanks to everyone for all the great posts! This information is truly invaluable (unless you wanna put the $1400 stealership price tag on it).
Cheers,
Erik
Are you waiting on me?
"Yeah, Thai Dishes is one of my dad's restaurants."
"Really? What kind of food do they serve?"
"Uhm...Thai."
'02 330Ci 5sp Vert**310 South Bay Bimmers Meet**310SBB Facebook**562 Meet
eRock79 is offline   Reply With Quote
Old 12-10-2012, 02:44 PM   #540
jfoj
No need to prime.
Cycle the key on and off 4 or 5 times.
Rate This Thread
