Old 06-26-2012, 12:45 PM   #1
alexxander.foster
My Ride: 2000 323i
MS42 DME Pin Mapping...
I want to start the process of mapping the pins of the MS42 DME. I've tried using http://wds.spaghetticoder.org/ but i'm not finding enough information about what the pins are controlling/receiving.
My goal is to see how different the MS42 and MS43 really are once they interface with the engine. If they match up close enough, I want to start a write-up on upgrading to the MS43 WITHOUT a wiring harness swap -just moving the pins around as needed and hooking up the few necessary engine parts. Of course this is an oversimplification of the swap, i'll likely need to develop some external circuitry, but you get the idea.
Is anyone willing to lend a hand sifting through all of the data?
alexxander.foster is offline   Reply With Quote
Old 06-26-2012, 10:15 PM   #2
TerraPhantm
My Ride: M3 & ZHP
I was looking at this a while back. So for the most part, connectors X60001, X60002, and X60005 are identical. (X60001 on the M52TU has an extra +12V supply, which can probably be discarded).
For X60003 and X60004 are where the real differences lie, I think it's a little "easier" to look at the diagrams rather than the tables - since the abbreviations are actually somewhat more descriptive than the table values.
For example, X60003/Pin 9 on the MS42 corresponds to "Signal Driver's Wish Sensor 2" - this would correspond to one of the pedal position sensors on X60004, but the signals aren't numbered in the MS43 table.
Now if you go to the diagram for MS42 "Module 3" - you'll find that Pin 9 corresponds to "A_FWG2" - now go to MS43 "Module 4" and you'll find "A_FWG2" sits on Pin 13 - which is indeed one of the pedal position sensor signals.
It will be a pain to go back and forth between the diagrams, but I do think you should be able to figure out which pins to swap with them
