Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
Old 07-25-2013, 05:36 PM   #261
TerraPhantm
My Ride: M3 & ZHP
I'm stumped. EWS is sync'd, no codes are being thrown (except for exhaust gas flap), the CAN bus is functional, and all sensors seem to be getting the right signals. I want to say that at this point the car should be diagnosed as if it's a factory E46 that isn't starting.
Old 07-25-2013, 08:19 PM   #262
Hornung418
My Ride: '04 MB ZHP
Re: MS42 < MS43 Compatibility Thread...
Replaced the spark plugs for the first time in my 20k miles of ownership.
Boot from cylinder six.
Spark plugs left to right, one through six.
Finishing off tonight with a nice pilsner.
Hornung418 is offline   Reply With Quote
Old 07-25-2013, 08:21 PM   #263
Hornung418
My Ride: '04 MB ZHP
Should note...the car didn't start after changing the plugs. Next step is diagnosing the coil packs. And finally the fuel pump. From there it must be a relay of sorts.
Old 07-25-2013, 11:39 PM   #264
jdjg
My Ride: e39, m52tub30
Originally Posted by TerraPhantm View Post
I don't remember all of them, but stuff like oil pressure, oil level, battery, and starter signal.
do you have the diagrams?, thats the only I need to solve.....
I have the Oil Pressure and Oil Level warning in my cluster....
regards,
jdjg is offline   Reply With Quote
Old 07-25-2013, 11:41 PM   #265
jdjg
Originally Posted by Hornung418 View Post
Car was running the 3.0 filter and rail with MS42.
Sent from my SCH-I535 using BimmerApp mobile app
me too, MS43 DME + MS42 fuel line + m54b30 injector....
Old 07-26-2013, 02:53 AM   #266
Hornung418
My Ride: '04 MB ZHP
Ms43 rail.
Old 07-26-2013, 03:06 AM   #267
Hornung418
My Ride: '04 MB ZHP
yes, you are correct Terra, but Im talking of a connector that came
in the same harness
the white one, in your left, in my car came in white with 10 pins, in the MS43 came in black with 16 pins.....
Just realized you have an e39. Different dme box and everything. I will definitely be hacking into the dme box and doing some wiring this afternoon. Because I know the big red and yellow spotted wire isn't connected to the relay.
Old 07-26-2013, 01:15 PM   #268
Hornung418
My Ride: '04 MB ZHP
The issue has to be in the fuel line. The car is getting spark. because there are no wires that differed between the X6002 connection. Which contains the coil pack harness.
So now the issue becomes how does the fuel injectors get power to open and close. There are signals while testing in INPA that are saying they're opening and closing, but are they actually doing that?
My thought now turns to the X6053 connection. The difference between harnesses is a lone pin addition in slot 7. That pin is not connected to anything on the splice harness. What I've discovered is that there are two relays for that slot which occupies number 3 in the third graphic down linked HERE. Notice how it mentions the K6326, Unloader Relay...and the fuel related one is K6327, Fuel Injector Relay.
Not sure what the part number is for the relay...but I think that if I swap the relay and run a splice from pin 2 in X6327 to pin 7 in X6053, we should get the car to fire...finally. There is no way in Hell the Fuel Pump is dead...and definitely not all the coils. So it has to be that the problem lies at the injectors.
Old 07-26-2013, 01:27 PM   #269
TerraPhantm
My Ride: M3 & ZHP
This is what the WDS says
MS43
MS42
edit:
Here's the diagram for X6326 (unloader relay) on the MS42:
http://www.bmw-planet.com/diagrams/r...000007114.svgz
Basically it seems like they're the same relay, except it goes to the first ignition coil on the MS42, and injectors on MS43.
And the ignition diagram from the MS43:
http://www.bmw-planet.com/diagrams/r...000014353.svgz
Old 07-26-2013, 02:09 PM   #270
Hornung418
My Ride: '04 MB ZHP
But that's the thing...where does that leave the extra plug? If it were to function like an MS43, then I think it would start. So how do I acquire the correct relay and splice the connection properly?
Old 07-26-2013, 02:36 PM   #271
Hornung418
My Ride: '04 MB ZHP
So I have a feeling I am going to have to make a franken-harness...by combining the differences in the MS42 Body splices with the MS43 engine pinouts.
Thoughts?
Old 07-26-2013, 03:05 PM   #272
HakenTT
My Ride: 323i with S54
spray some starter fluid into intake manifold, if the engine fires then you got the fuel issues
Siemens MS43 tuning master
HakenTT is online now   Reply With Quote
Old 07-26-2013, 03:19 PM   #273
Hornung418
My Ride: '04 MB ZHP
What is the best place to try and spray it?
Would fuel that has been sitting in the tank for as long as it has become "bad?" Hasn't started in over four months. No stabilizer had been added before taking it off the road.
Old 07-26-2013, 03:54 PM   #274
TerraPhantm
My Ride: M3 & ZHP
Some additives may have degraded, but it should still start with old fuel, maybe just run badly afterwards. I had a tractor with 3 year old gas that started right up.
Old 07-26-2013, 04:28 PM   #275
Hornung418
My Ride: '04 MB ZHP
Well if it starts then we can diagnose the fuel issue...
Old 07-26-2013, 10:20 PM   #276
Hornung418
My Ride: '04 MB ZHP
Omg omg omg! It fvcking started!!! Took a video. Uploading it shortly.
Old 07-26-2013, 11:40 PM   #277
HakenTT
what moronic thing did you do to make the engine not start?
Old 07-26-2013, 11:49 PM   #278
TerraPhantm
My Ride: M3 & ZHP
No need to insult him. You couldn't have simply asked "so what did it end up being" ? Anyone is bound to make mistakes their first few times doing something like this
Old 07-27-2013, 12:05 AM   #279
Hornung418
My Ride: '04 MB ZHP
I actually took your "moronic" suggestion to use some starter fluid. and guess what...it worked!
Video Proof.
Old 07-27-2013, 12:18 AM   #280
jdjg
I acrually tool your "moronic" suggestion to use some starter fluid. And guess what...it worked.
Video proof.
nice
but one question, you still have all the m52tub28 internals? like camshafts (intake/exhaust), crankshaft, pistons, rods????
