Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
Old 08-22-2013, 10:42 AM   #341
jdjg
My Ride: e39, m52tub30
MS42 < MS43 Compatibility Thread...
Originally Posted by Hornung418 View Post
You already shared that information earlier in this thread. The e39 must be a different configuration than the e46 as far as wiring differences between engines and management.
I think the harness are the same, since the motor are the same......
regards,
jdjg is offline   Reply With Quote
Old 08-23-2013, 01:11 AM   #342
TerraPhantm
My Ride: M3 & ZHP
So I bought a ZHP. this project is being scrapped on my end. If someone can document a straight swap and get a 2.8 M52 running MS43 I would love to see the gains.
Attachment 523039
Pic was taken in Lincoln, Nebraska as I was passing through on my way back to Baltimore.
Congrats! Shame that the ms43 swap never finished, but I'm sure you'll enjoy your ZHP. If it isn't already at the latest software, I recommend updating it via WinKFP
Old 08-23-2013, 09:34 AM   #343
Hornung418
My Ride: '04 MB ZHP
Re: MS42 < MS43 Compatibility Thread...
Thanks man. There is still some hope for the swap...I have one last chance to make it work with the new, unbent fuel rail. It could be a massive air leak at the throttle body because I dremeled some of the opening wider to accommodate the adapter, but I just need to get it sold right now.
I had reset all adaptations when I took possession of it. That seemed to improve the hill climbing ability. Will update the S/W when I get a chance.
Needs VANOS rebuilt, DISA repaired and a new air filter. Popped MAF codes the whole way home because of the K&N in the stock box.
Hornung418 is offline   Reply With Quote
Old 08-23-2013, 07:35 PM   #344
Hornung418
My Ride: '04 MB ZHP
I did get my new MS42 harness today. Gonna be working on that this Sunday.
Old 08-23-2013, 11:45 PM   #345
HakenTT
My Ride: 323i with S54
I finished my MS43 project into E30. All works fine. I am currently doing 2004 ZHP engine with MS45.1 into E30.
HakenTT is offline   Reply With Quote
Old 09-01-2013, 12:02 PM   #346
e34m5freak199
My Ride: E34 M5, E46 325
Guys, your freaks.
Come over here http://forum.e46fanatics.com/showthread.php?t=1003871
and help smash this out the same way you smashed ms42 - ms43 ?
e34m5freak199 is offline   Reply With Quote
Old 09-04-2013, 07:26 PM   #347
jdjg
Hi there, since I change the MS42 for the MS43 I have in the cluster the Oil Pressure warning and the Oil Level Warning....
can any one please told me how do I need to connect the signal that came from both sensors (oil pressure and oil level) to my cluster?
regards,
Old 09-05-2013, 06:23 PM   #348
jdjg
well finally, after a long day of reading and searching and asking, I figure it out how to solve the OIL PRESSURE and OIL LEVEL cluster warnings......
For the OIL PRESSURE you need to do this:
- Take off from the DME X60004 the cable from PIN #11
- Reattach the cable in to PIN #8 in the X6011 plug
For the OIL LEVEL you need to do this:
- Take off from the DME X60004 the cable from PIN #21
- Reattach the cable in to PIN #9 in the X6011 plug
For the Battery signal you need to do this (this are incomplete, I need to search a little more):
- Reattach the cable in to PIN #2 in the X6011 plug
When you do this, the red battery icon turning on in the cluster, but after you start the car, the warning stay ON (aka red battery symbol), so, I forgot to do something else, do not know what, maybe one of you guys can tell me.....
The only two thing I need to figure it out are:
- How to connect the Reverse Switch light in to my cluster, since I use to have automatic transmission, now, I put manual transmission, and the WDS told me that I have from the Cluster and the plug X11175 one cable in PIN #4 that are attach directly in to the X60004 Pin #19 for the reverse, but don{t know why, I have a blank spot in PIN #19 in the X60004, but I have a yellow cable in the X11175 in the cluster..........
- Solve the battery warning red light that always stay ON.
regards,
Old 10-11-2013, 04:47 PM   #349
new//M3fan
My Ride: 77' 924 87' E30
MS45.0? Yes. MS45.1? No. MS45.0 uses narrowband O2s like most other BMW ECUs. Software might be compatible between the two (if you flash it at the EEPROM level), but you'd still need to change some hardware out
They're also sufficiently new that there won't be "Euro2" tunes for them
Just took a quick gander at bmwfans.info
and found this 2002 Z4 3.0i
7 561 470
MS45.0
Left-hand drive
For vehicles with:
EU2 exhaust emissions standard (S168A) = Yes
Or:
Equipment for leaded fuel (S199A) = Yes
Or:
Data record without EOBD (S861A) = Yes
And also
7556262 MS43
For vehicles with:
Alpina Roadster S (S8ADA) = Yes
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 10-24-2013, 10:58 AM   #350
Hornung418
My Ride: '04 MB ZHP
Re: MS42 &lt; MS43 Compatibility Thread...
Well I started the 328i yesterday after working all day. It was quite a joyous occasion. The engine sounds rough and I couldn't drive it because as soon as I took off the jumpers it sputtered out and died. Oh well.
So when do we look into running the MS45.0?
Old 12-26-2013, 03:11 PM   #351
M_South_Afrikanna
My Ride: e46 325i
Excellent thread very informative. I'm hoping this will help me figure out how to get rid of the check engine light on my car. I did a b25 to b30 swap awhile ago and ever since I have had the running lean code coming up. I assume I need a flash but I really dont want to pay the 800 dollars everyone's quoting me to do it, so I have been working on learning how to use NFS, winkpf, and a whole list of other programs so I can the flash the dme to run the 330 motor. Ill keep doing research but if anyone has any suggestions on what exactly I need to do with working with the programs and/or anything else that might help me fix the error code please any help would be appreciated.
M_South_Afrikanna is offline   Reply With Quote
Old 04-21-2015, 12:46 AM   #352
Patton323I
My Ride: R1100GS E46 E53
So, I'm about to perform a 3.0 swap on my 323. This thread is full of fantastic information on pin reassignments. But I want to do this the easy way lol. SO, shouldn't I be able to just buy a used complete engine wiring harness that would go with the MS43 DME and have this work anyway? Is there pins behind the instrument cluster that need to be switched around for this to work? and what harness do I need for the new electronic pedal? Again, awesome information here! Just looking for a little clarification.
1999 BMW E46 323 with MS 42 DME M52TUB25
Patton323I is offline   Reply With Quote
Old 04-21-2015, 12:56 AM   #353
daniel_f.
My Ride: 330iC
Why not stick with MS42 and just change the tune?
Old 04-21-2015, 01:45 AM   #354
Patton323I
I'm running an ESS supercharger kit. And according to them, in order to get the most out of the engine, I need to move up to the MS43 DME and 3.0 software. They said the MS42 will only support a tune for a 2.8 liter motor. I'm no expert on tuning, so I'm inclined to believe them.
Old 04-21-2015, 02:08 AM   #355
daniel_f.
My Ride: 330iC
Alright, thats a different story then.
Old 04-21-2015, 06:42 AM   #356
jdjg
you need to fabricate your own gas pedal harness, they are 6 cables that go directly to the DME (from the gas pedal)
dont remember what pin you need to relocate in your cluster, in my case (e39) need to relocate one or two pins because the Oil pressure light and battery light
I think I write up in this post
regards a good luck
Old 06-30-2015, 10:48 AM   #357
Patton323I
regards a good luck
Anyone have a good example of the harness that needs to be made for the throttle pedal? Or anyone have picture of one that they made. This would be very helpful.
And which pins do I need to flip around?
Old 10-05-2015, 01:20 PM   #358
Patton323I
Just a small update with my swap. The harness I got from a later model 330I will be useful as a donor to splice wires into my current harness. After doing some reviewing of the two harness, I've determined that it would be easier to do the pin reassignments and splice in the new wires, than it would be to try and make the 330 harness work with my systems.
I am wondering if anyone has had an issue using the MS43 DME with the ASC traction management system in the 323. Or if because the ASC is a separate module that this is a non issue. It would be much more complex to swap in a DSC unit into my car. (May as well buy a 330 with DSC already in it...)
Old 10-05-2015, 04:10 PM   #359
daniel_f.
My Ride: 330iC
There are MS43 cars equipped with ASC from factory
Old 10-05-2015, 07:06 PM   #360
Patton323I
Outstanding! Thank you good person!
