Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#101 |
delete
#102 |
Well I have everything ready to go for the install. Just need to find a person to code the car. Wondering if the dealer can do it...
Sent from my SCH-I535 using Bimmer App
#103 |
Can someone share the wiring schematic for the throttle pedal > throttle body? Looking to see how it's connected. Is it through the DME or is it a direct connection to the throttle body?
#104 |
DME I received is a Siemens MS43 from a 06/15/00 330i
![]() Not sure which software version it has on it though. The label states the VIN and the unit part number (7 506 307) as well as another part number which I assume is the ZUSB p/n. That number reads 7509443. Checked on BMWFans.info and RealOEM.com, but no luck regarding the p/ns. No matter what, the end result will be a European tune, but it would be nice to know the current tune on the car. Could have had an update, but it still denotes the VIN is from a 330i, which is great news! On to the EWS...How will I know if the unit is paired to the DME? I have no tags other than the part number: 61.35-6 905 670. And finally, where does the throttle pedal connection meet with the DME? That is my biggest issue yet. I have half of a harness for the Pedal, but no where to plug it in. Let's get this project moving people!
#105 |
MOTOR DRIVEN THROTTLE VALVE
The MDK control function has been integrated into the ECM. The purpose is for precision throttle operation, OBD II compliant for fault monitoring, ASC/MSR control, and cruise control. This integration reduces extra control modules, wiring, and sensors. The MDK control function is integrated into the Siemens MS42.0 ECM. The ECM carries this function out by regulating the engine throttle valve. The engine throttle valve performs the following functions: • Precision intake air control • ASC control • MSR control • Cruise control • Preset position during engine start up (if temperature is < 0ºC) The new engine throttle valve (MDK) differs from the familiar EML in the following points: • The accelerator pedal potentiometer (PWG) is now integrated in the MDK housing. • A throttle cable is used to actuate the throttle potentiometers and also serves as a backup to open the throttle plate (full control) if the MDK system is in fail-safe. throttle cable (foot pedal controlled) is connected to a pulley on the side of the MDK/ The pulley is linked by springs to one end of the throttle shaft, the MDK electric motor is attached to the other end of the throttle shaft. With the pulley linked by springs to the throttle shaft, this allows ASC intervention to override the driver’s set throttle position. As the pulley and shaft are rotated, the twin potentiometers (integral in the MDK housing, driver’s wish) are sensing the requested load. A twin potentiometer is used for back up redundancy (fail-safe). The MS42.0 ECM will actuate the MDK motor pulse width modulated in both directions at a basic frequency of 600 Hz) which positions the throttle plate. The second twin potentiometers feedback the actual throttle plate position, allowing the ECM to verify correct throttle position. Again, twin potentiometers are used for back up Engine Management Systems MDK EMERGENCY OPERATION If a fault is detected in the system, the following modes of operation are: • Emergency operation 1 - Faults which do not impair safety, but which adversely affect the functioning of the MDK. • Emergency operation 2 - Applies when faults are encountered which might impair safe driving operation. • Emergency operation of idle speed actuator. EMERGENCY OPERATION 1 • Activation of the EML warning lamp. • MDK is deactivated, the throttle valve is opened mechanically by the springs and throttle cable. • To maintain vehicle control, the MDK opening is compensated for by closing the idle speed actuator and retarding the ignition (engine power reduction). • Engine power is further limited by fuel injector cutout. Emergency operation 1 limits the dynamic operation if one or more of the potentiometers fail. The engine can slowly reach maximum speed with limited power. The EML light will be illuminated to alert the driver of a fault. EMERGENCY OPERATION 2 If another fault is encountered in addition to emergency operation 1 or if the plausibility is affected, emergency operation 2 is activated by the ECM. An example of plausibility fault would be that the pulley position does not match the MDK position and the associated airflow. Emergency operation 2 can also be initiated by simultaneously pressing both the accelerator pedal and the brake pedal, or if a fault is encountered in the brake light switch diagnosis. Engine Management Systems When in emergency 2 operation mode, there is an engine speed limitation (slightly above idle speed) in addition to the measures for emergency operation 1. In emergency operation 2, the engine speed is always limited to 1300 RPM if the brake is not applied, and approximately 1000 RPM if the brake is applied. The vehicle speed is limited to approximately 20-25 mph. The reason for limiting the vehicle speed is if the MDK is wide open, the vacuum assist is insufficient for the brakes. The emergency operation functions are inactive when: • Ignition is switched off, main relay is deactivated, and engine is started again • A fault is not detected • Brake pedal is not depressed • The throttle valve is in the idle speed setting FURTHER SAFETY CONCEPTS The MDK safety concept can detect a jammed or binding throttle valve as well as a broken link spring. This fault is detected by the ECM monitoring the feedback potentiometers from the MDK in relation to the pulse width modulation to activate the MDK motor. Emergency operation functions if the throttle valve is jammed: • Engine speed limitation depending on driver’s wish potentiometers and the MDK position. • Limited vehicle speed if MDK is wide open. • The ECM will alternate between 0 - 100% sensing ratio to “shake” the MDK loose. In the event of a fault, the DIS or MODIC must be used to interrogate the fault memory, and clear the fault once the proper repair has been performed. Last edited by HakenTT; 01-26-2013 at 03:17 PM. |
#106 |
Good info. But how do I wire the pedal? Where does it connect in the grand scheme of this?
![]() Last edited by Hornung418; 01-27-2013 at 11:51 AM. |
#107 | |
this means that is posible to just wire the electrical pedal and install MS43 dme in your car. I am investigating this now on my project car. |
#108 |
Yes I've been aware of the throttle body functionality since I took ownership in May 2010.
My question still remains. Where does the pedal connect to the engine management? Sent from my SCH-I535 using Bimmer App
#109 | |
Looks like MS43 could be internaly rewired to work as a "plug and play" on MS42 equipped car. Last edited by HakenTT; 01-27-2013 at 03:23 PM. |
#110 |
Check the first post in this thread. We have already figured out that some simple re pinning will allow the MS43 DME to communicate with the 323 or the 328.
#111 |
It's been a while since I looked at our old posts, but if I remember correctly, we decided it'd be easiest to just run new wires for the pedal. It's only 6 wires, and it's not difficult to get to the DME box from there. Just about everything else can be reused however.
#112 | |
#113 |
#114 | |
I inherited a daily driver in my father's 09 Altima. He passed away on the 4th of the year. So the car can be worked on even with my busy schedule. Going to start the swap tomorow after work at 11 am. Sent from my SCH-I535 using Bimmer App
#115 |
No progress today
![]() Perfect temperatures ruined by high wind forces and heavy rain. Blast! Sent from my SCH-I535 using Bimmer App
#116 |
#117 |
#118 |
#119 |
Yup! Currently have M54B30 Manifold (c. November 2010), M54 fuel rail/filter conversion w/ purple top injectors and a long tube intake.
Headers and a custom 3" header-back exhaust are on the way after the management upgrade.
#120 |
Cool. Well I am swapping M52TUB into E36, running full E36 exhaust sytem without catalists. I will get it running fine with MS42 then after all that is done, I will do a MS43 conversion.
Siemens tuning junkie |
