Old 06-10-2012, 11:27 PM   #1
mikese36m
My Ride: 95 M3 and 325I dd
Another rim and tire fitment question.
I know I know I should search but I did and got mixed results. Here is my concern. I am getting ready to get some vmr vb3's for my wife's 02 325 sport. I am going with 18 inch diameter and 9.5 width with 45 offset in the rear. Question is if it's lowered 1.8 inches can I still stuff those wheels back there if I do a 255/35/18 tire? I really don't want to roll the fenders and she's not crazy about that idea either. So am I going to run in to any issues? Thanks in advance for the input.
Mike
mikese36m is offline   Reply With Quote
Old 06-10-2012, 11:43 PM   #2
Stiggles
Stiggles's Avatar
My Ride: Was built Fri 13th
Nope won't fit. And you'll need to do more than roll the fender.
Stiggles is offline   Reply With Quote
Old 06-11-2012, 12:19 AM   #3
TallSkinnyMatt
My Ride: 330ci
You sure? Cause I'm running 19x9.5 rears with at ET45 offset and 265/30 rear tires. No rubbing at all. Though I did get my fenders rolled...
TallSkinnyMatt is offline   Reply With Quote
Old 06-11-2012, 05:10 AM   #4
azshorty
My Ride: 00 323ci - 01 330i
Originally Posted by tallskinnymatt View Post
you sure? Cause i'm running 19x9.5 rears with at et45 offset and 265/30 rear tires. No rubbing at all. Though i did get my fenders rolled...
+1
azshorty is offline   Reply With Quote
Old 06-11-2012, 05:42 AM   #5
mikese36m
I'm really hoping not to have to, but if I do then I do.
Old 06-11-2012, 09:33 AM   #6
MacFady
My Ride: 330i ZHP
Sedan - wont fit
Coupe - will fit
My experience.
MacFady is offline   Reply With Quote
Old 06-11-2012, 10:04 AM   #7
Stiggles
Stiggles's Avatar
Well you have a coupe and got your fenders rolled.
Unless the advice is to run massive amounts of negative camber for OP, it simply wont work without some modification.
I have 18x8 ET 35 wheels and 225/40/18 tires with a 2 inch drop. It is very close to rubbing the fender in the rear without a roll.
Why not just get a smaller width wheel and tire? Makes life easier and still looks meaty.
Old 06-11-2012, 11:14 AM   #8
mikese36m
well its not lookin good for me i guess. My thought is if I go with a square setup with the VMR VB3's the rear won't be concave and look like traditional rear csl wheels. I don't know if thats just my retarded thinking or what.
Old 06-11-2012, 11:43 AM   #9
TallSkinnyMatt
My Ride: 330ci
Ah forgot OP had a sedan. I'm curious for my car though. The only reason I had fenders rolled was because of my old set up. 9.5 ET33 which i got rid of. 265 may still work on a coupe without rolled fenders. But thats besides the point.
OP, what AC_2007 said. Maybe a smaller width or modifications. Or you can just call up VMR and see what they recommend.
Old 06-11-2012, 04:42 PM   #10
mikese36m
Well vmr says they will fit but could possibly need fender rolling. I'm not sure on that but I hope they are right.
Old 07-24-2012, 09:53 PM   #11
mikese36m
Just an update. I got the wheels and lowering spring on a few weeks ago. And to my amazement.........they fit! I did roll the fenders a half inch out or so. But it does have 255/35/18 in the rear and 235/40/18 up front. It's a good fit and a tight fit. I will post pictures in the near future of it.
