Closed Thread
Old 09-06-2012, 06:03 PM   #121
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
Chris,
Thanks for making this process public, and giving enthusiasts the chance to participate in the design process.
Whatever you decide on, I think the focus on quality is going to sell more units than how it looks over time.
Nice idea for the central radiator venting.
Thanks. And thanks for the ideas everyone else as we've taken all of it in. We are going to produce a documentary video of the design and implementation processes as well as the manufacturing and ultimate release of the hood. We should have the first hoods ready for sale before Xmas.
Chris.
HPF Chris is offline
Old 09-06-2012, 07:49 PM   #122
xixixi
Banned User
My Ride: 01 330x-xi
Originally Posted by HPF Chris View Post
I have seen and spoken to so many people over my lifetime that have done the same stupid thing with not so lucky results. ha ha. I don't think the manufacturers intended on the entire engine compartment being submerged in water.
Chris.
That would only be possible if I filled a pool with water, my car just happened to be parked in. A power washer, is unable to duplicate that. I can say in confidence, power washer all over will cause zero problems. Unless a problem is already present, in that case it will be highlighted. I'm making a video.
xixixi is offline
Old 09-06-2012, 08:12 PM   #123
HPF Chris
Past Site Sponsor
I've seen people pop nearly every electrical component on the car doing this. Relays, Fuses, sensors, electronics, computers, anything aftermarket, lighting, etc. They feel pretty stupid after doing this when I talk to them. People have even caught their cars on fire. If you want to create a following for yourself than convince people to wash their engine compartments with a hose. lol.
I recommend disconneting your battery before you wash your engine compartment and waiting a good couple hours afterwards for everything to dry out before you reconnect the battery.
Chris.
Old 09-06-2012, 08:32 PM   #124
JohnBlaze
My Ride: Black Sunshine
large amounts of cool water on a running or even turned off but hot engine will cause microscopic fractures on the areas in contact with the water as they cool much more fast than the metal below those surfaces getting cooled by the water. Yes you can crack your block this way
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline
Old 09-06-2012, 08:49 PM   #125
xixixi
Banned User
My Ride: 01 330x-xi
OMFG PEOPLE WAKE UP! Most drive up washers, spray the hell out of your car top bottom etc. Do you think for any reason if there is a possible chance to "crack a block" they would be in business, unlikely. In theory when you shut a car off. The temps will rise a bit, due to the coolant not being pushed through the block. Lets say you go to a diy car wash, on the fvcking dial it says engine cleaner. The same logic implied your car is hotter a few mins after shut down. Really? no
xixixi is offline
Old 09-06-2012, 08:50 PM   #126
HPF Chris
Past Site Sponsor
You go super star.
Old 09-06-2012, 09:44 PM   #127
xixixi
Banned User
My Ride: 01 330x-xi
You go super star.
Thanks for the support!
xixixi is offline
Old 09-06-2012, 10:27 PM   #128
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Chris,
Are you going to wait until you've completed the documentry to release the hood design, or will we be getting some sneak peaks before hand?
PEI330Ci is offline
Old 09-06-2012, 10:35 PM   #129
xixixi
Banned User
My Ride: 01 330x-xi
"The following are our requirements for the HPF BMW E46 Hood.
It MUST be AGRESSIVE!!
It MUST work for most E46's.
It MUST have strong internal webbing to support the attachment points to the rear hinges so the hood doesn't flex when you open and close it
It MUST have a super strong hood latch so that no hood pins are needed
It MUST have venting on both sides
It MUST be fade resistant
It MUST be blemish free so the hood can be run without paint
It MUST simply bolt on without modifications "
You said it, I am just agreeing with you. Maybe you weren't sure then? Maybe your not sure now? Maybe you don't know?
xixixi is offline
Old 09-07-2012, 12:04 AM   #130
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
I don't take my car to car washes like that.. my cars have all been hand washed since day one. But I wouldn't hesitate to take a STOCK car through a wash like that ... one with all the plastic barriers underneath/etc..
My concern is with using a POWER WASHER under the hood.. not the water itself.. I don't know what mickey mouse target martha stewart edition powerwasher you use but my power washer will take up tar even on its lowest setting.
In short to suggest/advise that people do that to a modern day car is pretty careless. Especially a highly modified one with aftermarket ecu, additional vacuum plumbing, etc..
MarcusLSB is offline
Old 09-07-2012, 01:41 AM   #131
mkodama
mkodama's Avatar
No. Otherwise people couldn't drive in the rain.
False. Heat takes time to transfer, and the rate depends on variables like the material, the surface area, the temperature difference, etc... Once you shut off your car, you shut off your cooling system, and the hottest areas of the engine are now going to transfer energy to other parts of the engine. Sure, the cylinder walls may cool down, but the head, parts of the block and all the other cooled parts of the engine are going to heat up.
Also, saying all pressure washers work on your engine bay isn't smart. If you didn't know, some pressure washers blast right into concrete, and nothing plastic or rubber in your engine bay will hold up to that. Worse so than the connectors though, are all the bearings on the front of your engine. Get water inside a ball bearing and it's done for.
mkodama is offline
Old 09-07-2012, 06:10 AM   #132
7to3_enthusiast
My Ride: '02 AW 6spd M3
I wouldn't rule this theory out. It all depends on how many high stress areas the water comes in contact with. If the block is engineered properly then they added healthy radius's on any ribs or bosses added to the block to prevent these micro fractures. Even though you can't see one doesn't mean it isn't there. Then the additional heat and forces generated from pushing more power will bring this fractures to life. Just hand wash people...you spend this kind of money for a kit don't skimp on detailing the car.
...just because a car wash offers this option does not automatically mean that it's safe for you're car. A brush auto car wash scratched the hell out of my old paint job on my rx7 and I had to get it repainted. Just food for thought
94 VR R2 Rx7 SOLD
02 AW M3 The daily / looking for FI
14 CW 1.8T Beetle - Wife's dream car
02 4.6is X5 - The Work Horse
04 LSB M3 SOLD
7to3_enthusiast is offline
Old 09-07-2012, 08:17 AM   #133
JohnBlaze
Driving in rain, or washing your car with the hood down is not comparable to running water directly onto an engine with an open hood.
Do you understand that much?
It can happen and I've witnessed it. When I was 16 I learned the hard way, seriously
Old 09-07-2012, 09:59 AM   #134
Forcefed M3
My Ride: HPF Stage 2.75
You cannot crack your block from water hitting it! If this was the case, you would see cars on the road with cracked blocks everytime a suprise rain storm shows up. In fact I drive my car hard and usually will find a water covered section of road, nothing has happened. Heck even the paint on my block looks perfect! Sorry no ones buying it!
Forcefed M3 is offline
Old 09-07-2012, 10:16 AM   #135
JohnBlaze
Well I had to buy a refurbed engine in my Ford Bronco 2 back in 1994 that I personally cracked the engine in when I ran a hose directly onto the engine after driving it for sometime. This same truck I took mudding many many times, the same truck I drove through 20+ yard mud puddles in fields at speed and that was never a problem. However, as soon as the water stream from a hose hit the engine I heard a definitive crack that I'll never forget, and the engine was done. I guess I'll just take your word that it can't happen, even though it actually happened to me. I realize it's not likely to happen, but it definitely can, and I personally made this mistake myself.
Tell you what, why don't you go do some highway runs then when you get home and the motors still hot, try it yourself. Video tape the whole thing and we can see what happens with yours.
additionally, I'll write it again, you cannot compare washing your car or driving in rain to pouring water directly onto the engine.
Old 09-07-2012, 07:58 PM   #136
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
I must sell my car now since I can not pressure wash the engine bay
MSpired is offline
Old 09-07-2012, 08:15 PM   #137
Hockeyguy02
My Ride: E46 m3
F*** this s*** I'm buying a bicycle.
CarbonBlackCinnamon
30% Tint/Black Grilles And Gills/CF Wrapped Trim/MeganRacingExhaust/DepoSmokedCorners
Hockeyguy02 is offline
Old 09-07-2012, 08:49 PM   #138
HPF Chris
Past Site Sponsor
Ever see videos of the fools on the news that try to cross a road during high water. They get a couple feet deep and their car stops running? Then the water keeps rising and sweeps their car away. Hmmm. Wonder why that happens, I thought all cars were waterproof?
Old 09-07-2012, 10:09 PM   #139
xixixi
Banned User
My Ride: 01 330x-xi
My power washer swept my car away yesterday.. It was found 3 counties over with some stickers on it and a CF hood that was just as functional. I find this to be very common where I live. Holy sh!t, an e60 is floating across my lawn at this very moment! Chris please come up with a solution for random cars being pushed off the road by water. I'm sick of dodging these things. Is anyone reading this sh!t? How can you give this man money? Why doesn't logic exsist in this thread? This post is the best I've seen yet. I thank you for the entertainment. You have customers asking about coil/plug set ups. Yet you post about cars floating away in your own thread. You are truly amazing! You have zero renderings of the said hood, this man has zero data to back up any claim. How can you make a decision on something that you haven't even tested? How can something go into production without a prototype? Several tests to develope the correct product to the market?
xixixi is offline
Old 09-07-2012, 10:15 PM   #140
xixixi
Banned User
My Ride: 01 330x-xi
I must sell my car now since I can not use a vented hood
You said it was the rain before that was causing issues now it's a pressure washer. The real issue you have is an exposed electrical connection that is shorting out due to water. I'd assume after 100k into a car, it would run better than it did before. I'd be asking why I gave a man thousands of dollars for my car to run like **** under certain conditions b/c of the hood. You can't run a vented hood... Fixed it for ya.
xixixi is offline
Closed Thread
