Old 07-01-2012, 06:18 PM   #1
bimer21
My Ride: stick 325i
Is my bushing causing this-->
Hi there i have my rear bushing of differential crake, sometimes when i swich gear i hear and feel a little bump coming from the back also when i accelerate hard only on first gear i feel vibration coming under the car! Also i see that the bushing or mount that joint the tranny with the car is a little crack too. And yes i check my rear subframe and its good i clean it and no cracks on chassis noting, is good! Some opinion please thanks
bimer21 is offline   Reply With Quote
Old 07-01-2012, 06:45 PM   #2
bimer21
My Ride: stick 325i
Bump
Old 07-01-2012, 07:27 PM   #3
Alex323Ci
My Ride: M3 & 323Ci (sold)
people bump their threads when it gets kicked off the first page. which in the last 27 mins from your first post it wasn't lost.
if your rear diff bushing(mount) has a crack in it yes, this could be the problem you feel. our E46s also are known to sometimes have this clunk in engagement that people replace almost their whole driveline trying to trace. but yes, if the older style bushing it will flex inside and hit it's outter casing.
so replace that diff mount.
vibration in the driveline underneath can also be from a worn guibo(aka Flex-disc) that is made of rubber. the center support bearing can also cause this. so i would inspect the Flex disc and csb. but certainly replace the rear diff mount if it has a crack and go from there.
Old 07-01-2012, 08:07 PM   #4
bimer21
My Ride: stick 325i
Sorry for the bump but i'm a little desperate with this! Also this start when i switch my shift linkage on thursday! I took the 3 bolt from the bar that goes from tranny to diff and there was when i see this mount with a little crack and i finish my job and tight it back on everything just like it was! Now whats the flex disc and csb? Sorry im lack of knowledge!
Old 07-01-2012, 08:07 PM   #5
bimer21
My Ride: stick 325i
It was not doing this before this!
Old 07-01-2012, 08:17 PM   #6
jasonbimmer
My Ride: 2001 BMW 330xi
what do you want us to say?
do you really want us to tell you to replace them since you've already know the answer?
its like asking what to do when you run outta gas.
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 07-01-2012, 08:35 PM   #7
bimer21
My Ride: stick 325i
i dont know for real i will take the piping out again and will under there what should go wrom but i dont really know what to look for! and the rear bushing of the diff i will remplace it too! but my question should i look for something in specific?
Old 07-01-2012, 08:41 PM   #8
fiveightandten
My Ride: '03 330ci / '98 M3
I'd check your diff mounts and your transmission mounts to see if there's any cracking or separa...Oh..wait, you already did and found exactly that. What's the purpose of this thread again?
-Nick
fiveightandten is offline   Reply With Quote
Old 07-01-2012, 09:30 PM   #9
Alex323Ci
you need to explain this part a little better. "3 bolt from the bar that goes from the trany to diff". are you talking about the driveshaft? if so, that rubber donut thing that connects the driveshaft to the transmission is the Flex Disc(also called Guibo and sometimes Univeral Joint).
"csb" is the "center support bearing".
#1 is Flex Disc and #8 is the Center Support Bearing
Old 07-02-2012, 05:32 AM   #10
bimer21
My Ride: stick 325i
I am NOT gay but guy i love you so much and yes thats is was i talk about the guido or flex disc! So i thinks that my headache with this will end soon jajaj i will order that piece new to replace it thanks i will post with news
Old 07-04-2012, 07:19 AM   #11
bimer21
My Ride: stick 325i
After too much looking any autoparts or autozone have then and dealer cost 200$ and will take from 7-12 days to ship because they dont have in stock so i order then online from ECS 81$+tax under 100$ should be at home before next thursday!
Old 07-04-2012, 04:53 PM   #12
Alex323Ci
haha, glad you got it sorted out.
when doing the Guibo, it's very important to make sure the arrows point towards the flanges. otherwise you will get vibration and the guibo will break in short time. here is a fairly good DIY on it. #7 is the part i'm talking about with the arrows.
http://www.bokchoys.com/differential/diy_guibo.htm
Old 07-04-2012, 05:58 PM   #13
bimer21
My Ride: stick 325i
Thanks for the hint very important info! I appreciate it
Old 07-11-2012, 05:24 PM   #14
bimer21
My Ride: stick 325i
Work done no more shaking thanks! Here is the old one
ID:	460436   Click image for larger version
ID:	460437   Click image for larger version
Old 07-11-2012, 09:28 PM   #15
bimer21
My Ride: stick 325i
F....... Still feeling that vibration inside the car un heavy acceleration but its only until 4k but now its leas
Old 07-12-2012, 07:20 AM   #16
bimer21
My Ride: stick 325i
I only change the two bushings the shifter and shifter level! I did touch the flex disc and now i see that its bad! But my vibration continue! I will buy the center piece and change that too what you guys thinks?
Old 07-16-2012, 04:16 PM   #17
bimer21
My Ride: stick 325i
Check this out
ID:	461048   Click image for larger version
ID:	461049   Click image for larger version
ID:	461050   Click image for larger version
Old 09-06-2012, 07:49 PM   #18
bimer21
My Ride: stick 325i
Here i'm again with same problem! I start feeling some vibration under my car when accelerate slow in 1 and 2 gear till around 3k! And i 1 gear only when i floor it! But i went inside the car i only can see the disc flex and this one looks like new! I cant see the mid-bearing of the driver-shaft but i put this 2 new in less than 2 mounts! Some advice here now please
