What does this dummy light mean? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-18-2012, 10:58 PM   #21
Tiag46
My Ride: e46
Vtec kicked in Yo
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 07-29-2012, 10:22 PM   #22
jaymar88
My Ride: Acura
You guys are all dicks for not giving him a real substantive response.
Those lights indicate your exhaust manifolds are overheating.
http://farm5.staticflickr.com/4003/4630289415_0c3784d64b.jpg
jaymar88 is offline   Reply With Quote
Old 07-30-2012, 03:40 PM   #23
PhotoPro
My Ride: 01 325i
Thanks for all the jokes! Made it a little more enjoyable to read. It was the license plate light burned out / or loose. Problem fixed, and now I have a turbo charged vTec engine with warp drive, overheating exhaust manifolds, a brand new set of flux capacitors, AND new LED license plate bulbs. Unfortunately the search function on this site is REALLY cluttered, and it's far easier to ask a new question than read a billion threads looking for my answer.
PhotoPro is offline   Reply With Quote
Old 07-30-2012, 08:41 PM   #24
jaymar88
My Ride: Acura
Glad you got it fixed bro.
Old 07-31-2012, 11:10 AM   #25
cityjohn
My Ride: 2001 M3
You're gonna miss those little lights now
cityjohn is offline   Reply With Quote
Old 07-31-2012, 11:30 AM   #26
PhotoPro
My Ride: 01 325i
I was about ready to pull the gauge cluster and yank the lights out! haha
Old 07-31-2012, 11:56 AM   #27
Breyton-BMW
Breyton-BMW's Avatar
My Ride: Ti
Send a message via AIM to Breyton-BMW Send a message via Yahoo to Breyton-BMW
Glad to help.
Breyton-BMW is offline   Reply With Quote
Old 07-31-2012, 01:13 PM   #28
putyoursoxon
My Ride: 03 M3
incoming missles, fire chaff
putyoursoxon is offline   Reply With Quote
Old 07-31-2012, 04:53 PM   #29
RKiepper
My Ride: 1999 E46 328I x2
I need one of these.
RKiepper is offline   Reply With Quote
Old 08-02-2012, 01:36 PM   #30
waterdale
My Ride: 2001 330Ci Conv
I had the same problem with my 01 330 Cic. The "dummy" ligts for taillight problem would go on and off (mostly on) until one day it to continuously on. I checked the wiring to taillamps to see if my car was affected by the insufficient ground plug design that has been so well documented elsewhere on this site. I found no evidence of a problem, but I proceeded to make the recommended bulb plane gronding repair anyway. No dice. Finally, (what a dummy) I realized my license plate lights had stopped working. I found the bulbs were both blown, so I replaced them, but they still didn't work. Then I found there was no voltage at the lamp socket. I began to wiggle the bundle of wires inside the rubber sleeve that run from the right front of trunk lid to the body, and to my surprise, the license plate lights began to flicker on and off. I cut open the rubber sleeve, and I FOUND THE PROBLEM! AT LEAST SIX FO THE WIRES BUNDLED THERIN were very visibly damaged - with a couple nearly cut through. Just a jiggle on one of the wires that fed the license plate lights, and it broke in two. SO, I a soldered in splice in the most damaged, and wrapped the remaining less-damaged (but not cut throgh) wires in electrical tape, and viola, everythings worked. And best of all, no more light-out indicator warning light at the dash.
waterdale is offline   Reply With Quote
Old 09-24-2012, 01:16 AM   #31
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Originally Posted by PhotoPro View Post
Red lights towards the rear of the car. My brake lights and reverse lights work fine from what I can see... Hmmm. Any help?
Check the lights that illuminate the liscence plate.
aahmed2016 is offline   Reply With Quote
Old 09-27-2012, 10:53 PM   #32
chuckdiez323i
My Ride: 2000 323i
had the same issue i put the wrong type of bulb in but you have to find the right bulb you can feel it snap in place but if it needs to be forced in its the wrong bulb and they will seem dimmed compared to the rest
chuckdiez323i is offline   Reply With Quote
Old 09-28-2012, 08:22 AM   #33
waterdale
Check out my post from 8/2, just above yours. Most problems related to the dash dummy light rear-light problem annunciation are due to a grounding problem with the taillight assembly ground plane, as documented in great detail elsewhere on this site. I've gathered that this problem is more common, if not uniquely common, on newer-than-01 models, and it was eventually addressed by a BMW recall.
My problem, also an 01, (and with same dummy-light symptom) turned out to be a completely different issue -- damaged / broken wires within the wire bundle that is located inside the rubber boot that leads from the trunk lid to the body (on my car, attached to passenger-side hinge strut). My license plate bulbs continued to burn out, apparently due to their constant flickering on/off due to the shorting wire lead located within this rubber boot. The lead to the license plate was all but broken in two, and several other wires also showed considerable insulation damaged with some exposed wires . It almost looked as if the insulation was cut, as if the wires were damaged before or during installation, and not by opening and closing of the trunk. Of course, there is no way to say for certain.
To check this out, carefully slit the boot open on one side with a sharp knife to expose the bundle of wires therein, and take a look. Repair any damaged wire(s) therein as/if necessary, and then tape boot back up with electrical tape, and reattach it to hinge strut with strip-ties.
Good luck
Old 09-28-2012, 10:41 PM   #34
kowalzekc
My Ride: 99 328i
I have the same light on and I can say with certainty for me it was the licesnse plate light.
kowalzekc is offline   Reply With Quote
Old 12-25-2012, 07:28 PM   #35
Juliopinto03
My Ride: 2000 328i
Easy fix ! Headlights stopped flickering as well
Juliopinto03 is offline   Reply With Quote
Old 01-09-2013, 10:05 AM   #36
BiMMeR07AtX
My Ride: 2001 325i
I think im ganna take my license plate bulbs out and rig a separate LED bar so i can have this light pop up all the time so i can tell people that i have turbo boosters. my cluster looks boring with no indication lights on anyways
BiMMeR07AtX is offline   Reply With Quote
Old 01-09-2013, 10:13 AM   #37
tcphoto
My Ride: E92 335 MT Coupe
I had that warning last summer when the ground wire on my tail light corroded. I relocated both ground wires on the holders and it was good. Ironically, one was corroded and the other was not but the problem was with the clean wire. There was a recall for the 2002-2006 models but did not include my 2001.
tcphoto is offline   Reply With Quote
Old 02-22-2013, 11:02 AM   #38
newnoise
My Ride: 2000 BMW 323i E46.
This thread was hilarious AND helped me find the issue. Thanks e46ers!!
newnoise is offline   Reply With Quote
