Old 07-08-2013, 09:04 PM   #221
jared_wiesner
My Ride: 1999 328i (M54b30)
Epic Motorsports/Bimmerworld tune
Just checked disa operation by marking lever into vacuum pot with whiteout, the valve closed at idle and the mark went into the pot. When revved up slowly it shot back out at 2500 rpm. I thought it wasn't supposed to activate until 4000 rpm but its hard to say if it switches earlier if the car is revved with no load in neutral or if its something randy changed. He mentioned he played with the disa timing and that's how he got me the extra bump down low that I was missing.
jared_wiesner is offline   Reply With Quote
Old 07-08-2013, 09:11 PM   #222
jared_wiesner
Originally Posted by Iceman00 View Post
Try unplugging the DISA hookup and see if the bottom end feels stronger, it could just a bad seal.
When unplugged the disa stays open. It needs power to use the vacuum to close it until it reaches the activation point. So with it open I'd have no low end.
Old 07-08-2013, 09:31 PM   #223
Iceman00
Banned User
My Ride: E90 6MT
Hmm, are you sure - I thought active was the DISA closed. I might be mixed up here.
Old 07-08-2013, 09:36 PM   #224
jared_wiesner
Ya just tried it. It opens when unplugged, but I do wonder if 2500 is too early for it to open when I rev it up. It's hard to say if its something randy changes or if its due to being in neutral, or maybe There's something wrong with it.
Old 07-08-2013, 09:40 PM   #225
Iceman00
Banned User
My Ride: E90 6MT
In any case, you can see what a proper changeover does for torque. I can't wait till we shark your car.
Old 07-08-2013, 09:43 PM   #226
jared_wiesner
Ya I'm curious to see as well.
Old 07-08-2013, 11:24 PM   #227
jdjg
My Ride: e39, m52tub30
much better and easy, why don't you scan the codes in your can? if you have a bad DISA, you will have an error......
jdjg is offline   Reply With Quote
Old 07-09-2013, 07:03 AM   #228
jared_wiesner
I have no codes and no a bad disa will not always show up as an error.
I've sent an email to Randy asking about the fact that its opening at 2500 RPM
Old 07-09-2013, 05:56 PM   #229
jared_wiesner
Solo,I just verified that my old disa from my 328 does not open up fully if my finger is over the hole. It holds vacuum. I'd say my disa and your new disa are bad given they fail this test. I'm gonna see if I can find a decent one at the wrecker sometime and go from there.
*Edit*
Just heard back from Randy, he definitely thinks the disa has an issue.
Old 07-09-2013, 08:18 PM   #230
Iceman00
Banned User
My Ride: E90 6MT
Check this forums FS section, someone hooked me up with one for free.
Old 07-09-2013, 08:26 PM   #231
SoloII///M
My Ride: Many
That's a bummer. I ran that test twenty times today and it failed it every time. I guess I'll bring my backup one to the dyno this weekend.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 07-09-2013, 10:25 PM   #232
jared_wiesner
Done already, nothing there worth getting right now. Local bmw only wrecker says 100 bucks. If that part checks out that's likely what I'll do.
Old 07-15-2013, 03:47 PM   #233
jared_wiesner
After pouring through dyno's for a day, I also have a feeling that gen 3 headers could really help. Sigh, I'll have to do some saving.
Old 07-15-2013, 03:57 PM   #234
jdjg
why do you think that???
regards,
Old 07-15-2013, 09:54 PM   #235
jared_wiesner
regards,
Generally seem to make up to 10 whp more in spots over cars with ebay headers. Most cars making big power up top have them.
Old 07-15-2013, 10:34 PM   #236
da Vinci
My Ride: 2003 BMW 330i ZHP
Has anyone gained 10 hp from any header? I have some BB Gen3 that I am trying to fit some SCCA STX legal high flow cats and I think 10 hp is optimistic. The headers have not been installed yet.
Click here for my Build Thread
"Make everything as simple as possible, but not simpler." Albert Einstein
da Vinci is offline   Reply With Quote
Old 07-16-2013, 12:38 AM   #237
Iceman00
Banned User
My Ride: E90 6MT
Headers can probably boost mid range power, but peak power isn't effected as much, if at all.
Old 07-16-2013, 07:07 AM   #238
jared_wiesner
Like I said I'm seeing up to 10 whp in spots. I never saw that at peak though I did see sizeable gains that were close up there. From the little bit of information that is available, the gen 3 headers were supposed to make the best peak gains vs the gen 2's. Most of the people running the big number cars are also running those headers. In the end i really only care if they make the car faster so whether they boost peak or not, as long as the whole curve around peak is boosted, I'm happy. Now, whether I think the Bimmerbrakes copies measure up is hard to say. I have no idea if they will be as good as the originals. It will also be a while before I get to try this out.
Old 07-16-2013, 07:34 AM   #239
SoloII///M
My Ride: Many
Comparing my car with Technik V3s to a very similarly set up car with supersprints (real ones, not eBay knockoffs), we made very slightly more top end power with the V3s and it was only from 6200-6800. My car also made a decent amount more midrange torque but I attribute that more to intake manifold differences and E85.
John V
Old 07-16-2013, 09:42 AM   #240
jared_wiesner
Could be that what I'm seeing is alot of ebay supersprint vs genuine technik headers.
Neither the real supersprint or original technik is in my budget though... so, it really depends on whether the bimmerbrakes replicas stay true to the originals.
