Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#61 |
Wow I am liking this tune more and more !
#62 |
Did they ever say if they remove the CEL from headers with the Tune?
#63 |
They can do that, I will be sending him a copy of my fault codes and he will be sending back the tune with the o2 monitoring removed. Also I'll be getting the stock version of the tune file for e-test purposes.
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. |
#64 |
When I get the car back to the dyno post tune, yes.
John V
'03 330i ZHP 6sp street car '02 330Ci 5sp race car |
#65 |
I screwed up and can't post
I've been sick and out of town, sent some funds. Good Luck on this.
#66 |
Thanks so much! only 4 more days.
#67 |
It's crunch time.
#68 |
Dyno day is today! I work till 5 EST. Dyno is booked for 6. Supposed to be a nice cool 71 degree day today. High Humidity though, 90% right now. Even still, it should run well. It felt great this morning.
Thank you everyone who has made this financially possible/reasonable for me!
#69 | |
![]() Hope this works out well for you, interested in results (particularly for 02 sensor removability).
2003 Jeep Wrangler Rubicon 2000 BMW 323ci 1995 Saab 900 SE - JZW Stage 4 |
#70 |
I should also clarify for those that are concerned about the temp being different today and having missed the middle of the thread, I will be dynoing with and without the tune today. This way, all factors remain constant except the tune.
#71 |
Please dyno first WITH the tune. Since our computers adapt to modifications, the on/off switch with mods on a dyno can actually be misleading. For example, getting a dyno, installing a BBTB and then getting another dyno right away is not an accurate test.
#72 | |
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. Last edited by jared_wiesner; 08-14-2012 at 09:25 AM. |
#73 |
Banned User
updates?
#74 |
#75 |
Just finished, pretty crushed by the results. Seems what I felt was all in my head/ I was fooled by part throttle position tweaks.
Car made 195 whp on its best run with the epic tune. About 2-3whp more than the best non tuned run. No more low end power either, in fact on one run the stock tune made more. The only possibility that I'm hoping for is that the guy running the dyno who is a pretty well known import (not BMW) tuner mentioned the extreme whistle that my car has above 4000 rpm. I thought it was from my throttle spacer but he said it was definitely a whistle from an exhaust with a lot of restriction. I'm hoping that my car is just bottlenecked right now and the tune is not able to be a factor. Graphs to follow later tonight when I get home.
#76 |
Hmmm.....
(FYI you now have 20whp on me. Time to catch up!) |
#77 | |
#78 |
Graphs are as follows.
The first graph is the big mess of all the runs. Runs 3-8 are with the Epic tune. Runs 9-11 are the stock Euro tune, these were done after a 15-20 min cool down. The second graph is my three best of each, so runs 4-6 are with Epic tune and runs 9-11 are the stock Euro tune Last graph is best of each. Run 5 is Epic tune, Run 10 is stock Euro tune. You can tell the Epic runs pretty easily because they all go to 7k RPM. Thank you everyone again for the support! It meant so much. I'm just sorry I couldn't come back with better news.
![]() Check out my band - The Marked 1999 BMW 328i (Daily Driver) - m54b30 intake manifold, ebay headers, Rebirth Motorsports CAI, Rogue Engineering underive pulleys, Epic Motorsports Software, Custom 3 inch exhaust with Burns Merge, Schrick 264/248 Cams 1967 Buick Skylark - 430 Buick Big Block Swap. Last edited by jared_wiesner; 08-16-2012 at 10:49 AM. |
#79 | |
#80 |
Id say I gained nothing, that was one run, the averages say it's not making any more.
