Old 07-03-2012, 05:59 PM   #1
gavi
My Ride: BMW 330Ci sport 6MT
Post Changed Lower control arm bushings: DIY for you
Hi, I had my lower control arm bushing changed, payed 100$ + oil change.
I would have done if I could lift my car myself!
So if you have that opportunity (the lift) you can do it
This are the steps
I have three pictures while my car was up!
I have marked the bolts and screws with stars!
first set is three red stars (3 screws)
then continue on red stars bolts (4,5,6,7,8,9,10,11) be careful the aluminum protector will fall on you!!! hold it when you are about to unscrew 10 and 11 bolts.
Then you will see the bushings, left and write on the picture is new ones with only two bolts fastened on the body or frame(two other photos).
then you will see on the right side bolts (green stars 1,2) on the left side bushing two bolts (blue stars 1,2) undo them and proceed to taking off the bushings.
I bought the set of my bushings from bavarian auto sport, for 70$ with aluminum brackets.
If they are worn out you can pull them out with rotating and pulling them out, if it will be hard you can use WD-40 and some holding and squeezing tools.
then for easy putting them back, you can use a soap water, so easy to put them back on (the new ones)
After putting everything back, tight up the bolts and last three screws back, by back order!
And wallah, you are gonna have a new car!
Notice! I haven't changed my arms completely cause they were and still are in a good condition! (even dealer said to not replace them(believe it or not, but they said thing like that sometimes )
I hope this will help a little bit!
Name:	Left Lower Arm Bushing NEW.jpg
ID:	459144   Click image for larger version
Name:	bushing replacement.jpg
ID:	459145   Click image for larger version
Name:	Right Lower Arm Bushing NEW.jpg
gavi is offline   Reply With Quote
Old 07-08-2012, 05:54 PM   #2
Bimmer37
My Ride: 2003 BMW 330i
thanks for the pics
Bimmer37 is offline   Reply With Quote
Old 07-08-2012, 05:55 PM   #3
Bimmer37
Were the new bushings already pressed or did the shop do that as well?
Also, was wondering where you had them changed at and if you recommend them.
Old 07-10-2012, 03:28 PM   #4
gavi
Sorry for late response.
I would recommend them, pm me
I bought bushings pressed in aluminum brackets, so you have to just replace the whole thing its easier...
PM me I will tell you also where to get them a wholesale price
Old 01-13-2013, 10:08 AM   #5
Joe C.
My Ride: 2001 330i\sport pack
Can I just jack one wheel up at a time and change the control arm and bushing?
Joe C. is offline   Reply With Quote
Old 01-13-2013, 11:03 AM   #6
Passnu2
My Ride: Sport Wagon
shouldn't be an issue so long your using a jack stand and not the jack to hold the car up.
Passnu2 is offline   Reply With Quote
Old 01-15-2013, 05:13 AM   #7
Joe C.
Perfect. I was just going to replace the bushings, but is it worth replacing the control arms too? While I'm down there.
Any tips on not wrecking the bushing while trying to press in on?
Old 01-15-2013, 09:20 AM   #8
Brobby87
My Ride: 2003 325i, 1986 535i
When i took my control arm out the ball joints on the arm were blown out and had way too much play in them.
Get new arms by Meyle that have replaceable ball joints. You'll be glad you did because the steering stiffens up by quite a bit.
You got many miles on the OEM arms?
Brobby87 is offline   Reply With Quote
Old 01-15-2013, 08:52 PM   #9
Joe C.
As far as I know they are original. Car has 138,000 as of today. I've had the car for 3 years now.
Old 01-16-2013, 08:23 AM   #10
Brobby87
Oh yeah I bet they are due to be replaced. I replaced mine at 142,000 and they were toast.
The new ZHP arms that I installed fixed my mushy steering right up though.
Old 01-16-2013, 07:39 PM   #11
Joe C.
Mine is a 330i with sport suspension. Is there a diff. in meyle hd arms and the others? I want to make sure I get the right ones..
control arm bushings, replacement
