#1 |
My Ride: '04 325i,'99 Boxster
Fuel Pump Location
Hi Class. Where is the fuel pump located on an '04 325i? Mine crapped out today and I ordered a new one from BMA. Is it under the passenger seat or do I have to drop the tank? Either way, It has to be fixed.
#2 |
My Ride: 2000 BMW 3XXi ZSP
Let me get my easy button... Its under the rear bench seat, its easy to get to and an easy DIY... You should be able to use google and find the steps to the DIY. Just my two and a half cents worth!
V/R Zachary Pullins Sr.
National Capital Chapter BMWCCA NCC Member Recognition Chairman NCC High Performance Driving School Registrar NCC Auto-X BOD Liaison DIY Senior Committee Coordinator 2006 E90 325Xi & 2000 E46 3XXi " Vision without resources is just hallucination" |
#3 |
Mod
Do you have a SULEV engine by any chance?
#4 |
Banned User
My Ride: 2003 325i stick
the SULEV engine is for the birds
#5 |
No. I have the normal engine. I was in the fast lane on 95 and went to accelerate. My foot went down but the car didn't speed up. I parked it on an incline at my house on Thursday. I went out this morning and tried starting it. It coughed and weezed...and then died. 124,500 on the clock
Thanks All |
#6 |
Has fortified jimmies
My Ride: 330Ci ZHP 6sp
Access to it is literally under the passenger's seat. Easiest replacement ever compared to most cars.
#7 |
sounds great. I've had to do it to 2 Porsche 944's, plus a sending unit. They're somewhat similar. My '98 328i had 150k on it and was still doing the job before it got wrecked,
#8 | |
#9 |
Both sides?
#10 |
My Ride: '06 330CiC, '03 M5
You do not need to replace the siphon pump on the drivers side. This is a passive device with no moving parts. Very rare these ever have problems.
Suggest you read this thread - http://forum.e46fanatics.com/showthread.php?t=929501
Fuel pump failures - http://forum.e46fanatics.com/showthread.php?t=929501 Temp Info - http://forum.e46fanatics.com/showthread.php?t=964491 Hidden OBC Menu - Check Voltage, Temps, Fuel Level - http://forum.e46fanatics.com/showthread.php?t=239619 E46/E39 GM5 Door Lock Info - www.bmwgm5.com Lower hose fan switch O-ring - BMW #13621743299 |
#11 |
I did read this earlier today. Got my fuel pump from BMA for 106. I knew that was the problem after I read a few posts this morning. Fule filter was replaced last year. Hopefully the relay isn't bad, but if I find out it is, I get a new one. don't need the car for a while. Have plenty of time and other things to drive.
BTW: thanks for posting all the good info. |
#12 | |
My Ride: M3 & 323Ci (sold)
just so you know that doesn't mean it's your fuel pump. but i think you sorta related you know this and want to see if this fixes it. good luck.
![]() ![]() OEM CSL WHEELS - OEM CSL BRAKES - OEM AUTOFOLD MIRRORS - CSL TRUNK - CSL DIFFUSER - AA SPORT TUNE - AA PULLEYS - BILSTEIN PSS9s - AUTOSOLUTIONS SSK CF CSL RACE LIP - NAVI HU - BMW PERFORMANCE CF STRUT BAR - BMW GROUP-N MTRMTS - UUC SS BRAKELINES, TRANS MOUNTS, RTABs - 4.10 BMW M-SPORT DIFF |
#13 |
My Ride: '94 325iC & '00 323i
