General Off-Topic
View Poll Results: Which Bullet will hit the ground first?
The bullet in his hand 31 28.70%
The bullet fired from the gun 4 3.70%
Both at the same time 70 64.81%
No idea. Stupid bloody question 3 2.78%
Voters: 108. You may not vote on this poll
Old 07-04-2012, 06:55 AM   #1
gueste46
Banned User
A Physics Puzzle
This is not a trick question.
A man stands and in one hand is holding a hand gun aimed directly ahead and in the other hand is holding a single bullet.
If he fires the gun at the same precise moment as he releases the bullet in his other hand, which bullet will hit the ground first? The bullet fired from the gun or the bullet he was holding in his hand?
gueste46 is offline   Reply With Quote
Old 07-04-2012, 06:58 AM   #2
stevenluczynski
My Ride: Is Steel Blue
Both will hit the ground at the same time, a bullet has no wings.
stevenluczynski is offline   Reply With Quote
Old 07-04-2012, 07:04 AM   #3
bmw325coupe
My Ride: bmw 325 coupe
i would think at the same time, as the same gravity is acting on both
bmw325coupe is offline   Reply With Quote
Old 07-04-2012, 07:13 AM   #4
absent
My Ride: '01 325i
Originally Posted by stevenluczynski View Post
both will hit the ground at the same time, a bullet has no wings.
+1
absent is offline   Reply With Quote
Old 07-04-2012, 07:17 AM   #5
pancakes
My Ride: GTI, DRZ, Opel
depends. is he on a treadmill?
pancakes is offline   Reply With Quote
Old 07-04-2012, 07:47 AM   #6
Rubenk
My Ride: M35A2
Well there are far too many variables in play if you were to perform it real world, but theoretically in a perfect environment, they would hit the ground at the same time.
Rubenk is offline   Reply With Quote
Old 07-04-2012, 08:12 AM   #7
ryanwhite74115
My Ride: 2013 Infiniti G37S
Are we accounting for the coriolis effect, humidity, wind speed, direction bullet was fired, what about the moon (it does affect gravity...haha).
All these questions and no answers.
I'm a lawyer. I'm most likely wrong.
ryanwhite74115 is offline   Reply With Quote
Old 07-04-2012, 08:17 AM   #8
JTLaz
My Ride: 2010 Wrangler 4 Door
I would say the bullet being dropped. The bullet being fired has a force pushing it horizontally; gravity must overcome this force to push the bullet down.
JTLaz is offline   Reply With Quote
Old 07-04-2012, 08:42 AM   #9
Rubenk
My Ride: M35A2
Must it?
A similiar experiment can be done with a pendulum.
two objects of identical mass/weight, one tied to a string so that it can swing freely. Drop it from a point perpendicular to its post(string taut) and drop a free flying object next to it. I would strongly suspect that the stringed object reaches the bottom of its swinging arc at the same time the free flying object reaches that height, despite being moved laterally.
Old 07-04-2012, 09:02 AM   #10
CollinsE90
My Ride: 330i
They did this sh1t on mythbusters; you can go back to gun research now OP.
CollinsE90 is offline   Reply With Quote
Old 07-04-2012, 09:03 AM   #11
Wraisil
My Ride: 2010 Infiniti G37
The bullet he drops will hit first. The rate of fall will be the same for both bullets but the earth is curving downward as the fired bullet moves away from him. This means that the total distance to fall will be the height of the bullet when fired plus the additional distance it must fall because of the planets curvature. If, however, the particular location he is firing at is going to an upward elevation (i.e. towards a mountain etc) then the bullet fired would hit first because there would be less distance for it to fall. They fall at the same rate, but one is falling straight down from the original height and the distance the fired bullet must fall will be dependent on the curvature of the earth in the direction of its travel.
Wraisil is offline   Reply With Quote
Old 07-04-2012, 09:42 AM   #12
JTLaz
http://scienceblogs.com/dotphysics/2...s-bullet-drop/
They don't hit at the same time. Actually, all three objects will hit differently. The no air drag object will hit first, then the dropped bullet and then the fired bullet. The above graph looks like just two lines because the dropped bullet and the no drag bullet are so similar. Let me zoom in a bit on that graph.
Old 07-04-2012, 10:40 AM   #13
rohde88
rohde88's Avatar
My Ride: S2000
Originally Posted by Rubenk View Post
Must it?
two objects of identical mass/weight, one tied to a string so that it can swing freely. Drop it from a point perpendicular to its post(string taught) and drop a free flying object next to it. I would strongly suspect that the stringed object reaches the bottom of its swinging arc at the same time the free flying object reaches that height, despite being moved laterally.
My post was taught by yarn. Does that make a difference?
-Ron
rohde88 is offline   Reply With Quote
Old 07-04-2012, 10:44 AM   #14
s3th
s3th's Avatar
My Ride: 05 330Ci ZHP
Both.
You can just call me seth.
500px
s3th is offline   Reply With Quote
Old 07-04-2012, 11:36 AM   #15
Rubenk
My Ride: M35A2
*sigh*
taut...
Old 07-04-2012, 11:47 AM   #16
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
Force applied to a fired bullet I feel would make that bullet slower to hit the ground than just a dropped bullet. My reasoning is the net force pushing the bullet to the ground is less than gravity itself.
Dropping a bullet has only gravity acting on it so net force will roughly be gravity.
Firing a bullet still has the same gravity acting on it but also a horizontal force component. Once the net force is calculated, it will be less than that of gravity (thinking of a triangular force diagram here)
Tutankhamon is offline   Reply With Quote
Old 07-04-2012, 12:51 PM   #17
Roller619
My Ride: 03 E46 325iT
The answer would be more meaningful if proven with equations.
Roller619 is offline   Reply With Quote
Old 07-04-2012, 01:41 PM   #18
kuksul08
My Ride: M3
the bullet will take off
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 07-04-2012, 01:44 PM   #19
gueste46
Banned User
Extra marks for the humour.
Old 07-04-2012, 02:07 PM   #20
ImPulSe
My Ride: Bentley GT
The same can be done with a book and a feather
