My car just shut down on the road won't restart - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-04-2012, 06:45 PM   #1
EDWAGON
My Ride: 2004 325xiT
Had a engine light on for a day or so then today on way to store just started to sputter and engine shut down. Would not start just turned over and over. Got it Flatbeded to my Indy. Tried to change everything (coolant refresh, fuel filter, pulleys) last few months so I wouldn't be left on side of the road but obviously something just shut me down .
Any ideas what it may be? I guess I will know tomorrow when Indy opens up.
EDWAGON is offline   Reply With Quote
Old 07-04-2012, 06:58 PM   #2
jasonbimmer
My Ride: 2001 BMW 330xi
fuel pump maybe?
2009 Mazda RX-8 R3
2013 Toyota FJ Cruiser
2008 YAMAHA YZF-R6
Old 07-04-2012, 07:34 PM   #3
Wickedly
My Ride: 2016 BSM ///M2
I bet fuel pump too
Wickedly is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-04-2012, 07:34 PM   #4
VG1134
Old City Bimmer
My Ride: Classifieds
You need to pull codes. It can be anything.
VG1134 is offline   Reply With Quote
Old 07-04-2012, 07:54 PM   #5
ExitBuddy
My Ride: 2008 335i Vert
When my fuel pump failed and stranded me last week, and had it towed to the indy, when I asked him whether or not there were any codes generated, hidden or not, and he said there weren't any. Is he lying, or are there events that exist that would not throw a code?
But I also agree, fuel pump is suspect, but there are other things it could be. Rule out everything else first. Fuel pump replacement can be a big money maker for the shop. Unfortunately my indy boned me big time to replace fuel pump, filter, seals, just over $1000. Don't think I am going back.
ExitBuddy is offline   Reply With Quote
Old 07-04-2012, 08:07 PM   #6
jfoj
My Ride: 330CiC, M5, X5, E93
$3 can of starting fluid and a good solid 2 second shot into the air cleaner box will tell you if it is a fuel related problem. Car will start then immediately die.
You should read this thread - http://forum.e46fanatics.com/showthr...501&highlight=
Usually these fuel pumps on the E46 do not trigger any codes, sometimes you will get lean codes. E39 will sometimes show up a fuel pump relay when the pump is usually at fault.
Also suggest you check the first link below in my signature for info on codes and vacuum leaks and also check the hidden OBC menu and check your fuel tank levels. If the right tank is empty, you can probably add a few gallons of fuel to get home and then order a fuel pump.
Good luck.
Old 07-04-2012, 08:32 PM   #7
Wickedly
a fuel pump shouldn't cost more then $250 and is an easy DIY If you paid $1000 to get yours change , I feel bad for you
Old 07-04-2012, 09:26 PM   #8
immigrant
Banned User
My Ride: BMW
Camshaft Sensor might be the problem also
immigrant is offline   Reply With Quote
Old 07-04-2012, 10:54 PM   #9
EDWAGON
I had a check engine light on for a day or two. So there are codes I would assume. Seemed like the engine was starved fuel before it shut. Hope it's just the pump and the last thing that will strand me.
Old 07-05-2012, 06:46 AM   #10
jfoj
See if you can get your car from your indy or have him order your pump from BMA.com
Again, if your right hand fuel tank lobe is empty you can add a few gallons of fuel and get home.
Fuel pump replacement is as easy as changing a tire and you do not have to jack the car up!
Old 07-05-2012, 06:55 AM   #11
dmax
dmax's Avatar
My Ride: '99 328i 340K miles
I was hoping someone would suggest 'fuel.' Jfoj got it, I see!
OP, the fuel level sender often fails...sometimes the sucking jet pump (which transfers fuel from one lobe to the other).
Search 'crank no start' here...there are a number of things that could cause this. FP is one. FP relay/fuse also. Then there's the Kalim Fuse...the 20-amp in e-box. If it's blown, could be because one of 9 things it powers has an issue. In my case, the intake cps wire had a kink in it and it was shorting out, blowing Kalim Fuse...which also powers the FP relay.
But, adding fuel is a good starting place.
GL!
Appearing Friday, Jan. 13 at Greenwich Village Comedy Cub, 99 Macdougal St., NYC, 6 p.m.
dmax on Facebook
Mangofy your E46!
Old 07-05-2012, 10:37 AM   #12
EDWAGON
Confimed it's a fuel pump as per Indy using oem charging me 264 for pump, labor not sure yet , what do you think is a fair amount of time to change pump?
They are always fair with me been using him for 16 years.
Old 07-05-2012, 10:40 AM   #13
jfoj
Probably a fair price depending on what he pays for the pump and when you will have the car back.
You can get a pump for abour $106, I bet your Indy is paying a lot more?
Suggest you put a fuel filter and pump relay on the near radar as well.
Old 07-05-2012, 10:44 AM   #14
My Ride: Lexus
And to all those who were challenging us in the JFOJ's fuel pump thread---where are you now?
My first reaction from reading the thread title alone was fuel pump. Pretty simple and obvious. What could have been a $107 30 min DIY project has now turned into $265 pump, $100 labor, $100 towing potentially $500 job. Not to mention the inconvenience.
Old 07-05-2012, 10:52 AM   #15
EDWAGON
Towing was free (20 buck tip ) through Allstate roadside assistance 80 bucks a year( on Dads policy)
I have changed filter already and happen to have a relay at home will change that when I get it back. Will be ready today.
Funny thing I was reading your thread about the fuel pump last week and was meaning to change it since it was so easy.
Old 07-05-2012, 11:00 AM   #16
jfoj
So easy a caveman can do it!
Old 07-05-2012, 11:05 AM   #17
Gus330vrum
My Ride: 330ci
Fuel pump + fuel filter!! Check relay.. "rarer a 100k maintenance or 150k+ if u lucky.
Avoid Indy shop at all means!
Way to expensive ... I would have searched all night before paying Indy shop any money or telling them is okay to touch my car.
Only Indy shop after so many searchs and NO luck on your answer.
Fuel pump fail diagnostic method is to let your fuel get bellow 45 miles left & drive hard and let it idle... if any shutter/engine hesitation/loss power on acceleration or weak is signed of bad fuel delivery to the injectors..." listen to your engine .. it will be obvious ...
Yes miss fires & CEL did come when I had my bad fuel pump.
Check my fuel pump threads ..
Sent from my ZTE-X500
Gus330vrum is offline   Reply With Quote
Old 07-05-2012, 11:07 AM   #18
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
Just finished replacing my fuel pump the other day. Final cost was 45 mins of my time and 140 bucks after tax and shipping was included.
Tutankhamon is offline   Reply With Quote
Old 07-05-2012, 11:11 AM   #19
EDWAGON
I really regret not doing it now I'm paying triple oh well.
Old 07-05-2012, 02:41 PM   #20
Alex323Ci
My Ride: M3 & 323Ci (sold)
What did they challenging you guys about exactly? That fuel pumps can go out or something else? Sure they can/do go out. And when the car gives you a Check Light and codes that suggest it's on it's way out then you can replace it. Simple logic no?? There is no reason this thread couldn't not have been about reading the codes and replacing it himself for $107.
Originally Posted by EDWAGON View Post
Had a engine light on for a day or so then today on way to store just started to sputter and engine shut down..
sorry but the car told you the problem days before you drove it til it shut down. not picking on you, just pointing out that had you taken heed in those days prior you would/could be posting how it cost nothing extra. if you had to do over I have a feeling you'd have checked the codes immediately??
