Old 07-04-2012, 09:16 PM   #1
iParkHard
My Ride: TIAg 330Ci ZPP
Help Please: P1192 & P1190 - Pre & Post Catalyst Fuel Trim System Bank 1
Anybody have any insight on fixing code P1192 - Manufacturer Control Air Fuel Metering. I've searched on several different occasion since I've been battling this for a couple weeks now. I can't seem to keep it off long enough to get the car inspected. And the threads I've seen, no one has a definitive answer as to how they fixed it.
***EDIT***
I've replaced both pre and post cat O2 sensors. Which removed the P1190 (pre-cat 02 sensor) code. But I'm still getting the P1192 code.I've replaced both pre and post cat O2 sensors. I've also replaced the lower intake boot and intake boot that connects to the MAF. Removed and cleaned the MAF too. The car runs fine, no sputtering, jerking, loss of power, or decrease in gas mileage.
iParkHard is offline   Reply With Quote
Old 07-06-2012, 06:23 AM   #2
iParkHard
If anybody has any insight on fixing this I would really appereciate it. I haven't been able to keep this code away long enough to get the car inspected and my tags have expired.
Old 07-06-2012, 10:09 AM   #3
TxZHP04
My Ride: ESS TS2+ ZHP
P1192 Post-catalyst Fuel Trim System Bank 1
I would recommend that you start by checking bank 1 pre and post cat O2 sensor voltages to verify the sensors are working properly. Problem could be with the sensors or I suppose even the catalytic converter. I've also read there may be a TSB regarding a software issue with some 01-02 models. Might want to see if there is a software update that would fix this for you. Good luck!
Old 07-06-2012, 11:05 AM   #4
iParkHard
I didn't check voltage on the pre-cat and post-cat sensors but I did remove both post-cat sensors just to inspect them and clean them up a little. Both sensors on (bank 1 I believe it was) look brand new and the post-cat sensor on bank 1 wasn't tight at all. I called my local BMW dealer and the service advisor wouldn't tell me if there was a software update, said I would have to bring the car in. I do not want to pay the $120 diagnostic fee that they charge just to look at the car and then try and upsell me a bunch of crap.
Old 07-06-2012, 03:46 PM   #5
TxZHP04
Software updates don't have to come from the dealer. Technically you could do it yourself with some research but a competent independent BMW shop should also be able to handle this with no problem. Visual inspection of O2s is just short of worthless.
Old 07-06-2012, 07:30 PM   #6
iParkHard
Alright well now that I have access to a laptop and can do some research, seems like the reoccurring codes are P1190 and P1192. Apparently the description I was getting from the OBD reader I was using, was obviously not BMW specific.
P1190 - Pre-catalyst Fuel Trim System Bank 1
P1192 - Post-catalyst Fuel Trim System Bank 1
Going off this image I found on the pre and post cat DIY, in terms of my car, my pre-cat bank 1 is new along with the post-cat bank 2.
Which pins would I be reading to check the voltage on the sensors? Looks like there are 4 wires. And I'm guessing I would need to follow the wires to the actual connectors for the sensors at the harness and get my voltage reading from there?
Thank you for your help by the way
Old 07-06-2012, 08:24 PM   #7
jfoj
My Ride: 330CiC, M5, X5, E93
Be careful with how you interpret trouble codes, they should be used as clues, not always as absolutes.
For example your codes, assuming they are accurate indicated fuel trim problems in general terms. They happen to mention O2 sensors, but they O2 sensors may be absolutely good? You may be able to get more trouble codes/clues if you have access to a BMW specific scan tool?
If you have time and do not want to spend money, swapping O2 sensor location can confirm if there is a sensor issue if the problem follows the sensor. However, I am guessing you do not have sensor issues as you have a fuel trim out of range for bank 1, front 3 cylinders, and both O2 sensors are seeing basically the same issue??
Also suggest you check the first link below in my signature for some ideas.
Old 07-06-2012, 09:26 PM   #8
doshu
My Ride: E46 CI
Send a message via AIM to doshu
I have had the same code, couldnt figure out what it was, one day my car started very rough and rich, puttering abnormally.. Figured it was the pre cat oxygen sensor, 90$ gamble that paid off for me.. You should always change Oxygen sensors in pairs, meaning both banks.. Otherwise your car will continue to throw codes..
doshu is offline   Reply With Quote
Old 07-07-2012, 05:09 AM   #9
jfoj
If you plan on replacing O2 sensors, check BMAparts.com or Amazon.com
Old 08-05-2012, 07:35 PM   #10
iParkHard
I've replaced both pre and post cat O2 sensors. I've also replaced the lower intake boot and intake boot that connects to the MAF. Removed and cleaned the MAF too. Which removed the P1190 (pre-cat 02 sensor) code. But I'm still getting the P1192 code. If anybody has anything to add I would really appreciate it. I read one member say he found a TSB on the issue and took his car to a dealer for the ECU software upgrade. I searched for said TSB and found nothing.
http://www.***********/recall-tsb/se...m=330Ci&y=2001
Even with the code, I've never experienced a rough idle, no sputtering, jerking, loss of power, or decrease in gas mileage while driving either.
Old 08-08-2012, 09:26 PM   #11
iParkHard
Anybody have anything useful or helpful to suggest?
Old 08-12-2012, 08:54 AM   #12
iParkHard
Geez...nobody wants to help. I feel like the fat girl sitting on the side of the highway with a flat tire in the rain.
Old 08-12-2012, 12:37 PM   #13
jfoj
Do you have any sort of post Cat exhaust leak?
Do you know for sure you do not have any cracks around the post Cat O2 bung?
Do you have original exhaust?
You may need to perform a smoke test on the exhaust system to check for exhaust leaks?
Old 08-12-2012, 07:31 PM   #14
iParkHard
The exhaust is OEM, no cracks or leaks that I know of. I will see if I can get my hands on a smoke tester.
Old 11-08-2012, 04:10 PM   #15
eph6jonprice
My Ride: 2001 330Ci
Did you ever figure this out? Having a seemingly similar problem...
eph6jonprice is offline   Reply With Quote
Old 11-14-2012, 06:52 AM   #16
Scott s
My Ride: 2001 525
Have same problem; P1192 (fuel trim bank 1) on 01 525.
Did you ever figure it out ? Like most, have already changed post o2.
Any direction from here ?
Scott s is offline   Reply With Quote
Old 11-14-2012, 03:54 PM   #17
eph6jonprice
My Ride: 2001 330Ci
I seem to be hearing that this code could be due to a vacuum leak in a variety of places (my secondary air injection system vacuum hose was loose and the line from the f-connector to the fuel filter regulator was completely missing!), but I haven't been able to pinpoint it. And out of curiosity, is one of your symptoms very "jerky" driving in regards to acceleration especially when very cold? Keep me updated and I'll do the same... Hope one of us can solve this mystery soon!
PS The LENGTHY post that jfoj has after his signature is a great tool, but I don't see code P1192 mentioned in there, so I just messaged him and will let you know what he says back to me!
Old 11-14-2012, 04:16 PM   #18
Wolrab
My Ride: 330Ci MT, 545i SMG
eph6jonprice - you had another vacuum hose missing, that was supposed to connect to that cylinder for an exhaust flapper, or something like that. Did you ever attach that hose, or plug the place it was supposed to go to?
Engineers do it with a torque wrench
Wolrab is offline   Reply With Quote
Old 11-14-2012, 04:32 PM   #19
Scott s
My Ride: 2001 525
Car operates normally. The light makes no difference at all on performance. Do you know if our cats need replacing ?
Old 11-14-2012, 06:11 PM   #20
eph6jonprice
My Ride: 2001 330Ci
Yeah, haven't found an open hole to plug yet... planning to tear it down to get access behind the engine to take a good look. Cylinder hose is unplugged, but haven't found where it originally was supposed to go yet :-/
