E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 07-05-2012, 07:45 PM   #1
grubby_baker
My Ride: 2005 325xi
Unhappy Vibration under acceleration
I'm at a loss to the point that I finally signed up for the forum. Sorry for this, since I know its been discussed to death, but I am not coming up with specific symptom and a solution to what I have.
Car is a 2005 325xi auto w/ 127k miles.
So, have a vibration under accelration, especially when you get on it. If you don't and baby it, its not very noticeable. It occurs in 2nd and 3rd gear around the 2000 rpm mark. Only under load/acceleration, not while at highway or neighborhood speed. Auto transmission that I recently changed the fluid and filter. Vibration was there before. Recently rebuilt the VANOS, too. I have already replaced the front driver side axle since the boot was cracked, likely contaiminated, and 99% of the forums say this is the culprit.
After replaceing the axle and both control arms, new inner ball joints, and control arm bushings, I'm still having the issue. Didn't replace the the passenger side since it looked fine; no grease loss or cracks or radial movement, just axial as its suppose to.
I visually checked and pulled around the rear axles to see if they were alright the last time I was under the rear of the car. But I can check again.
Thoughts? Transmission? Driveshaft? Rear axles? Am I missing something?
grubby_baker is offline   Reply With Quote
Old 07-05-2012, 11:10 PM   #2
E RaK
My Ride: 2001 325xit
Try looking into the passenger's side axle again, you never know. Others to consider: TC fluid or front and rear diff oil.
It sounds almost like the car has a turbo that is starting to go. Used and abused turbo Subaru's do exactly that. [/USELESS]
E RaK is offline   Reply With Quote
Old 07-06-2012, 07:26 AM   #3
grubby_baker
My Ride: 2005 325xi
I did change the transfer case oil but didn't have a 14mm allen socket to change the diffs. I'll do that since I wanted to anyways, but diffs don't usually shudder under straight line acceleration. We'll see.
I'll also go over the passenger axle with a 'fine tooth comb' and check our dealer records. I do remember them fixing the boot or axle on one of the sides while under warranty. Maybe they didn't get it completely cleaned?
The driver side was a b!%@# to change and I'm not looking forward to the passenger side....
Old 07-06-2012, 10:59 AM   #4
SamDoe1
My Ride: 4cyl of fury
Is it a very short vibration only at 2k rpm?
Old 07-06-2012, 12:17 PM   #5
grubby_baker
My Ride: 2005 325xi
Pretty short. I drove it today and its actually more around 2400-2700 RPM. Most noticeable in 2nd and 3rd gear. We also really noticed it last weekend when we took a sweeping right from a stop sign and went up a good grade of a street. So its very dependant on load. I decided to go ahead and remove the the passenger axle and swap it with a reman like the driver side since I have the part on hand. I'll keep you all posted on if it goes away...
Old 07-06-2012, 03:21 PM   #6
grubby_baker
My Ride: 2005 325xi
Just took the car for a test drive. Still does it Definetly stops right around 2900 RPM, so I'm almost thinking its the torque converter lockup. I'm going to go get a 14mm hex tomorrow and change the diff fluids and check the rear again, but I don't think its that. I'll also check the driveshaft, but that's usually pretty constant in my experience.
Any new thoughts?
Old 07-06-2012, 07:17 PM   #7
Bobby330xi
My Ride: '02 330 XI Auto
Check your tires, wheels and balance. I know it sounds trivial, but it makes a huge difference on cars like ours. I have worked on some older VW's that were so critical that the steering wheel would shimmy at 45mph unless the alignment, etc was 100% perfect.
The problem you describe also sounds like a bad rear axle. The part where you say "noticed it last weekend when we took a sweeping right from a stop sign and went up a good grade of a street". I experience the exact same problem if I accelerate HARD while going up a corkscrew type turn. Where I live is very windy country roads with 2,000 foot elevation changes......It really puts the car through its paces and will do a very bad/violent shake/wobble from the rear end if I really get on it under the right conditions. It is so minute that I haven't gotten around to rebuilding/replacing the axles. I was able solve a more minor but constant vibration by repacking the front axles, changing all fluids and having new tires installed (balance and alignment too).
Bobby330xi is offline   Reply With Quote
Old 07-15-2012, 12:17 PM   #8
grubby_baker
My Ride: 2005 325xi
well, removed the exhaust and was able to inspect the driveshaft. The u joints near the slip joint and carrier bearing are loose/sloppy. And the carrier bearing is now wore out. So, sent an email to Driveline Services of Portland for a quote. Broke the studs on the exaust manifold to pipe flange removing the exhaust. Any suggestions on that? Heat and hammer? Drill?
Old 07-15-2012, 08:38 PM   #9
Kubica
My Ride: 2003 325xi
^try and crack the nuts in half.
Replace motor mount and TC mount if they haven't been done.
Old 07-16-2012, 12:30 AM   #10
cool breeze
My Ride: 330xi
have the same exact issue currently...
cool breeze is offline   Reply With Quote
Old 07-16-2012, 01:23 AM   #11
bmwTuner1
My Ride: Bmw, 330ci
I dont have an xi but I did have a similar problem. It occurred under load while accelerating and turned out to be the driveshaft CV joint. Worth a check. I spent a pretty penny trying to figure it out and ended up changing every bushing in the car
Photobucket
bmwTuner1 is offline   Reply With Quote
Old 07-16-2012, 10:20 PM   #12
DenverSooner
My Ride: 2014 328d xDrive
I had the same problem with mine, turned out the MAF needed cleaning. May be too simple for your issue, but it's the simple things on these cars that cause the most problems sometimes
DenverSooner is offline   Reply With Quote
Old 07-16-2012, 11:03 PM   #13
Adamo99
My Ride: 2016 Wrangler 75thAE
Mine did the exact same thing, 6spd, so not a torque converter issue. Try MAF, then coils and/or plugs.
Adamo99 is offline   Reply With Quote
Old 07-31-2012, 07:46 PM   #14
grubby_baker
My Ride: 2005 325xi
Got the new driveshaft installed. Vibration is all but gone. There is a slight vibe under very hard acceleration. I found that the output shaft of the transfer case to the front driveshaft is a bit sloppy. May be the source. But I'm happy with it for now. For the exhaust studs, I ended up cutting off the studs flush to the flange, center punched them, drilled them out to 5/16" and used stainless cap screws (allen head), 2" long. Looks decent and no exhaust leaks with new gaskets.
Old 08-01-2012, 12:19 AM   #15
winston330xi
My Ride: 2001 bmw 330xi
Why did you replace the whole driveshaft and not just the u joint and center bearing? Was it damaged and unbalanced?
winston330xi is offline   Reply With Quote
Old 08-01-2012, 10:18 AM   #16
latitude39
My Ride: 2002 325xi (163k)
Originally Posted by grubby_baker View Post
Got the new driveshaft installed. Vibration is all but gone. There is a slight vibe under very hard acceleration. I found that the output shaft of the transfer case to the front driveshaft is a bit sloppy. May be the source. ...
Do you mean that you feel some play in the transfer case when you rock the front shaft? I think that is normal. My xi also has some play but I don't think that is a problem. Worn u-joints in that shaft would be a problem.
Did you replace the flex disk with the rear drive shaft?
Bentley, p. 260-7, "Rear driveshaft, installing," has very specific instructions for aligning and preloading. ...just an idea.
latitude39 is offline   Reply With Quote
Old 08-02-2012, 07:41 PM   #17
grubby_baker
My Ride: 2005 325xi
The ujoints aren't rebuildable so your only options are to buy a brand new shaft, buy a used one, or buy a rebuilt one. I went the rebuilt route since it comes with a new carrier bearing. I guess if you have your own machine shop and way to balance....could do it yourself.
No, I agree there is slop in the transfer case as you rotate it and I expect that to be normal. But mine if you move the output shaft up or down/ side to side perpendicular to its axis, it moves like the bearing in the transfer case is wore. U joints on the front drive shaft are good.
I did not replace the guibo as it appeared fine; no tearing, cracks, flaking, etc. Could be it I guess, but its another $125... I did 'preload' teh carrier bearing by pushing it toward the rear of the car as it shows in picture in the Bentley, even though it says in the text 'push toward the front'.
Old 08-03-2012, 08:24 AM   #18
winston330xi
Thanks for the info!
Old 08-23-2012, 12:34 AM   #19
cool breeze
My Ride: 330xi
Do you mean the transmission mount? I cant seem to find anyone selling a transfer case mount...thanks
Old 08-23-2012, 09:16 AM   #20
SamDoe1
^ Yes. Xi doesn't have transmission mounts. The tranny is held up on one side by the engine and the other by the transfer case. This is Xi specific so make sure you get the right one.
Here you go. Item #2:
http://realoem.com/bmw/showparts.do?...59&hg=22&fg=10
axle, transmission, vibration
