E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Old 08-23-2012, 10:29 AM   #21
///M3AN-MIKE
My Ride: 2003 BMW M3
worn carrier bearing causes exact symptoms, replaced mine...all gone
///M3AN-MIKE is offline   Reply With Quote
Old 10-22-2012, 07:48 AM   #22
jeepo23
My Ride: 2008 X3, 6 Speed
worn carrier bearing you mean the CSB? The thing that supports the driveshaft?
If so, I replaced that and still have the vibration that the OP describd only mine is a 5speed.
jeepo23 is offline   Reply With Quote
Old 10-22-2012, 09:36 AM   #23
GSherbs
My Ride: 2002 330 xi
+1
GSherbs is offline   Reply With Quote
Old 01-03-2013, 09:46 PM   #24
latitude39
My Ride: 2002 325xi (163k)
CSB Center Support Bearing preload confusion/clarification
Originally Posted by grubby_baker View Post
... I did 'preload' the carrier bearing by pushing it toward the rear of the car as it shows in picture in the Bentley, even though it says in the text 'push toward the front'.
I don't think the CSB should be preloaded by pushing it to the rear.
I believe it is correct to do as the Bentley *text* states, "...by pushing the bearing forward 4-6mm from center."
I researched the reasoning for preloading. I found an explanation I liked (in the E39 section of bimmerfest): "...when the car is lowered, the Rear Differential moves upward ... and ... the Driveshaft moves forward a few mm."
The reasoning goes on to say that preloading would not be necessary at all if the CSB is bolted down when the car is resting on its wheels, as when a mechanic works from within a pit, over which the car was driven.
Bentley has confused things by showing an "xi" rear driveshaft without labeling it as "xi" (see DRIVESHAFTS 260-5 in Bentley, which the reader would assume to be a RWD).
The word "center" is confusing too. Center in relation to what?
From the Bentley photo, I am guessing that the oblong holes in the CSB mounting bracket would be "centered" if the bolts sat in the middle of those holes. However, the photo clearly shows the CSB pushed toward the "front" of the car (top of photo). The bolts are clearly off-center in the oblong holes.
The reasoning makes sense to me so I wanted to share it here.
OP: Sorry for this late information. I just found it today--I'm going to pull my own drive shaft very soon (for flex disc, csb, etc) and wanted to get my ducks in a row. I've gone cross-eyed with all the reading and sorting truth from fiction but I've think I've got it now.
Images are from realoem 1) 325i driveshaft, 2) 325xi driveshaft
Name:	Driveshaft for RWD from realoem.png
ID:	484510   Click image for larger version
Name:	Driveshaft for AWD xi from realoem.png
latitude39 is offline   Reply With Quote
Old 01-05-2013, 09:11 AM   #25
grubby_baker
My Ride: 2005 325xi
Thanks for the background/feedback, Latitude. The car has seem to be doing fine since I have installed the new driveshaft. We are now only experiencing a clunk from the passenger front side when going through a crappy parking lot. It might be engine mount or strut? The engine doesn't move a lot when you press on the pedal in park (like on YouTube). I'll start a new post.
grubby_baker is offline   Reply With Quote
Old 01-15-2013, 07:48 PM   #26
jeepo23
If you hear a clunk during parking lot type of driving (slow speed?) then I would assume its your swaybar link.
Had the exact same issue, fast speed I wouldn't hear a thing, slow speeds I could hear it. Turned out to be swaybar link in the front
** Removed **
Old 08-08-2013, 12:41 AM   #27
4hoods
My Ride: 02' 325xit 5sp white
Part of my issue.
Same 2nd 3rd vib. 5sp Some thudding. Need to break bolts for exhaust due to rust. Haven't had time to get drive shaft out. But have Csb and guibo hoping its nit like front shaft in video.
Just replaced front billy sport and eibach and now front end bottoms out. Rear m3 shocks and mounts in. Front cv. At my end.
4hoods is offline   Reply With Quote
Old 08-08-2013, 12:41 AM   #28
4hoods
Part of my issue.
Old 11-20-2014, 02:52 AM   #29
iceman104
My Ride: e46 325xi manual
Some advice please. I have a 2001 e46 325xi. Under acceleration in 1st and 2nd gear I have a small very small vibration right under my feet. Could this be my front drive shaft or the cv half shafts? The cv half shafts look good to me rubber looks fine? But the car has 200k miles but in great shape doesn't look to have over 50k on it. I was told that there was a small amount of play in that drive shaft where it goes into the Transfer case. But then other BMW shops said a little play is fine. My question is is it the cv half shaft or front drive shaft. Also have I hurt the transfer case yet? Will I need it rebuilt? Thanks
2001 manual 5 speed 325xi
iceman104 is offline   Reply With Quote
Old 11-20-2014, 11:43 AM   #30
jeepo23
Cv shafts usually only vibrate when going up a hill on acceleration.
I had some serious vibration issues when going 1st, 2nd and finally in 3rd it remedied itself was not felt as bad. After replacing the guibo & CSB which is also likely what could be your issue. It slightly improvement but I still felt it.
I found my transfer case bushing was shot, once i replaced that it remedied my vibration a lot. I still feel it a bit but not nearly as much as before. Take a look at yours and see what its like.
Other thing that I think might be issue is the subframe bushings.. there is 6-7 bushings back there that support the differential etc.. if any of those are loose/have play your vibrations are going to transfer over into other components.
My next job will be the 4 rear ball joints and see how that stiffens up the rear as I know one is shot for sure. The subframe bushings are quite a job to do..
** Removed **
Old 11-20-2014, 09:54 PM   #31
iceman104
Yes I know I could use some rear diff bushings that was next on my list but I guess ill check out the tc bushing. Thatnks for your helf.
Old 01-28-2015, 10:23 PM   #32
schnejerator
My Ride: 01 325i black bomb
2001 325i AT 200k. I had the 25mph vibe under moderate acceleration. Indy shop replaced the center carrier, but he noted the u joints were a "little loose", but we decided not to replace at that time. Ran super smooth for awhile!
Less than a year later the vibe is back. I'm going to finally get it in the air and inspect this weekend, but my question is what happens if the CSB weren't preloaded properly?
i'm pretty sure i promised a boat and a diamond before another bike...
liar!
KTHXBYE
schnejerator is offline   Reply With Quote
Old 02-02-2015, 02:03 PM   #33
latitude39
My CSB runs silently, without vibration, without preloading. But I did replace a notchy u-joint (the rearmost one) when I replaced the CSB. I have no issues.
I didn't preload my CSB after talking to my indy mechanic. I scribed around the CSB mount before removing and then just aligned the new CSB within the scribed area, which didn't require pushing the CSB several millimeters forward, the "preload" procedure.
Originally Posted by schnejerator View Post
Less than a year later the vibe is back. ..., but my question is what happens if the CSB weren't preloaded properly?
Old 02-02-2015, 02:06 PM   #34
jeepo23
How did you replace the u-joint?
** Removed **
Old 02-02-2015, 07:40 PM   #35
latitude39
Good question, jeepo. I was wondering how these guys at the axle shop were going to do it. Looks like they ground down the "stakes" and pushed out the old u-joint. Then they installed the new u-joint and put a little spot weld at each of the 4 ends--in place of the staking.
It runs just fine...95mph and is free of vibration. Still, I would have rather seen a "high tech" solution where the "stakes" were somehow removed, and then re-staked. But it's been running fine for 11k miles.
Old 02-04-2015, 03:06 PM   #36
modjo
My Ride: 330XI
Before check motor mounts. Than axles.
modjo is offline   Reply With Quote
Old 02-24-2015, 11:20 PM   #37
Bulsara
My Ride: 330XI
I was experiencing the same symptoms and it turned out to be the u joint. Had it replaced problem solved
Bulsara is offline   Reply With Quote
Old 02-25-2015, 08:22 AM   #38
jeepo23
Doesn't the XI have 2 driveshafts? Which one is causing this issue?
Also, did you replace the shaft or just the u-joint? And if so, how?
** Removed **
Old 02-25-2015, 10:32 AM   #39
Bulsara
My Ride: 330XI
As far as i know it's one...i just replaced the u joint drive shaft was still good.
Old 02-25-2015, 10:33 AM   #40
jeepo23
How did you replace the ujoint its not service able?
** Removed **
axle, transmission, vibration
