Old 07-05-2012, 08:20 PM   #1
edca86
My Ride: 2002 e46 330i
Airbag Light/ BST Issue
I have an 02 330i. My airbag light came on. I hooked up my BMW scanner to reset it and it says that the battery safety terminal 1, resistance low. What exactly does this mean and how can I fix this.
edca86 is offline   Reply With Quote
Old 07-05-2012, 08:41 PM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
http://realoem.com/bmw/showparts.do?...=61&fg=10&hl=6
61128387512
Old 07-05-2012, 09:01 PM   #3
edca86
I have to replace the cable? Does that mean my bst went off.
Old 07-05-2012, 09:02 PM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
If there is a low or high resistance that means the wire has an issue. I had a high warning for a door airbag so I used CRC electrical parts cleaner on the connector and it's been fine since. I'm not sure about spraying down that wire though.
Old 07-05-2012, 09:04 PM   #5
edca86
Where else can I buy the repair kit.
Old 07-05-2012, 09:08 PM   #6
edca86
Is it normal for the airbag light to go on when the BST stops working
Old 07-28-2012, 05:54 PM   #7
shall36
My Ride: 325ci
I was getting a "Resistance too high" error on mine. Yes, it triggers the airbag light. My solution was to use PA Soft to configure the SRS module so that BST1 was turned off and then disconnected the trigger wires on the BST. No more light. My BST was never activated so the cable/terminal was intact.
shall36 is offline   Reply With Quote
Old 12-03-2012, 08:43 PM   #8
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
I have read the BST is wicked expensive (like $500) and difficult to replace.
Old 12-03-2012, 08:53 PM   #9
Reddirtranch
My Ride: 2003 325xi
Yes I head that too, I had the "Battery Safety Terminal 2 Resistance too high" error, I just turned BST2 off in the equipment coding area of PA Soft, I didn't disconnect anything, the light went off and the car starts, Anyone know what the consequences of this might be ?
Reddirtranch is offline   Reply With Quote
Old 12-05-2012, 02:44 PM   #10
LeMansteve
Dunno. Might not work properly in an accident? Isn't it designed to disconnect the positive battery lead in certain types of accidents?
Old 12-05-2012, 03:31 PM   #11
choxor
My Ride: JDM
Yes. A small pyro charge in the terminal detonates in the event of an accident. It will push the cable out from the terminal. There's a collar that will keep the cable from sliding back in.
