Sponsored by BimmerWorld
Old 07-31-2012, 02:45 PM   #21
boostedisbetter
boostedisbetter's Avatar
My Ride: NiNe tHoUsAnD!!!
Offset.
Originally Posted by Green_Shine View Post
(2/14/2017)Trump, by definition is a nitwit. He has every opportunity to make sound decisions, and he is incapable. I can't see this guy lasting 4 years without resigning or being impeached.
boostedisbetter is offline   Reply With Quote
Old 07-31-2012, 02:47 PM   #22
Jets330
My Ride: scrapes alot
Originally Posted by Tampa02e46 View Post
Offset.
agreed.. finally after many different sets of rims, i found the perfect offset at 8/9+20 all around and im a sitting so perfect!! but i want more aggressive.
Jets330 is offline   Reply With Quote
Old 07-31-2012, 02:56 PM   #23
Crespo5190
My Ride: 2001 325CI
Pics?
-Tony
Crespo5190 is offline   Reply With Quote
Old 08-01-2012, 12:13 AM   #24
Jets330
Originally Posted by Crespo5190 View Post
Pics?
heres one, let me know what you think
Old 08-01-2012, 07:15 AM   #25
Crespo5190
My Ride: 2001 325CI
Looks really clean dude
-Tony
Old 08-01-2012, 12:12 PM   #26
boostedisbetter
I have the same thing, the style 5s and style 19s are both et20, mine are just square 8x17 +20, fit perfectly flush on my stock susp.
Old 08-01-2012, 12:58 PM   #27
Jets330
great to hear.. some guy offered me his style 5's, 18x8/9+20 all around, i believe. i wanted them.. but dude was like 1000 miles away!
@crespo thanks man! i appreciate it.
Old 08-01-2012, 02:23 PM   #28
boostedisbetter
Ya, I think the 18" look much better than 17", but the ride IS a little better with the 17"
Old 08-01-2012, 03:49 PM   #29
Jets330
i bet.. but after running 17's, 18's, 19's, back to 18's.. over and over.. 19's was way too big. like monster truck status in my opinion, and the 17's looked like toy car rims to me.. 18 was perfect!
Old 08-05-2012, 10:29 PM   #30
Skaper
My Ride: '85 535i & '00 323iT
Originally Posted by jdny516 View Post
its about spending loads of money haha
This.
Skaper is offline   Reply With Quote
Old 08-05-2012, 11:52 PM   #31
dinan19
My Ride: 2004 Imola ZHP
Best way to go IMHO is to find a wheel that provides a moderate to aggressive lower offset, Coilover suspension, Not springs! lol. Then go with a lower profile tire that is smaller than recomended, for ex: a 215/35/19 on a 10" rear would give you a pretty agrressive stretch. then test Fit. Hope that helps. Ive been playing with the stance thing for quite some time now. Pm me if you got some more questions.
Old 08-07-2012, 03:42 PM   #32
05graysport
My Ride: 46/325 B5/S4 39/M5
Its pretty simple, the offset of the wheels provides the amount the wheel will stick out. A lower number, ie 15mm offset wheel will stick out compared to a 45mm wheel.
Camber adjustments are only necessary for performance driving, or tucking a large wheel which is truly far from fitting normally on your vehicle, like the style 92 7 series wheels.
If you want a flush wheel, you would most likely have to roll or cut your fenders, so the wheel will not rub.
1) Proper wheel width(not too wide)
2) Proper tire size(not too wide)
3) Rolled Fenders
If you don't want to lower your vehicle, you will possibly have a more obvious gap, due to more rim and less tire in your well, and the car will look worse than stock wheels, especially on the non sport models.
Best way is to slightly lower, and do the above three.
The moment you start playing with the camber adjusts, you risk excessive tire wear, and if your just a street driver, your not going to gain much. You will be more content with slightly lowering your car properly, giving you a lower center of gravity and better handling, you wont need more.
05graysport is offline   Reply With Quote
Old 08-07-2012, 03:44 PM   #33
05graysport
True statement, however choice of tires is huge on this. Getting the cheapest 18inch tires and comparing them to 17inch michelins will obviously have much more road noise, however a good set of 18 inch tires will be loads quieter and more performance oriented than some junker 17 inch tires, or even run flats.
The new 3 series that come with Run flats are bumpy, noisy, and terrible.
Pilots have always been my favorite, though expensive, worth the expense.
Making sure your alignment is on point will help prolong these expensive tires substantially.
Old 08-14-2012, 04:17 PM   #34
iya_ke35
My Ride: AW46 ZHP
Originally Posted by Gheybe View Post
You're slightly a faggot.
iya_ke35 is offline   Reply With Quote
Old 08-14-2012, 11:27 PM   #35
PutinRUS
My Ride: 2005 E46
Bahaha.
Whats the technique on how to properly roll your fenders? Just got new 18"s and it's a bit hard to drive without rubbing like crazy. Any suggestions?
2005 325i : i<3e46 : iLLmotion : Certified Radio : JL Audio
PutinRUS is offline   Reply With Quote
Old 08-24-2012, 02:06 PM   #36
PutinRUS
My Ride: 2005 E46
Offset.
There you go! In my opinion you can achieve "the look" with oem style rims. I've seen so many people grab x5 sport rims and slamming them onto e46 and they do look stunning. Just like Tampa said, right offset and "proper" size tires should do it. ))
Old 08-24-2012, 02:43 PM   #37
Skaper
Originally Posted by PutinRUS View Post
Bahaha.
Serious? Those tires are monstrous! Purchase smaller tires.
Old 01-03-2013, 05:24 PM   #38
TF3N
My Ride: '02 325i 5spd
Bahaha.
What suspension setup do you have?
TF3N is offline   Reply With Quote
Old 01-04-2013, 04:46 AM   #39
tks
My Ride: slower than yours
Bahaha.
How does it fare on u-turns?
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
