#1 |
So I have a bad vanos
So the rebuilt motor I bought and installed a week or so ago obviously wasn't rebuilt right. After a week of driving, and having a gut feeling about it, I rediagnosed it at my work. and of course, a long laundry list of faults got pulled up. The obvious ones I knew of before hand were from my headers, I have yet to intall the O2 sim, but on top of that, I got about 6 vanos related faults from both intake and exhaust.
The diagnostic machine was pretty cool, it showed the postioning of both vanos solenoids in real time, and I found that the exhaust side is faulty and not moving at all. This whole engine replacement has been probably the biggest F up and headache I've ever dealt with and am getting tired of having one thing after another get in my way of getting my car running legit again. Anyways, I happen to have my old vanos, which I had a feeling would come in handy, so my next plan is to try to swap them out. I have read the beisan vanos seal replacement diy, and am just wondering how many of you have done it. Are there any snags involved with removing/installing a vanos? I know they are very delicate and the last thing I wanna do is destroy another motor. I plan on most likely replacing the seals in my original vanos then just swapping the whole unit over. Any input from experience would be much appreciated guys thanks again! Last edited by threetwentyfizzle; 07-07-2012 at 04:53 PM. |
#2 |
About a month ago i followed Beisan vanos seal procedures and everything came out and installed easily. i think if you can install a motor you can handle vanos seals
#3 |
Yea the motor was a nightmare, luckily I had help with it. Wiring was the biggest headache ever. I'm sure I can tackle the vanos, especially after assembling a shortblock, but i just want to know what to expect with this new project. Did you feel anything noticeable from replacing your vanos seals? Did you have to re-time your engine after removing and installing your vanos?
And has anyone experienced similar loss in power as I am from their vanos? Pick up is very slow and, I can stomp the accelerator to the ground and the car will creep until it hits 3k or so. |
#4 |
From what I know 3k is the threshhold for vanos problems, and I've read many accounts of power, and response improvement after doing the vanos seals. I'm going to be doing mine probably later this summer/early fall when I do VCG.
#5 |
i did notice better acceleration. it was worth the 60$ for the new seals. i have 175k miles and the vanos seals were plasticized and worn down. you have a double vanos. you dont have to worry about timing. beisan instructions couldnt be any more thorough.
#6 |
My Ride: '00 328i ZSP w/ 179k
It took all day for me because I was being careful, but wasn't hard to actually do. I didn't notice much of a difference in performance, but at least my car doesn't almost stall out on cold mornings anymore. Make sure you have the tools the DIY says you need. You really need them.
#7 |
Are you sure the engine does not need timing by swapping a bad vanos unit with my original unit in good working order? I have techs at work saying otherwise, which is freaking me out a little lol. I'm pretty set on replacing the vanos seals asap on my original since it is already out and couldn't be easier to do lolol. Swapping the units is another story :/
#8 |
i didnt have to do squat to the timing heres the instructions http://www.beisansystems.com/procedu..._procedure.htm
if you had a single vanos then you have to "lock" the timing http://www.beisansystems.com/procedu..._procedure.htm
#9 |
I did this last year, and it was a piece of cake. I had only owned the car for about a month and had never done any work on it, but it still only took 6 or so hours. I'm sure if you already know your way around the engine it could take much less. The scariest part of the whole thing was taking out the reverse-threaded vanos bolts. I ran "righty-tighty lefty-loosie, now the opposite" through my head about a million times before I put pressure on them, but they came right out. If you follow the instructions you won't have to touch the timing at all.
#10 |
To give you an idea of what it looks like the first picture is with the vanos still attached, and the second is after I removed it. The timing chain and cam gears are completely untouched.
#11 |
No touching timing necessary or locking the engine when doing the job.
I read the instructions multiple times until it became reflex in my mind. Saved a copy for my laptop to use when doing the job. Did rattle fix at the same time. Why not when everything is wide open and all you need extra is an impact wrench and 4" bench vise with liners. |
#12 | |
Am I going to need a new VCG when I do this? I just put a brand new gasket in with that new motor or do you guys think I'll be safe? Last edited by threetwentyfizzle; 07-07-2012 at 09:22 PM. |
#13 |
Short time on your gasket and you should be fine.
Examine when you remove and make the call then. New Permatex (O2 sensor safe) is required. |
#14 | |
+1 Do make sure you have new permatex to properly reseal your VCG, and make sure to scrape off all of the old stuff that might stick to the head. Anything that sticks to the gasket that wont peal off easily won't be a problem. Last edited by ryansteel87; 07-08-2012 at 09:13 AM. |
#15 |
Thanks guys, sorry for the delayed reply, but I will take all your advice to heart. I will be ordering the vanos seals in the next few weeks when I get some extra cash and will prob do the vanos swap in the next couple months. Hopefully the job will go quick just having to swap the 2 units out, that should shave some time off of it
#16 | |
Registered Gadfly
Engineers do it with a torque wrench
#17 |
How long did it take you to do the job? Removing the fan shroud didn't give you enough room?
#18 |
Platinum Plus Quality
Just have assorted sized needle nose pliers ready. or flat nose. i think he meant for removing the piston bolt cap.
![]() Cooling | Maintenance | Vacuum | Suspension | Costs "Be a yardstick of quality. Some people aren't used to an environment where excellence is expected." -Steve Jobs |
#19 | |
Registered Gadfly
It's that little plastic thing that you pull out to expose the left-hand threaded bolt. By the way, the Beisan instructions tell you there's a risk of breaking off those little bolts. I didn't, but I had spares anyway. Cheap insurance. Note that Beisan doesn't supply the VANOS gasket or the seal rings for the banjo bolt. You need to have them on hand.
#20 | |
