Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Thread Tools Search this Thread Rating: Thread Rating: 35 votes, 5.00 average. Display Modes
Old 07-09-2012, 01:19 PM   #1
shwagon
My Ride: 325it 5-speed
GSG 522 SD Build thread
Impulsed purchased a GSG 522 SD over the weekend. Picked it up at Dicks Sporting Goods for $329. Took it shooting the same day and all I can say is WOW I'm in love with this gun!
Ergonomics, accuracy, and value all come with this gun. Ran through 200 rounds of cheap blazer ammo without a single malfunction. I was able to lay sub 6 inch groups at 150 yards with the factory sights.
Here is a good write up on the gun:
http://www.thetruthaboutguns.com/201...ns-gsg-522-sd/
Reading around, it is essential to replace the factory screw set with an updated aftermarket kit. Im waiting on a response back from a vendor to let me know if the kit that is available (for the older GSG 5) will fit the newer 522's. Also, factory HK break down pins are a common upgrade.
Picture of the gun:
Size comparison with my AR build I did awhile back:
What I have on order:
ECHO-1 side folding stock:
SEF lower:
I would love to SBR this with a real suppressor and eventually go full auto.... (time to start applying for tax stamps )
*** Ill update this as stuff comes in ***
Originally Posted by Reedo302 View Post
What an unending cavalcade of rampant virgin Mom's-basement-dwelling douchebaggery... Wow.
My Gun Builds: AR-15, GSG-522-SD, Saiga 308
shwagon is offline   Reply With Quote
Old 07-09-2012, 01:29 PM   #2
Adam@Euro-Spec
My Ride: is slowww
Send a message via AIM to Adam@Euro-Spec
Looks like a fun range toy. I can't wait to get my.22 can. No stamp for full auto though unless you become a manufacturer and make a sample. I like the folding stock a lot.
Adam@Euro-Spec is offline   Reply With Quote
Old 07-09-2012, 01:45 PM   #3
shwagon
Yea I guess you're right, Suppressed SBR it is lol
Here is an example with the stock:
Old 07-09-2012, 02:31 PM   #4
evolved
My Ride: 2011 BMW 335d
That's a pretty cool little package for $329.....nice pickup!
Present
2014 Jeep Cherokee Trailhawk V6
Past
2011 BMW 335d, 2011 BMW 135i, 2006 Mazdaspeed 6 GT, 2000 BMW 323ci, 2003 Evolution VIII, 1995 Nissan 240sx w/ SR20DET
evolved is offline   Reply With Quote
Old 07-18-2012, 07:59 AM   #5
shwagon
Received and installed the lower and stock Monday night, See below:
Next on the list is some DIY some trigger work, it is a two stage trigger but the break is spongy.
Old 07-20-2012, 11:08 AM   #6
speedcrazy1532
My Ride: is over
Looks good. I presoanlly prefer the retractable one to the folding but I'm not upgrading anytime soon. I did check the screws on mine and they were the tiniest bit loose. I'm on the fence about guying the "kit" online though. Could probably put it together cheaper at the hardware store.
-Phil
speedcrazy1532 is offline   Reply With Quote
Old 07-20-2012, 01:29 PM   #7
shwagon
Yea the retractable stock was my second choice (Im 6'4'' and the echo 1 stock was a full size stock) I dont know if the retractable stock is full size or not.
Im sure that you can buy all the screws at a hardware store for half the price but it would take you an hour + tracking everything down. I have the light weight version so I had a few extra screws left over. I can send you the ones I have left once Im done with the bolt and carrier.
Old 07-20-2012, 03:34 PM   #8
speedcrazy1532
My Ride: is over
I'm not clear what the lightweight version looks like? You bought the $15 bag off that site I assume?
-Phil
Old 07-20-2012, 03:54 PM   #9
southpaw
My Ride: E36 M3 and E36 318ti
Holy crap that's a lot bigger than I thought!
I'm thinking about an Umarex 22lr MP5 or a Sig 522. Dunno which one yet.
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 07-20-2012, 04:51 PM   #10
shwagon
The light weight version has a plastic upper receiver (if I would have known there was a metal one available I would have been glad to pay the extra coin, like I mentioned this was an impulse buy...). Correct, its the $15 kit from rrages.com.
My buddy who has fired an MP5 says the sizing is correct. It is very ergonomic and a blast to shoot. Stated above, I would look into the non light weight version. It doesn't feel cheap by any means, i'm having trouble with the upper rail (which is metal sandwiched between the two plastic upper receiver parts) Moving a couple thousandths of an inch front to back, which I feel is unacceptable...
Old 07-23-2012, 09:34 AM   #11
speedcrazy1532
My Ride: is over
Ok, I'm not the lightweight version then. That movement would enrage me.
-Phil
Old 07-23-2012, 12:39 PM   #12
shwagon
Yea it pisses me off too. I have the movement almost completely gone by using space age ultra high strength epoxy (JB Weld...). I'm not putting a high power scope on this, just put a red dot reflex sight on that I pulled off my airsoft gun. Im going to sight it in this week. If it holds zero at 50 yards I will be happy (I also have the true HK iron sights comming in so I may just use those).
Old 07-24-2012, 02:47 PM   #13
speedcrazy1532
My Ride: is over
I have an NC Star reddot and the mounting bracket that they sell on amazon. The entire rig was 40 bucks. It's dead on at 25 yards.
-Phil
Old 09-10-2012, 01:39 PM   #14
shwagon
Did some light trigger work (lightened the trigger slide and did some cutting on the hammer strut) and installed the HK style charging handle, tube, and front sight (have an HK rear sight on the way) over the weekend.
Found a great post from a guy on how to turn the factory trigger into pretty much a target trigger (a lot less first stage pull and about 3lbs on the second). I'll attempt this after purchasing a better set of files...
***Ill post the link later, looks like ar15.com is down for some reason***
