HERE COMES 6466 POWER... Ben's HPF Stage 2.5 M3 ARRIVED! - Page 6 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Closed Thread
Old 07-27-2012, 06:46 PM   #101
dallasberry
My Ride: ///M3
Originally Posted by HPF Chris View Post
Don't be a jerk and start a rumor Kenton. I don't want to spend weeks defending unwarranted blown motor speculation from the haters of the world.
Ben's car has been plaguing us with fuel pressure issues. We are flow testing all the injectors now and monitoring fuel pressure. This has caused delays in our shop as the dyno has been tied up with this car as the guys have replaced everything related to the fuel system. It will be done shortly and we can then dyno Rico's and Noel's cars.
Chris.
I don't think he was being a jerk, I think he was just saying that it seems something bad happened because the updates have been pretty thin the last few days.
Here you go. I took three different HPF Stage 2.5 M3's running the 6776S on pump gas. The top one is Ben's with the 6466 DBB and the FIC Injectors. Notice how much smoother the curve is with the FIC's and how the powerband is lifted at every RPM. We haven't been able to run methanol in Ben's car as the injector duty cycle goes too high when the boost is increased. We will have the fuel pressure/injector issue diagnosed shortly.
Looking forward to some more numbers with the fuel system 100%. Also interested in seeing a comparison with the 6766 vs 6466.
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline
Old 07-27-2012, 08:23 PM   #102
Dreikraft
My Ride: slow m3
What an annoying PITA car!
Dreikraft is offline
Old 07-27-2012, 08:39 PM   #103
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Well figured something would get posted...glad my plan worked
Commanderwiggin is offline
Sponsored Links
Advertisement
Old 07-27-2012, 09:37 PM   #104
Ky///m3
My Ride: 1988 E30 M3
lol well played sir
2006 E46 M3 HPF stg II SOLD
1988 E30 M3 Touring Class
1995 E36 M3 I-Prepared Class
Ky///m3 is offline
Old 07-27-2012, 10:54 PM   #105
Dreikraft
My Ride: slow m3
Originally Posted by Ky///m3 View Post
lol well played sir
nah, just compounding the situation.
just chill and let them work it out.
Old 07-28-2012, 12:20 AM   #106
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
By the look of the 6466 it makes 20hp and 40torque more than mine on pump. Im at 17psi. And it looks like the 6466 is running 20psi. I wondering why the 64 allows for more psi on pump? Maybe less heat because its smaller / more efficiency?
Being3
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline
Old 07-28-2012, 01:41 AM   #107
Bdave
My Ride: M3 HPF Stage 3
Being3
Normal boost for pump gas with out any meth spray is 16/17 psi maximum.
And 23psi max for high boost(pump plus meth, race gas, race gas plus meth)...for built motors.
I would like Chris to comment why we are seeing 20psi on a pump gas tune. That is pretty unusual.
Bdave is offline
Old 07-28-2012, 07:58 AM   #108
str8dum1
My Ride: VQ38DETT
Beacuase thats the pressure it takes to make 600whp, which is fine on pump gas.
if it only took 2 psi or 30psi to make 600whp thats what he'd run as well. After all those posts/threads, it has been made clear that boost is just a the air not getting into the engine, and only has a slight correlation with power.
VQ38DETT on twin 6262 with ProEFI128
str8dum1 is offline
Old 07-28-2012, 08:33 AM   #109
InDiGlOM3
My Ride: HPF M3 stg 2.5
It mainly has to do with size of turbo. Smaller turbo means more boost to make same power. The smaller turbo pushes less cfm at same psi vs a bigger turbo.
Sent from my PG86100 using Bimmer App
InDiGlOM3 is offline
Old 07-28-2012, 01:41 PM   #110
MSpired
My Ride: HPF Stage 2.5 e46 M3
Send a message via AIM to MSpired Send a message via MSN to MSpired Send a message via Yahoo to MSpired
x2
MSpired is offline
Old 07-30-2012, 06:51 PM   #111
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
John found the initial "In Tank" Walbro pump in Ben's car to be weak. He replaced it with a brand new Walbro pump and the fuel pressure still wasn't there. He replaced it with another Walbro pump and the fuel pressure still wasn't there. He took all three Walbro pumps and tested them outside the car and found one to be borderline and the other two were very weak. He tested them against the Aeromotive "In Tank" pump and the Aeromotive kicked the Walbro's butt. I'm not sure why these three Walbro's are not like the ones in the other cars we've done but they definitely are not flowing the same. We installed the Aeromotive pump in Ben's car and they are now tuning it with methanol.
Chris.
HPF Chris is offline
Old 07-30-2012, 07:45 PM   #112
MSpired
Chris.
Would the Bosch 044's be a more reliable alternative?
MSpired is offline
Old 07-30-2012, 08:06 PM   #113
02black330ci
My Ride: spaceship
^^^ What he said.....
02black330ci is offline
Old 07-31-2012, 04:13 PM   #114
tac1
My Ride: M3
this statement doesnt make any sense. cfm is a measure of volume per time and is the same regardless of psi or turbo in this application.
tac1 is offline
Old 07-31-2012, 07:49 PM   #115
HPF Chris
Past Site Sponsor
SAE
Uncorrected
Old 07-31-2012, 07:53 PM   #116
MaverickM3
My Ride: gets badge
Nice. Doesn't seem like meth or race fuel really did much extra for it. Full power on pump.
MaverickM3 is offline
Old 07-31-2012, 08:10 PM   #117
HPF Chris
Past Site Sponsor
Pump and Race both run low boost.
Old 07-31-2012, 08:34 PM   #118
MaverickM3
My Ride: gets badge
I know. I was looking at the pump vs the race/meth. There is less than a 100hp difference. That's good thing on our side. Pumps a lot cheaper than race fuel.
:Edit: didn't realize I put "or" between race and meth in my pervious post. My bad.
Old 07-31-2012, 08:50 PM   #119
Commanderwiggin
Expected alot more from this turbo...ow well good pump power anyways.
Old 07-31-2012, 08:59 PM   #120
DOC_Race
My Ride: 03 M3
That looks like a super fun power curve for the streets! Them walbro's though....
DOC_Race is offline
Closed Thread
