Closed Thread
Old 08-03-2012, 04:48 PM   #161
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
Originally Posted by Dreikraft View Post
Filter:
4 in. Flange ID; 5.75 Base OD; 4.75 in. Top OD; Length 7 in.
Cf intake no longer on there.
You been to the track lately? Seca? Willow? I'm dying to get back!
Originally Posted by HPF Chris View Post
Flywheel bolts only back out if they aren't torqued to spec and locktite used. Are they going to fix it for you.
Chris.
Flywheel bolts are one time use.. my OS Giken used specific flywheel bolts which have been in and out of the car a few times during our prep for MFest. I'm HOPING that simply replacing them with new ones, and torquing them properly will resolve the issue.
I'm not going to bring the car to Phoenix for that. I'll likely do it here in the bay area.
MarcusLSB is offline
Old 08-04-2012, 09:43 AM   #162
Dreikraft
My Ride: slow m3
Originally Posted by MarcusLSB View Post
I haven't had time for anything personal lately.. been swamped with work.
The flywheel bolts backed out in my car a few months ago and I parked it and haven't touched it since. I'll eventually get to fixing it.
Get another e36. I've been having a blast beating on the 95 guilt free and boosting obd1 is ez
Dreikraft is offline
Old 08-15-2012, 11:31 AM   #163
HPF Kirk
Past Site Sponsor
Ben's car is finished but I wanted to share the before and after overlay with everyone as well as some final pictures we took. Those 17's on the back are all business!
HPF Kirk is offline
Old 08-15-2012, 11:41 AM   #164
dallasberry
My Ride: ///M3
He must hook good!~
Custom Turbo Build By Lab22
815whp @ 625wtq 27psi E98
dallasberry is offline
Old 08-15-2012, 12:48 PM   #165
Commanderwiggin
My Ride: 1000rwhp Turbo M3
In for finalized race numbers? And torques!
Commanderwiggin is offline
Old 08-15-2012, 01:13 PM   #166
lrinco01
My Ride: 01 Turbo M3, 10 'X5M
Send a message via Yahoo to lrinco01
DAMN!
The 6466 takes a shyt all over the old 6776s from 4250rpm and up. im sure the exhaust helps a bit too
can the SMG enjoy a light weight flywheel?
Leonel Aka " Rico"
BMWCCA # 403748
01 BMW E46 M3 / 6 SPD / Tiag / Imola
HPF Turbo....
Custom Built S54
Flex fuel
8XX rwhp
FOR SALE:
http://www.m3post.com/forums/showthread.php?t=727953
Custom Silver CF 6Speed E46 M3 sport steering wheel
http://forum.e46fanatics.com/showthread.php?t=1051908
lrinco01 is offline
Old 08-15-2012, 02:25 PM   #167
HPF Kirk
Past Site Sponsor
The original 6776 Graph I found didn't have torque on it but I will find one for the 6466. I thought Chris already posted it on here, my apologies
Originally Posted by lrinco01 View Post
DAMN!
Turbo cars like load Rico, more weight on the crank equates to more load. You would probably spool later if anything. I have spoken to a few NA and Supercharger guys with a lighweight flywheel on their SMG and have gotten mixed reviews but nothing I have seen personally. I do know of a customer down @ MFest (LSB Vert Hardtop with LSB Interior) he tracks his car and has a Spec Stage 3 Clutch and Lightweight Flywheel that I thought would fail but he's still going strong and tracks the car pretty often. He is only at about 300whp I believe though.
HPF Kirk is offline
Old 08-15-2012, 06:31 PM   #168
DOC_Race
My Ride: 03 M3
Looks great Kirk! No lazy here, 4K and she's alive (what lrinco01 said)
DOC_Race is offline
Old 08-15-2012, 06:43 PM   #169
Bdave
My Ride: M3 HPF Stage 3
I thought the spool would be way up at 3k. How hard is it to adapt a QSV to PT turbos?
Bdave is offline
Old 08-16-2012, 02:32 AM   #170
Dreikraft
My Ride: slow m3
how come those ghetto pedals are still on the car?
the turner ones came in didn't they?
Old 08-16-2012, 12:17 PM   #171
str8dum1
My Ride: VQ38DETT
you just need a divided turbine housing.
VQ38DETT on twin 6262 with ProEFI128
str8dum1 is offline
Old 09-23-2012, 09:06 PM   #172
JackEatsEmoKids
My Ride: '02 E39 530/5
Send a message via AIM to JackEatsEmoKids
Man that car is gorgeous!
- BMW Master Certified Technician -
'02 530i - PTE6262 - MegaSquirt3X - E85 fuel -
596whp/558ft-lbs @ 22psi
JackEatsEmoKids is offline
Old 09-23-2012, 11:04 PM   #173
Bdave
Ben, those 17's look so badass. I know you complained about wallowing. Did you ever get that solved with better coil overs and maybe increasing your running psi in the tires?
I know Marcus runs 17's with no complaints we have heard about.
Bdave is offline
Old 09-23-2012, 11:19 PM   #174
Dreikraft
My Ride: slow m3
i should not have put 315s on there. should have put 295 or 305 max. you need a 11.5 wheel to run 315. ill burn these up and try some 305.
so you should be fine since your apex are 11.5 right?
also, since you did so much work on your fenders... try and get 275 in front.
Old 09-23-2012, 11:58 PM   #175
Bdave
No, I have 11's. I was incredibly lucky to have those made for me. They are the exact size recommended for 315's. I checked everywhere. 11.5's might be better, not withstanding...less sidewall bulge. I hear you about your 10.5's. Sorry they did not work out. I still think they should have, and cant think of a reason why they aren't working for you.
That's not bad advice for me to get 275's up front. I may be able to do that. I will look in to it. Thanks.
But DID you ever get the mega springs you were talking about??? I have 750's in the rear which i think is adequate. You were talking 1000? as I recall. That is a lot, but should stabilize any issues you might have...I would think!
Are you loving your 64mm turbo? If it still isn't spooling as fast as you want then GET a QSV. It has been show to FIT and WORK on our cars...very well, as a matter of fact! It just takes some tweaking to get to fit. Good luck in achieving what ever your goals are.
Bdave is offline
Old 09-24-2012, 01:20 AM   #176
MarcusLSB
Bdave, I was actually unable to fit my 17's.. they didn't clear my mono block brembo's by about 1mm. I actually drove to Apex , test fit the 17's.. they fit (very close, but they fit) .. but the production wheel was actually just a hair to small compared to the prototype we sized with.
So now I run on 19x10's on R888's..
Old 09-24-2012, 02:15 AM   #177
Bdave
No way! That's terrible! Mine fit...barely. I had a the people who make the wheels for Apex, custom make me a pair of 11 inch wheels for hardly any more $$ than the 10.5's. I should say this was all arranged for me by someone else with all the contacts.
There are one or two other guys running 17's? I forget. Does anyone know?
So, Marcus, I guess you didnt want to grind on your BBK's even a little? I have heard of people doing that successfully.
I hope to report on how mine work in the street shortly.
Bdave is offline
Old 09-24-2012, 12:39 PM   #178
MarcusLSB
I would have had to grind the actual allen bolts.. the mono blocks are different then the two piece Brembo's.. I didn't want to grind that, chances are I'd need to drill it out to remove my calipers.. wasn't worth it.
Old 09-24-2012, 12:42 PM   #179
str8dum1
My Ride: VQ38DETT
too bad you couldnt have had Apex spin the barrels on a lathe to make them fit if it was that close.
str8dum1 is offline
Old 09-24-2012, 04:46 PM   #180
Bdave
No, I would have done what you did...use a different wheel. However, I am kind of surprised APEX didnt try to help you out some...exchange the wheels for a measured set? Don't they even advertise that their 17's will clear BBK's? Sorry. Too far off topic? maybe you can PM me.
Dreikraft, you will let us know when you burn up the 315's how the 295's or 305's treat you? I still think 10.5" is well with in range for 315's. You MAY have other things at play like ball joints, RTABS etc. You should NOT have a wallow just from wide tires on SLIGHTLY less than ideal width wheels.
Bdave is offline
Closed Thread
