Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 05-16-2013, 01:21 AM   #401
BmwSonora26
My Ride: Bmw325ci
*Street Edge Coilovers Review *
I got the same real rapid squeaky noise on big bumps. Everything is installed correctly I'm going to wait till it settles alil more to see what happens.
BmwSonora26 is offline   Reply With Quote
Old 05-16-2013, 07:35 AM   #402
martiwil
My Ride: 2001 325i
Lightbulb
Yeah I've had them for about a month now and the noise is still there. Can someone tell me how much the torque spec is for shock bolt that is in the trunk?
martiwil is offline   Reply With Quote
Old 05-16-2013, 08:43 AM   #403
blkonblk05
My Ride: 2005 325i
Re: *Street Edge Coilovers Review *
2 weeks after install no problems. Thanks 2 Street edge and The Suspension Source
Sent from my DROIDX using BimmerApp mobile app
blkonblk05 is offline   Reply With Quote
Old 05-16-2013, 11:27 AM   #404
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
Tightening torque for piston rod nut is 25 Nm (18 ft-lb). The rear axle shock absorber has to be installed according to the car manufacturers installation instructions.
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 05-17-2013, 06:37 AM   #405
wallyworld
My Ride: 2003 325i 4dr sedan
anybody have these for over 10k miles?
wallyworld is offline   Reply With Quote
Old 05-17-2013, 07:20 AM   #406
stevenluczynski
My Ride: Is Steel Blue
yes
stevenluczynski is offline   Reply With Quote
Old 05-17-2013, 07:26 AM   #407
wallyworld
Yea i searched and saw a guy still liked then after 15k. What about 30k though?
Old 05-17-2013, 07:28 AM   #408
stevenluczynski
I dont know of any coil overs to last that long.
Old 05-17-2013, 07:36 AM   #409
wallyworld
ok oh i wasnt sure. are coilovers more for track or lowering? or both? i dont know much but Im just looking for a sport suspension ride height thats a little firmer than my OEM non sport stock w 85k miles on them. bumpy roads in wisc
Old 05-17-2013, 07:41 AM   #410
stevenluczynski
These are meant for lowering. These will be firm and give you the adjustably of your ride hight.
Old 05-17-2013, 08:08 AM   #411
e46beater
My Ride: N63 F10
I've probably put 5k on mine and still really like them... they lower the car nicely and the handling was greatly improved compared to my sport suspension.
e46beater is offline   Reply With Quote
Old 05-20-2013, 11:17 AM   #412
Sales@TSS
Sales@TSS's Avatar
These can last for many miles after 15k. I have about 30k on my KW suspensions kit still pushing strong. It all varies on your driving habits and what not.
Fresno, CA 93727
1-888-230-1288
Old 05-21-2013, 12:52 AM   #413
BmwSonora26
My Ride: Bmw325ci
Found out the problem it was the wheel hitting the spring I needed spacers. So, i put these bad boys on with lower offsets!
No noise anymore rides great!
Old 05-21-2013, 03:00 PM   #414
blkonblk05
My Ride: 2005 325i
When i I installed my rears i flipped the spring so the adjuster would ne at the bottom. Seemed easier to access. I have no ill effects. Is there a problem with running the rears this way?
Old 05-21-2013, 04:15 PM   #415
Sales@TSS
Sales@TSS's Avatar
Please install to our specs. This will prevent any noises or premature ware.
Fresno, CA 93727
1-888-230-1288
Old 05-21-2013, 04:24 PM   #416
blkonblk05
My Ride: 2005 325i
Thumbs Up
I will be flipping it tomorrow when i get my wheels installed. Just wondering considering I had no install instructions. Would be nice... would have never known if Ididnt seefollow this post. . However I have not had any issues sqeaks or nocking since install. Great product
Old 05-22-2013, 08:59 AM   #417
Sales@TSS
Sales@TSS's Avatar
We have a $100 off coupon code. BIMMERFEST2013. Expires May 31st.
Fresno, CA 93727
1-888-230-1288
Old 05-27-2013, 02:30 PM   #418
sam35e79
My Ride: 00 323i
Did anyone have to run spacers and extended lugs with these?
sam35e79 is offline   Reply With Quote
Old 05-27-2013, 02:55 PM   #419
blkonblk05
My Ride: 2005 325i
Nope
Old 05-27-2013, 03:36 PM   #420
trj
My Ride: 325Ci
I am running 10mm at front and 15mm spacers at the rears with extended bolts.
You should be good with the wheels of 40 offset in the front.
I had style 44s which are 47 offset, hence needed at least 5mm spacers. I went with 10mm ECS spacers with extended bolts.
The rears dont require spacers, but I put 15mm for the looks.
So, yes for the spacers up front if you are running anything more than 40 offset wheels up front. Else the tires will rub the springs.
Rate This Thread
