Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 07-08-2013, 09:15 AM   #501
SilverMayn
My Ride: ZHP,325i,e36 m3
Originally Posted by aarondb4 View Post
Hey kris, question for you. I have my fronts all the way down I have the backs all the way up and I am still lower in the back than the front. Attached is a pic of my rear adjuster. Bout as high as I want to go with it and I am still lower in the back. Are my springs sagging or is this normal?Attachment 514862
i dont know about the front but in the rear on my e36 m3 I had the same issue. Turned out to be worn out trailing arm bushings gave my rear supsension too much vertical travel
SilverMayn is offline   Reply With Quote
Old 07-08-2013, 10:12 AM   #502
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
If you are experiencing a front/rear noise visit this thread I created that shows you how to fix http://forum.e46fanatics.com/showthr...204&highlight=
If you are experiencing height issues in the front PLEASE make sure you have the coilover seated in the "hub" correctly. If not seated correctly it will result in a like factory height. The hub can be a real PITA to get apart.
If you are experiencing height issues in the rear please provide me the part numbers from your perch and spring. Also fill this out http://www.s45inc.com/files/Coilover-Measurements.pdf
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 07-09-2013, 01:36 PM   #503
Sedan Hussein
My Ride: e46
What is going to be the Bimmerfest price?
Sedan Hussein is offline   Reply With Quote
Old 07-09-2013, 01:39 PM   #504
Sales@TSS
Sales@TSS's Avatar
That price has expired.
Fresno, CA 93727
1-888-230-1288
Old 07-09-2013, 01:41 PM   #505
aarondb4
My Ride: 2002 BMW 330CI Vert
Originally Posted by E46runsPCB View Post
Check to be sure your front assembly is seated properly in the clamp at the bottom of the front coils. There's a little guide on the front coil assembly that should slide into the crack of the clamp which when inserted properly will let the coil rest about 3/4" further into the clamp. That's my first guess..
The front is definitely installed correctly and it did drop a significant amount from stock. It is as low as it was meant to be based on other pics. The rear is just much lower. If I adjust it to full drop I could hide the entire tire and just have rim showing. I'll fill out the measurement form and get it to Kris to see if it is normal or not.
2002 BMW 330CI Convertible
aarondb4 is offline   Reply With Quote
Old 07-09-2013, 01:43 PM   #506
trj
My Ride: 325Ci
The fronts are seated right. I rechecked everything when I did the FSMs last week.
Strut nut torqued with the tool with allen wrench to 37lbs.
Fronts almost all the way low, one thread remaining on the perch.
Rears almost all the way up, one thread remaining on the perch.
Still getting that creaking noise and grinding when I go over the bumps.
Nothing touching anywhere.
Will check the part numbers and heights this weekend.
Old 07-09-2013, 01:54 PM   #507
aarondb4
Did you reuse the stock washer on top of the coil over? Did you torque the pinch bolt to 60lbs? Did you install new top mounts? Did you torque the top mounts to 25lbs?
Just some things to check. Mine are completely noise free, just have the lower in the back issue.
Old 07-09-2013, 02:19 PM   #508
Sedan Hussein
My Ride: e46
Oh, sorry. I thought you mentioned there would be a sale at bimmerfest
Old 07-09-2013, 02:59 PM   #509
CharlzO
My Ride: 2000 328ci
I'll finally have all the parts I need tomorrow. Only waiting on the rear shock mounts and reinforcement plates at this point. Got a few extras I didn't need (like new rear lower spring pads, since it's the uppers that get used instead, etc) but can't hurt to have on hand I guess. I did get new washers and everything, pretty much new hardware for everything, so I'm going to try to loosely (not torqued yet) assemble the struts and mounts tomorrow morning, and assuming FedEx comes when they did today (bright and effin early), I'll get the rears together too. Then it's just pull the old out, put the new in on Sunday. I'd do it in the driveway, but I don't have a torque wrench, and from everything I've seen so far, things need to be pretty darn close to avoid clunks and whatnot. And I don't want to clunk! I'll try to get some pictures along the way though, for two reasons: If I'm wrong, the pictures will help me figure out what to correct, and if I do it RIGHT, I'll have pictures of it so people can see lol. Tomorrow is way too far away...
CharlzO is offline   Reply With Quote
Old 07-09-2013, 09:04 PM   #510
trj
My Ride: 325Ci
*Street Edge Coilovers Review *
Yes to all the questions.
I did the whole process twice. Once during the installation and once last week when I changed the front mounts.
The noise I am getting is from the driver side front strut area.
Old 07-09-2013, 09:11 PM   #511
CharlzO
My Ride: 2000 328ci
I may have missed it previously, but it's not something else in the suspension that just seems to have woken up noisy after the install? sway bar bushings, CABs, end links or anything else that might have loosened up? Just trying to think of what else might be there that could cause any noises.
Old 07-10-2013, 12:06 AM   #512
trj
My Ride: 325Ci
FCABs and RTABs are new.
The only thing I can think of right now is the endlinks. I used the new ones that came with the coil overs and re checked their tightness last week. All the joints and nuts are tightened to the spec.
The issue is the sound only comes when there is load on the suspension; like turning the wheels or going over the bumps.
If I were able to recreate the noise while on the lift, I would be able to point out where the issue might be.
Well, going to check everything again. Its getting really irritating having to change things one at a time and the issue not getting resolved.
Old 07-10-2013, 12:32 AM   #513
fth001
My Ride: 325i, e36m3, s13
Try checking the sway bar bushings and mounts also. I have run across a couple cars that have actually cracked the mounts right off the frame rail, granted they were running huge bars but its worth a look.
fth001 is offline   Reply With Quote
Old 07-10-2013, 12:45 AM   #514
Hawaiian821
My Ride: Vert,G37, f350Harley
Been on my car for a little over 500 miles and still love them. I'm thinking of getting a set for the wagon! Kris, can you PM me a price for a 2000 323i wagon? Thanks!!
ID:	515685Click image for larger version
ID:	515686Click image for larger version
Hawaiian821 is offline   Reply With Quote
Old 07-10-2013, 01:29 AM   #515
kaldE46
My Ride: 2001 325i
Still riding strong. Here's a rolling shotClick image for larger version
kaldE46 is offline   Reply With Quote
Old 07-10-2013, 02:48 AM   #516
Goo7dson
My Ride: s65
I've had sex that left me looking worse.
Goo7dson is offline   Reply With Quote
Old 07-10-2013, 09:40 AM   #517
Sedan Hussein
My Ride: e46
Originally Posted by kaldE46 View Post
Still riding strong. Here's a rolling shotAttachment 515688
nice stance
Old 07-10-2013, 10:05 AM   #518
aarondb4
I had a creaking/clunking in the front driver side as well, the top but on the coil was not right enough. I couldn't get a torque wrench on it so I just got it good and tight and the noise went away.
Only other think I can think of is did you get reinforcement plates for the mounts? Also is your wheel far enough away from the shock? I didn't use spacers and I am really close, but I remember others saying they were rubbing a bit on bumps.
Old 07-10-2013, 11:05 AM   #519
trj
My Ride: 325Ci
I didnt use the re-inforcement plates for the front mounts. I am going to install strut bar soon. So i figured i didnt need the plates. No deformation of strut towers on mine. So i am good on that. I did get the strut nut torqued both the times.
I have 10mm ecs spacers up front and 15mm in the rear. So its not rubbing.
Just not able to see what is causing the noise.
I am going to dismantle everything put it together this weekend. Ordering the sway bar bushings now. Sucks to keep on adding parts one at a time and still issue not getting fixed.
Old 07-11-2013, 04:22 PM   #520
CharlzO
My Ride: 2000 328ci
Assuming the weather holds off in the morning, going to be putting the front end together on mine tomorrow. Turns out my step-brother is a bum, and planned to do other stuff on Sunday instead of letting me toy in the garage. So, I've put everything together, had him torque the top nuts onto the mounts for me (since he had the tools for it, I took them up and made him go do them on his lunch break lol). So tomorrow is install day for me. If all goes well, it'll be the front end, plus CABs while I'm under there. If time left, I'll do my fuel filter and oil change, but I mainly want the front buttoned up. I'll probably also adjust the rears down a little more, now that they've had time to settle in. Will definitely take some pictures when I get it done!
Rate This Thread
