Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 07-18-2013, 11:19 AM   #541
aarondb4
My Ride: 2002 BMW 330CI Vert
Yep I used the kit links as well. The driver side link fought me a bit as it appeared to short but I managed to get it on there and it is working fine, no noises or issues.
2002 BMW 330CI Convertible
aarondb4 is offline   Reply With Quote
Old 07-18-2013, 11:26 AM   #542
CharlzO
My Ride: 2000 328ci
I ended up jacking up the assembly slightly, to line up the links when I was putting them on. I bolted the bottom on, then jacked it up slowly until the top slid in place.
CharlzO is offline   Reply With Quote
Old 07-18-2013, 03:05 PM   #543
fth001
My Ride: 325i, e36m3, s13
Originally Posted by stevenluczynski View Post
The kit already comes with the proper shorter end links, I dont see why you would ever need the impala ones.
I used the impala ones to keep my bar eyelet at 0 degrees, they are about an inch shorter and way beefier (1/4" vs 1/2"). If your not going all the way down then yes its not really needed. Set your car on the ground and take a look at the angle of your bar to see what I mean. The eyelet part of the bar should be as parallel as possible to ensure zero chance of binding on full compression and rebound. Everyones car will be different as we all ride at different heights so it would be impossible to have a non-adjustable link to be a perfect fit on an adjustable coilover. Will it really matter on a street car? Meh, not really, just what I chose to do. Your car, your choice, happy modding guys.
fth001 is offline   Reply With Quote
Old 07-18-2013, 04:13 PM   #544
trj
My Ride: 325Ci
Which impala endlinks did you use?
I dont see anything that is bad on my suspension and still having creaks and clunks. Only thing I can suspect is the endlinks. I would like to try the impala endlinks and see if it solves the issue.
I think that'd be the cheapest in hit and trial method.
New FCABs, New FSMs, all new bolts, no play in ball joints, nothing play on sway bar bushings. I dont know where the creak is coming from anymore.
I am almost all the way low on these coils at front and almost all the way high on the rear.
I not a fan of the raked look, but these coils lower the rear a lot more than I expected and car looked like it was squatting.
Old 07-18-2013, 05:08 PM   #545
fth001
I believe its for a 2007 Impala rear endlink.
Old 07-18-2013, 06:04 PM   #546
BBBoy323i
My Ride: 01' 325ci
Thanks guys, I think I will install the ones that come with the kit. I'm only planning to go low for car shows, daily duty will be lowered just a bit.
BBBoy323i is offline   Reply With Quote
Old 07-18-2013, 10:25 PM   #547
trj
My Ride: 325Ci
Hey old fren, the kit will lower the car pretty good but not SO low to the ground.
Hopefully I can find what the hell is making noise on the driver's side, otherwise I am quite satisfied.
Old 07-18-2013, 10:27 PM   #548
trj
My Ride: 325Ci
You mean, Impala rear end links for the fronts on e46 with Street edge coil overs?
Just want to make sure before I go and buy them.
Will check everything this weekend. Damn it has been a weekend chore for me to raise the car, remove the wheels and check everything.
Old 07-18-2013, 11:51 PM   #549
fth001
That is correct.
Old 07-19-2013, 12:33 AM   #550
BBBoy323i
My Ride: 01' 325ci
Thats good. And yeah I know how low it can go, fth001 was kind enough to let me check out his car over here.
Old 07-19-2013, 01:08 AM   #551
fth001
Just ordered a set yesterday thanks again Kris!
Good luck with the install and let me know if you need a hand. You should go all the way down, those splitters of yours would make nice manapua scrapers.(inside hawaiian joke)
Old 07-19-2013, 04:09 AM   #552
BBBoy323i
My Ride: 01' 325ci
Haha they probably would and thanks man!
Old 07-19-2013, 08:14 AM   #553
trj
My Ride: 325Ci
That is correct.
Thanks. I will check the whole suspension once again tomorrow or on sunday and see if I can find the 2007 impala rear end links at the local auto parts store.
Old 07-19-2013, 05:33 PM   #554
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
What noise are you experiencing in the front?
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 07-19-2013, 10:26 PM   #555
E46inthe206
My Ride: 2003 BMW 330Ci
Front maxed out, back can go down about another inch, 19" wheels.
Attachment 517042
Attachment 517043
Looks sick! Lower than I expected. Mine have just been sitting around.. time to put them to use!
Do you know what size tires those are?
E46inthe206 is offline   Reply With Quote
Old 07-20-2013, 09:59 AM   #556
ashgotti
My Ride: 2000 323i
Hi Kris,
I've read all of this thread and am very close to ordering but just want to know if it will improve handling for autocross? I just started and have stock suspension on my 2000 323i. Anything will be stiffer, but are the Street Edge capable of holding up and an improvement for autocross?
Thanks.
ashgotti is offline   Reply With Quote
Old 07-20-2013, 04:05 PM   #557
trj
My Ride: 325Ci
Kris, we had been communicating via PMs and as per your recommendation I changed the FSMs, but still I am getting the noise.
This is the noise I get when turning the steering wheels and I feel a definite clunk in the drivers side going over the inconsistencies on the road like speed bumps or pot holes.
Checked and re-checked everything many times.
I will try to check it again tomorrow and send you the measurements and part numbers on the springs and perches on the rear. I do have the height issue.
Old 07-21-2013, 03:04 PM   #558
bad91teg
My Ride: 2000 323i
is there any upcoming sales on these ? bout ready to pick these up.
bad91teg is offline   Reply With Quote
Old 07-21-2013, 05:22 PM   #559
CharlzO
My Ride: 2000 328ci
Just to toss up one of my more recent pics (I'm on 17s btw, which is why they don't look as low as some others, and it's only a week old, might be more settling to be had? Fronts are all the way down, rears have about an inch left to go).
Old 07-24-2013, 08:43 AM   #560
Sedan Hussein
My Ride: e46
+1, any chance of a group-buy price? I'm sure a lot of guys would jump ship.
Sedan Hussein is offline   Reply With Quote
Rate This Thread
