Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 08-19-2012, 02:38 AM   #41
Arpee
My Ride: E30 M3/ 323ci
I hope this will go on SALE again...
Arpee is offline   Reply With Quote
Old 08-20-2012, 11:21 AM   #42
dylan.
My Ride: 135i
Me too!!
dylan. is offline   Reply With Quote
Old 08-20-2012, 01:16 PM   #43
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
I will do $50 off til next weekend. Must PM, email or call in order.
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 08-20-2012, 01:22 PM   #44
stevenluczynski
My Ride: Is Steel Blue
Originally Posted by stevenluczynski View Post
I'll do that when I get home, thanks
So i checked the nuts and everything is tight, I can recreate the sound by raising my car, garbing the spring and pushing it back and forth
stevenluczynski is offline   Reply With Quote
Old 08-20-2012, 01:25 PM   #45
Sales@TSS
Sales@TSS's Avatar
Have you checked the condition of your factory top mount? If you can grab and move the spring sounds like the top hat is loose.
Fresno, CA 93727
1-888-230-1288
Old 08-20-2012, 01:28 PM   #46
stevenluczynski
top hats were changed about 20k miles ago when I had lowering springs, so they are in good condition. The spring just seems like it can move around too much up top
Old 08-20-2012, 01:29 PM   #47
Sales@TSS
Sales@TSS's Avatar
Let me toss around some ideas with John. I am wondering since you have it "slammed" that is causing the slack.
Fresno, CA 93727
1-888-230-1288
Old 08-20-2012, 01:33 PM   #48
Sales@TSS
Sales@TSS's Avatar
You can move the spring back and forth while the car is on jack stands or on ground? Also did you use the provided sway end links?
Fresno, CA 93727
1-888-230-1288
Old 08-20-2012, 01:36 PM   #49
stevenluczynski
Jack stands, and yes I did
Old 08-20-2012, 01:41 PM   #50
Sales@TSS
Sales@TSS's Avatar
The reason you can move the spring around while on jack stands is because there was not a lot of tension. Is there a way you can send us a video? It will help us better understand the issue.
Fresno, CA 93727
1-888-230-1288
Old 08-20-2012, 01:47 PM   #51
stevenluczynski
ya ill get it to you within a few days
Old 08-20-2012, 01:49 PM   #52
Sales@TSS
Sales@TSS's Avatar
Thanks for helping us figure out what may be causing the issue with your car. It isn't too common we get someone who is so cooperative lol.
Fresno, CA 93727
1-888-230-1288
Old 08-27-2012, 06:32 PM   #53
AaronAlexander
My Ride: 2001 330ci
Any possible way i could get stiffer springs in the rear from you guys? this is how my car sits with the coilovers on. About 3000 miles put on them so far
AaronAlexander is offline   Reply With Quote
Old 08-27-2012, 06:56 PM   #54
Sales@TSS
Sales@TSS's Avatar
How much stiffer are you wanting? Not something I would like to do considering we find the car rides smooth with our selected springs. But I can try to meet your needs. We are not like KW/ST with various springs. We have a limited springs for the applications we have.
Fresno, CA 93727
1-888-230-1288
Old 09-05-2012, 01:50 AM   #55
dreyo27
My Ride: 2001 325ci
I actually have brand new tophats OEM, the endlinks you provided, new FCAB OEM. Also to fight the spring chatter i put plastic zipties on the springs in key locations, and most of it is gone... there is still a little bit left...
So about 2-3 months later and 2 track days I feel the shocks going soft, when i am doing 80-90 (in Mexico obviously) the car starts to feel like its hopping... most people wont notice that because i use my 330cic with new OEM shocks installed about a year ago... which is a lot less rebound when driving on the same road...
dreyo27 is offline   Reply With Quote
Old 09-05-2012, 01:53 AM   #56
dreyo27
My Ride: 2001 325ci
both as far as the ride-height, the front adjuster is 12 threads from the bottom, back is set so that the adjuster is flush on the top with the portion that had the threads on it.
Old 09-05-2012, 02:01 AM   #57
dreyo27
My Ride: 2001 325ci
Here are a couple of pictures i took a month ago, where you can see both the small and the big spring's wear marks due to contact... let me know if you guys come up with something...
don't mind the nicks in the springs, those are from the spring compressor tool
Name:	2012-08-08 12.22.36.jpg
ID:	467662   Click image for larger version
Name:	2012-08-08 12.22.56.jpg
ID:	467663   Click image for larger version
Name:	2012-08-08 12.23.04.jpg
ID:	467664   Click image for larger version
Name:	2012-08-08 12.23.11.jpg
Old 09-05-2012, 12:47 PM   #58
Sales@TSS
Sales@TSS's Avatar
Do you have the measurement in inches of your drop?
Fresno, CA 93727
1-888-230-1288
Old 09-09-2012, 08:00 PM   #59
fth001
My Ride: 325i, e36m3, s13
So we just finished installing a Street Edge coilover set and immediately got front end spring chatter. Very noticeable when turning and during compression and rebound. Took everything apart and noticed it was missing the all-so-important washers between the top spring perch and top hat. Without them the bearing in the top hat wasn't making contact with the upper perch causing the spring to bind and turn every time the wheel was turned. Now with everything in place the top hat turns freely on the coilover when fully assembled and no more noise. We had the new kid working on this, just goes to show you that if you want it done right you gotta do it yourself. Hope that helps you guys with the spring noise.
fth001 is offline   Reply With Quote
Old 09-09-2012, 08:09 PM   #60
stevenluczynski
I installed them myself and used the washer, hmm. Im getting tired of the noise
Rate This Thread
