Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 08-29-2013, 01:20 AM   #601
BmwSonora26
My Ride: Bmw325ci
*Street Edge Coilovers Review *
Originally Posted by Linx View Post
Looks good. Few questions though. Is that at the lowest setting? Any issues so far? Though I know these are not for the track but how do they perform compared to stock sport suspension?
No, it's not the lowest setting I'm 7 clicks up from all day way down in the rear and in the front I'm 1 click up. No issues so far(crossed fingers) and they perform quite well compared to sport suspension it's more on the firm side in which I prefer! If your looking to DD your car this is the best bang for the buck but, if your looking to track I suggest you go with kw's.
BmwSonora26 is offline   Reply With Quote
Old 09-05-2013, 01:01 PM   #602
EazyM3
My Ride: 98 M3
Any idea how low these coilovers are on an e36? Anyone have pictures of an e36 set to the lowest ride height?
EazyM3 is offline   Reply With Quote
Old 09-05-2013, 03:42 PM   #603
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
Lowering Range:
Front ***150; 1.6"-3.1"
Rear ***150; 0.8"-2.0"
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 09-08-2013, 10:39 PM   #604
Smonkbmw
My Ride: 01 330i, 05 duc 999
To those with "spring pop" replace the washer under the front upper mount and above the spring perch (a lil grease never hurts either).
Rode these on my e46 touring for 6 months. Rides so much better than factory sport suspension.
Just sold the touring and bought a coupe, time for another set!
Smonkbmw is offline   Reply With Quote
Old 09-09-2013, 01:16 AM   #605
Linx
My Ride: '02 BMW 325iT
I have a Touring and been considering these. Do you have any pix? How hard was the install?
Linx is offline   Reply With Quote
Old 09-09-2013, 04:14 PM   #606
Smonkbmw
http://forum.e46fanatics.com/showthread.php?t=981705
Hardest part is taking apart the interior in the rear. After reading this thread over I'm not sure i got the fronts all the way seated as I still had a lot of room in the front. In the pic below the fronts were all the way down.
Old 09-21-2013, 11:05 PM   #607
Linh
My Ride: BMW
Repost
Linh is offline   Reply With Quote
Old 09-21-2013, 11:07 PM   #608
Linh
My Ride: BMW
Curious, how does this suspension ride compared to a stock ZHP?
Anyone with updates or regrets on their purchase?
Old 09-22-2013, 11:02 AM   #609
CharlzO
My Ride: 2000 328ci
I just passed the 5k mile mark on mine, still feel as solid as the day I put them on. No regrets at all. I might regret my decision to be lower come snowfall, but hey, I have a wrench for that. lol.
CharlzO is offline   Reply With Quote
Old 09-23-2013, 01:51 PM   #610
Sales@TSS
Sales@TSS's Avatar
Seems like everything is going well for our customers.
Fresno, CA 93727
1-888-230-1288
Old 09-26-2013, 10:52 PM   #611
iSpeak.King
My Ride: 2004 325ci vert
Almost well I seem to have everything functioning at 90% but I am having issues with the front tires as there is the knocking sound on tight turns and in reverse with the steering wheel completely turned. If I'm correct, it seems that the perch and/or spring rubs against the weight clamped on the wheel. My concern is that it's still to close to the wheel even if I remove the weight and that it may rub against it as it did to the tires on my stock wheels (pictures 4, black mark on spring from tire rub). Here are the specs:
Body Type: 325ci convertible
Front Tires: 235/35/19
Offset: 40
Spacers: None
Perch Adjustment: 1/2 inch from the bottom
Possible Solutions:
1) adding a spacer, if so would a 5mm be ideal? (Refer to picture A)
2) error in strut installation, there is this needle on the strut which I have laying on top of the wheel clamp. Is this the proper way of installing it. (Refer to picture B)
Everyone has been of a great help in this forum and once I have this up and running I'll be glad to post final pics with details about the ride. Thanks!
ID:	528493   Click image for larger version
ID:	528494   Click image for larger version
ID:	528495   Click image for larger version
iSpeak.King is offline   Reply With Quote
Old 09-26-2013, 10:57 PM   #612
stevenluczynski
My Ride: Is Steel Blue
Offset: 40
Spacers: None
Possible Solutions:
Ya you need spacers, id go with a 5 mm or larger
stevenluczynski is offline   Reply With Quote
Old 09-26-2013, 10:59 PM   #613
stevenluczynski
Offset: 40
Spacers: None
Possible Solutions:
and your struts are not seated all the way, that needle you speak of has to go trough the steering knuckle.
Old 09-27-2013, 12:54 AM   #614
iSpeak.King
Thanks for the info! Does it go midway in the knuckle and then you bolt it tight? Correct me if I'm wrong but that should leave about 1.5 to 2 inches of the strut showing in the bottom.
Old 09-27-2013, 02:13 AM   #615
fth001
My Ride: 325i, e36m3, s13
Thats right. Loosen the pinch bolt and rotate the strut until the pin drops into that gap that the bolt pinches. It wont go all the way through but it will bottom out in the knuckle about half way through.
fth001 is offline   Reply With Quote
Old 09-30-2013, 11:35 AM   #616
Sales@TSS
Sales@TSS's Avatar
I love how you guys help one another
Fresno, CA 93727
1-888-230-1288
Old 10-01-2013, 10:13 PM   #617
Rezist09
My Ride: 325i sedan
When's the next sale discount! Looking into getting this before eatin a turkey
Rezist09 is offline   Reply With Quote
Old 10-01-2013, 10:34 PM   #618
Sales@TSS
Sales@TSS's Avatar
Now....$399.99
Fresno, CA 93727
1-888-230-1288
Old 10-01-2013, 10:59 PM   #619
Rezist09
My Ride: 325i sedan
399 plus shipping right
Old 10-02-2013, 10:16 AM   #620
Sales@TSS
Sales@TSS's Avatar
That is correct
Fresno, CA 93727
1-888-230-1288
Rate This Thread
