Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 01-15-2014, 12:05 PM   #681
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
Here is the low down on camber plates......You can use camber plates if your little heart desires lol. Just be aware when you are going for the "hella flush" look with crazy camber you do run the risk of damaging the rod of the shock. This is for ANY brand coilover.
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 01-19-2014, 05:45 PM   #682
Rezist09
My Ride: 325i sedan
Bump just gonna order this better then raceland just gotta order top hats and time to install.
Rezist09 is offline   Reply With Quote
Old 01-19-2014, 05:48 PM   #683
DevilDoc87
My Ride: 328Ci 323Ci
I am having an issue with one of my front struts. You can hear a noise at low speeds when going over bumps and if you push down on the car you can make the same sound appear. It almost sounds like metal on metal rubbing but I am not sure.
-Justin-
DevilDoc87 is offline   Reply With Quote
Old 01-19-2014, 05:58 PM   #684
FrodoTBaggin
My Ride: 2004 325i
If you put in New mounts, you probably forgot to use the washer between the mount and the strut.
FrodoTBaggin is offline   Reply With Quote
Old 01-19-2014, 06:26 PM   #685
DevilDoc87
I had a shop do it and they put the washer in with the new mounts.
-Justin-
Old 01-19-2014, 06:29 PM   #686
FrodoTBaggin
My Ride: 2004 325i
Hmm....You sure? Did you watch them install? Is the helper spring on top? How low did you go?
Old 01-19-2014, 07:09 PM   #687
DevilDoc87
Ya 100% sure I was there when they had all the parts out and told them what had to be reused. Helper spring is on top like it came in the box and it is one full turn from being as low as it will go.
-Justin-
Old 01-19-2014, 07:40 PM   #688
FrodoTBaggin
My Ride: 2004 325i
How are your control arm bushings?
Old 01-19-2014, 07:40 PM   #689
FrodoTBaggin
My Ride: 2004 325i
Dp
Old 01-19-2014, 07:43 PM   #690
DevilDoc87
Control arms and bushing are brand new.
-Justin-
Old 01-19-2014, 07:44 PM   #691
FrodoTBaggin
My Ride: 2004 325i
Son of a....
Old 01-19-2014, 07:52 PM   #692
DevilDoc87
Looks like im gonna have to rent a lift on base now to check this issue out. Hopefully its something simple.
-Justin-
Old 01-19-2014, 08:21 PM   #693
Sales@TSS
Sales@TSS's Avatar
Can you give me your CENTER of wheel hub to TOP of fender measurements for both front and rear? I am not blaming your install but 4 out of 5 problems customer experience are related to install. And most are done by shops.
Fresno, CA 93727
1-888-230-1288
Old 01-19-2014, 08:22 PM   #694
FrodoTBaggin
My Ride: 2004 325i
Did you have to run spacers?
Old 01-19-2014, 08:28 PM   #695
DevilDoc87
I will get that too you when I can dont have access to a tape measure right now.
No I am not running spacers at all.
-Justin-
Old 01-19-2014, 08:30 PM   #696
FrodoTBaggin
My Ride: 2004 325i
What are your offsets on your wheels? Size? What size are the tires?
Old 01-19-2014, 08:31 PM   #697
FrodoTBaggin
My Ride: 2004 325i
I'll bet you're rubbing.
Old 01-20-2014, 12:09 AM   #698
DevilDoc87
I couldn't tell you the offsets of them but they arent rubbing I am running a 235 in the front. Its only the drivers side strut that is making noise passenger side is perfectly fine.
-Justin-
Old 01-20-2014, 12:42 PM   #699
Sales@TSS
Sales@TSS's Avatar
That is what I am thinking.
Fresno, CA 93727
1-888-230-1288
Old 01-20-2014, 01:33 PM   #700
DevilDoc87
There is no rubbing at all.
-Justin-
Rate This Thread
