Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 4.71 average.
Old 02-24-2014, 11:59 AM   #761
Guest021715
Account closed.
Originally Posted by sm240 View Post
Go with a taller tire next time, that'll be in my future to balance the look
Well, his front tire profile is 35 instead of the correct 40.
But under no circumstances would I recommend changing tire profile just to alter appearance if it was already correct.
Old 02-24-2014, 01:00 PM   #762
Sales@TSS
Sales@TSS's Avatar
My Ride: 1995 BMW E36 325i
By changing or removing any of the components you will void your warranty.
Sales @ The Suspension Source
www.thesuspensionsource.com
5654 E. Westover #112
Fresno, CA 93727
1-888-230-1288
Sales@TSS is offline   Reply With Quote
Old 02-24-2014, 01:17 PM   #763
sm240
My Ride: 95 240sx
Ugh tire size will not affect anything other than appearance in this case. A 235/40 would fit slot better that a 225/35, that's a pretty skinny tire
sm240 is offline   Reply With Quote
Old 02-24-2014, 02:10 PM   #764
Linx
My Ride: '02 BMW 325iT
Im running 245/40/19 in the front and still got 3 threads before I hit lowest setting.
Linx is offline   Reply With Quote
Old 02-24-2014, 05:46 PM   #765
Guest021715
Account closed.
That is what is being said.
In any way 225/40/18 is the correct tire size for the front, he has the wrong size right off the bat.
Old 02-24-2014, 06:10 PM   #766
Guest021715
Account closed.
Rightfully so.
Anyone who intends to use a shorter helper spring should be mindful of this fact.
By running a strut/shock within a range it is not designed for, you will significantly shorten its lifespan.
Old 02-25-2014, 10:39 AM   #767
E46inthe206
My Ride: 2003 BMW 330Ci
Does anyone else think my front should be lower? @Kris, what do you think? Does that height look right to you?
E46inthe206 is offline   Reply With Quote
Old 02-25-2014, 11:48 AM   #768
Sales@TSS
Sales@TSS's Avatar
Can I have your HUB to fender measurements?
Fresno, CA 93727
1-888-230-1288
Old 02-25-2014, 12:16 PM   #769
sm240
My Ride: 95 240sx
Height is right, you need taller tires. Then you'll prob rub lol
Old 02-25-2014, 12:55 PM   #770
E46inthe206
So it'll sit lower on a 40 tire up front?
Old 02-25-2014, 03:44 PM   #771
cruizer97
My Ride: E46 M3
I have 2 kits that were returned and rebuilt.
E46 M3 $250
E46 non M $250
Only one of each. First come first served. Comes with a full 2 year warranty.
this a long shot but is the M3 set still available? PM if so, thanks.
-Ray
cruizer97 is offline   Reply With Quote
Old 02-25-2014, 04:01 PM   #772
Linx
The car isn't gonna sit lower. It's just that the 40 is a taller profile tire so it'll fill up the gap giving the appearance of the car being lower. Scroll up and look at my touring. I have 40 in the front with about 3 more threads before I'm at lowest setting and 30 in the back with only about a quarter way down on the collar. Also check that nipple on the strut that slides inbetween the pinch mount. I know for sure I had them in during install but after my left side wasn't sitting as low as my right, I rechecked and sure enough the left side nipple was sitting on top of the pinch mount. The way your picture is looking is exactly how mine was riding on that side.
Old 02-25-2014, 04:09 PM   #773
Sales@TSS
Sales@TSS's Avatar
Good try but LOOOOOOONG gone lol
Fresno, CA 93727
1-888-230-1288
Old 02-25-2014, 04:30 PM   #774
Mccomasg09
My Ride: 2001 Hellrot 330Ci
@Kris - So after some research I noticed that you have a front spring rate of 345lbs and a progressive rear spring rate, which is the same as the ST Coilovers! Since you sell both and recommend both all the time, where would you say the difference in quality lies from your product to theirs to justify double the price? Shocks, Springs Materials, etc.?
Mccomasg09 is offline   Reply With Quote
Old 02-25-2014, 04:49 PM   #775
Sales@TSS
Sales@TSS's Avatar
Here ya go:
Warranty 5 years w/ ST
Made in Germany w/ ST
Ride quality is better w/ST
ST can handle more beating like Autocrossing
Those are things I can honestly speak to. Overall ST is a solid kit with a great following of thousands of customers.
Fresno, CA 93727
1-888-230-1288
Old 02-25-2014, 06:48 PM   #776
Guest021715
Account closed.
Better valving, better warranty, better paint coating on the springs with ST.
Street Edge are basically a budget version of ST's (which are already a budget version of KW V1's)
I own kits from both companies.
Still curious why my order from The Suspension Source came with a signed commercial invoice from KW. Kris, I asked you the affiliation between your company and KW over the phone. What is it?
Old 02-25-2014, 06:55 PM   #777
Sales@TSS
Sales@TSS's Avatar
Sent ya an email about it Alex. My shipper was running behind and dropped off his shipments at KW to ship out since he was already there picking up our stock order. Their pickup is later in evening when ours is around 330pm. He was thinking of how to make sure the international orders went out without causing any delays.
Fresno, CA 93727
1-888-230-1288
Old 03-03-2014, 12:04 AM   #778
Linh
My Ride: BMW
Question
What suspension hardware is everyone buying with their coil over install?
Reinforcement plates?
Front and rear top hats?
Paper gaskets?
I'm planning to do the rear trailing arm bushing too, and need to know what other necessary parts needs replacing. My car has 150k on original suspension.
Linh is offline   Reply With Quote
Old 03-03-2014, 12:23 AM   #779
Linx
Originally Posted by Linh View Post
Question
Paper gaskets?
I just bought the front and rear top hats and new gaskets for the back. I didn't do the reinforcement plates. It never was mentioned that it was necessary so I didn't bother. Plus, someone correct me if I'm wrong, but don't think you can mount a strut tower bar if you put the reinforcement plate on.
Old 03-03-2014, 12:37 AM   #780
R3APER
My Ride: E46 E90
I've tried to search and haven't found a kit for the xi. Do you guys have anything in the works or something that I can't seem to find?
R3APER is offline   Reply With Quote
Rate This Thread
