Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 269 votes, 4.89 average. Display Modes
Old 07-12-2012, 04:30 AM   #21
Vigilante
My Ride: 320i - 2.2 L - 170hp
Send a message via MSN to Vigilante
Do not use the ones supplied by Meyle.
As always I will follow every advise but I just want to ask why not to use the Meyle nuts that came with the HD control arm?
Had this job planned for Monday including HD bushings, front springs & struts and rear shocks but it seems I have to pros pone the job till I have the right OE nuts I could try the Stealer but they barely have E46 stuff in stock anymore...
320i Executive Sedan | E46_AV11 | ZF5HP19 S-t | M54B22 | 170hp 210Nm | 09/2000 | 171k | 32.9 MPG
Maintenance
Re-surfaced CH | VC+VCG | CAM/VANOS timing | IMG | NGK-i | BAT+ALT | O2's | GM5 | WP WPP | PSP | DISA | TB ICV MAF | CCV | CAI | OFHG | FP | FF | A/C | FSU | AUC | WSS | BL BD BP | Mango | JFOJ | SB TP IP | springs | Shocks | tires | ASC+ | alignment | E.Flush | Castrol SAF-XJ 75W140 | ZF LGF5 ATF Flush | FCA+FCAB | Struts
Vigilante is offline   Reply With Quote
Old 07-12-2012, 04:53 AM   #22
ApolloTheGod
My Ride: E92, E46, E36, Caddy
Originally Posted by Vadiminator View Post
I have this clunk/pop when I driving over a bump or dip. What exactly is the issue here...?
I know its not anything else on the suspension because we replaced all the key parts. What you are describing sounds exactly like my car.
Is it from the rear? Diff bushings? Perhaps from the center, maybe the cross member for tranny or bad tranny mounts?
ApolloTheGod is offline   Reply With Quote
Old 07-12-2012, 10:01 AM   #23
My Ride: Lexus
There's been reports of them breaking. Plus they look extremely poor next to the Genuine BMW nuts which are seemingly military grade. Your call.
Make sure your endlinks are tightened REALLY good.
Old 07-12-2012, 10:03 AM   #24
My Ride: Lexus
The Meyle nuts thing is probably overblown but still I would just play it safe and go Genuine on those.
Old 07-12-2012, 10:20 AM   #25
Vigilante
Genuine's on the way
Maintenance
Old 07-12-2012, 10:22 AM   #26
My Ride: Lexus
Good man. Compare them to your Meyle ones and tell me the Genuines don't feel and look that much better.
Last thing you want to think about are your nuts when going around a corner at 80 mph
Old 07-12-2012, 12:01 PM   #27
Vadiminator
My Ride: 02 325i
It is definitely from the front, I have been trying to pin-point where exactly but it is tough. I will try taking a look at the end-links and make sure they are tightened. Thanks!
Vadiminator is offline   Reply With Quote
Old 07-13-2012, 06:57 PM   #28
falcon1209
My Ride: 2000 BMW 328ci
Love.
Thanks a bunch!
EDIT: Not sure if mounts of various types are included in the scope of this article. Shock/Strut mounts, Trans mounts, engine mounts, etc.
Just a thought.
falcon1209 is offline   Reply With Quote
Old 07-13-2012, 08:35 PM   #29
My Ride: Lexus
Just suspension.
Old 07-13-2012, 08:37 PM   #30
choxor
My Ride: JDM
Why isn't this stickied yet?!?!!?
Hey Jake, you should totally like sticky this thing for maximum stickage.
Old 07-13-2012, 09:07 PM   #31
My Ride: Lexus
If I request one more sticky from Jake, he's going to fully deeeak out. I know it.
Old 07-13-2012, 11:59 PM   #32
Sunspot
My Ride: Sleektop 330ci
Sticky stick stick.
IMG_1l54hu2
Sunspot is offline   Reply With Quote
Old 07-15-2012, 01:23 PM   #33
ImolaSix
My Ride: '02 330Ci M-sport
Good stuff, Mango!
Perfect timing as I'm in dire need of a complete suspension refresh.
ImolaSix is offline   Reply With Quote
Old 07-15-2012, 04:34 PM   #34
Sweetness
My Ride: '01 325i
The reinforcement bolts only need replaced once. I took the hit and spent $20 just on bolts while doing the oil sender. When I remove the plate again I will re-use the bolts. They look like normal bolts and have the same density. Yea sure they are designed to shear in the even of a head on collision, but I think they will just do fine. Not to mention they will probably get fvked anyways. If it's 3 years from now after I take it off again, then I'll prob replace the bolts. Not every freaking job.
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 07-15-2012, 07:43 PM   #35
My Ride: Lexus
They're not normal bolts. They are torque to yield bolts and for accuracy and strength, they should be replaced every time that plate comes off. Don't d!ck around with the front structure of your car by trying to save $8. (order them online next time you order oil filters, etc. and they're much cheaper)
Old 07-15-2012, 08:00 PM   #36
Paulscustom
My Ride: 323i
I just replaced my suspension with the stage II kit from pelican parts along with rotors and pads. The kit came with all new hardware also replaced the brake sensors and new Myle JD control arms and bushings. Sense I gave the car to my wife I went mostly OE. Drove over 300 miles today with it. Drives like new.
Paulscustom is offline   Reply With Quote
Old 07-24-2012, 11:38 AM   #37
awszach
My Ride: 2001 BMW 325xit5mt
I went to get an allingment today and he said he couldn't because the rear bushing front control arm (I know it's in the rear not front) needs to be replaced. Can someone explain it briefly to me and what exactly it's called, he didn't do a great job and I want to understand it a little before I continue ordering it and replacing. Thanks in advance
awszach is offline   Reply With Quote
Old 07-24-2012, 11:48 AM   #38
My Ride: Lexus
you talking about the front control arm bushing right? it's called the front control arm bushing. what didn't he do a great job at? need more info.
Old 07-24-2012, 12:02 PM   #39
ryannel2003
My Ride: '04 Cadillac Deville
I have to do a lot of what is listed here on mine. Going to stick to the control arms and the bushings, tie rods, sway bar links & bushings, RTAB's, and the rear diff mount bushing (clunks when put into reverse). I'm going to do the shocks and struts next year as they aren't too bad. For what I have listed does that all sound right? Anything else I should add while I'm doing those particular things?
ryannel2003 is offline   Reply With Quote
Old 07-24-2012, 12:29 PM   #40
328redleather
My Ride: 328ci white/red
this will come in handy. thanks
2000 328ci alpine white on tannin red leather
328redleather is offline   Reply With Quote
