Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 269 votes, 4.89 average. Display Modes
Old 07-01-2014, 09:01 PM   #161
AdaRi
My Ride: 2004 325i e46 sedan
Fantastic write up! I will definitely be using this! I just noticed my bushings are worn so it's time for the upgrades!
I love having good excuses to upgrade!
Work in Progress.
2004 325i Sedan GrauGruen Metallic
Beyern 19x9.5 front, 19x10.5 rear/ Clear LED side markers/ Black Roundels/ Matte black kidney grilles/ Smoked m3 tails/ Clear Corners/ Front LED turn signals
Intake manifold/ Coolant Hard Line DIY
AdaRi is offline   Reply With Quote
Old 10-08-2014, 10:43 PM   #162
TotheMountains!
My Ride: 2001 330xi
Fantastic thread
Thanks Mango! Are you even still around? Your start of this thread has been a great help to thousands of readers.
But . . . where is the description of Stage 3? I've got a 330xi with 195,000 miles. I've done much of the front, but the car handles like crap. So now, to the rear suspension refresh. I'm going to time this to do it at the same time as a new clutch, which is badly needed. So I'll have the exhaust out, the driveshaft out, and since I want to do RTABs and the differential bushings, I might as well drop the subframe, right? I cannot find any personal DIY of the subframe anywhwere.
I get that I need lots of special presses for all of the rear bushings, I hope to borrow/rent them. But if I look at the ECS package:
http://www.ecstuning.com/BMW-E46-330...its/ES2219643/
I'm going to be dropping the subframe to do the full refresh. So, where's the write-up? Someone must have done this, right?
My 330xi with 195.000 miles is so played out that I've burned up a good set of tires in 20,000 miles. This car needs a lot of work, and if I'm going to spend weeks on my back I'm going to need all the resources I can get.
TotheMountains! is offline   Reply With Quote
Old 10-09-2014, 09:45 AM   #163
JTripper
My Ride: 3dirtyci
Can you get your hands on a bentley manual? That would be your best friend. And not just for the suspension, the whole car!
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
1st Gen. AC Schnitzer Strut Bar, M3 Face, Gunmetal VMR V710FF 18x8.5/9.5 , AEM Logger & longtube CAI, H&R Sport Cup Springs and Front Struts, Koni Rears, Reinforced Towers, Int. Trim Wrapped, Custom FX-R Retrofit , 3k Fogs, Frosted WeissLichts, 8 Track Player with Dolby.
JTripper is offline   Reply With Quote
Old 10-09-2014, 10:54 AM   #164
TotheMountains!
My Ride: 2001 330xi
Oh yeah, I have the Bentley manual. The entire description of this process is about as long as: "Remove rear subframe carrier. Press out worn bushings. Reassembly is the reverse of disassembly." I learn a lot more from people who post their experiences here.
Old 10-09-2014, 05:15 PM   #165
JTripper
My Ride: 3dirtyci
I must agree with you about learning here. I suppose they started from the position you're in. Good luck with thw repairs n stuff. Have you checked bavauto blog? Otto may have a youtube vid
@BMWorNADA
BMWCCA
///MPIREBOYZ#239
Old 10-12-2014, 03:51 PM   #166
Razz617
My Ride: 2004 330Ci
Thanks for the info Mango.
I too, am hearing the CLUNK when going over bumps. I'll do a check point on your list & try to do a DIY.
I LOVE my car & the way it rides. just every now & then, I get that roughness on bumps & small holes.
Razz617 is offline   Reply With Quote
Old 10-12-2014, 08:47 PM   #167
DEADF15H
My Ride: 2001 325i Auto
There are usually a couple of those tools for rent, from forum members, in the classified section.
Sent with BimmerApp using a Note 2, probably from the driver's seat of a BMW
DEADF15H is offline   Reply With Quote
Old 11-04-2014, 12:43 AM   #168
TrentW
My Ride: 89 325is, 05 325xiT
You list the Sport rear shocks up to 9/01 33521095913 and Non-Sport as 33521096366. You have the numbers switched. Also, Tourings use different rear shocks, Sport-33526750784. Non-Sport, 33526750783. M Technik rear shocks are NLA.
No one has mentioned the Z4 M front CABs. They are solid rubber w/an offset for increased steering feel and quicker turn-in (hoping it will help the vague steering common to the E46). They are just like the E30 M3 CABs I run on my 1989 325is, just have to set toe at 0-1/16. Half the cost of Meyle HD also. Anyone running these and can comment?
http://www.ecstuning.com/Search/Site...38575/ES48907/
TrentW is offline   Reply With Quote
Old 11-04-2014, 01:02 AM   #169
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I run those on my Bimmer, they're the Sh1t. If you search my name & that part you'll see I try to keep people informed...
http://forum.e46fanatics.com/showpos...8&postcount=17
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 11-04-2014, 02:06 AM   #170
TrentW
Thanks Rob.
Old 11-05-2014, 11:30 PM   #171
TrentW
Originally Posted by Grande D View Post
The 04/01-09/01 dates have conflicting information, so if your car was built in that range you'll need to examine your original parts closely.
Sport struts/shocks up to 04/01 were Sachs Advantage. These are much better quality struts than the sport struts from 04/01, which were Sachs Super Touring, their base damper. Sachs Advantage apparently carry a lifetime warranty and go toe to toe with Bilstein HDs, while Super Touring struts carry no such warranty and compare with the Bilstein Touring Class struts.
I question this info. The 9/01 and later prod date cars (330 cars from 4/01 on) actually had stiffer bushings, springs and shocks. Stiffer coupling between steering column and rack, and quicker steering ratio lock-to-lock; 3 vs previous 3.4.
Since the Sachs Advantage has a slightly higher damping rate I'm pretty certain these were paired with the later stiffer springs. I'll check the rear shocks on my Touring w/Sport Package tomorrow and report back.
Old 12-01-2014, 06:50 PM   #172
zander271
My Ride: 6spd ZHP/5sp XI
Originally Posted by Mango View Post
Strut mount (2 per car), part number 31336752735
Bump stop (2 per car), part number 31306757046
Again, these are for stock replacements. Some people go aftermarket as the firmer shocks tend to eat at and destroy the stock design as it is too flimsy. I went with Rogue Engineering.
Strut tower reinforcement plates (VITAL--must install!) two per car, part number 51717036781
I'm planning on using going this route with my suspension
http://www.ecstuning.com/BMW-E46-330...oni/ES1876720/
I'm not seeing aftermarket Strut mount on Rogues site...should I use M3 mounts? Also because I am lowering the car do I nee a shorter bump stop?
Slowly peeling though the parts list to see were and what I am going to buy..car has 130k on it now. More questions to come I'm sure.
Old 12-09-2014, 01:29 PM   #173
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
How much does it cost to do every stage of the refresh? Estimating?
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 12-23-2014, 10:45 AM   #174
Avgas
My Ride: E46 330i Touring
This is really really useful. Appreciate the time and effort and detail you have put in to this.
Due to a knackered back (blown and missing disc) I can't do the work myself, but I know a man who can! This will be invaluable so cheers.
V best and happy Christmas, Chris
Avgas is offline   Reply With Quote
Old 01-16-2015, 09:23 AM   #175
chisha100
My Ride: 2001 BMW 330Ci
Excellent thread!
chisha100 is offline   Reply With Quote
Old 01-16-2015, 09:51 AM   #176
Karlose_M3
My Ride: BMW 318i M43 engine
Send a message via MSN to Karlose_M3
Originally Posted by chisha100 View Post
Excellent thread!
Hey Chisha100 how about we start a sub-club and hunt for Zed bimmer owners here?
Mission: Smoke other automobiles esp Japanese cars
Karlose_M3 is offline   Reply With Quote
Old 01-16-2015, 09:53 AM   #177
chisha100
Hey Karlose! That sounds like a great idea! PM me if you're in Zed man. Nice to meet you.
Old 03-21-2015, 10:22 AM   #178
Razz617
My Ride: 2004 330Ci
Just got my suspension parts!!!! It is STILL SNOWING here in Boston!!! Ground is covered in fresh coat of snow. I'll start the installation with my son as weather permits.
Old 03-26-2015, 05:41 PM   #179
Astheros
My Ride: BMW
Just bought the following:
Meyle control arms
Meyle CABs
Meyle Tierod Assembly both
Meyle Swaybar Endlinks
Meyle RTABS
I am not doing subframe bushings...at least not now as I have already spent quite a lot on this car. Anything else I should do? 125k
Will order swaybar front/rear bushings in a couple months.
Also getting some Broadway Static coilovers which come w tophats and shockmounts.
Seems like itll pretty much all be done. Opinions from the experts?
Once done...all I need is fsr/voltage reg/battery and fuel pump to be completely done w maintenance for the next 4 years or so
Evil men will triumph so long as good men stand by and do nothing.
Astheros is offline   Reply With Quote
Old 09-06-2015, 12:44 PM   #180
XPGLD
My Ride: 05' 330i, 75' C20
Legendary write-up Mango, thank you.
XPGLD is offline   Reply With Quote
