Old 07-11-2012, 08:57 PM   #1
GotVANOS?
My Ride: 2003 325xi Touring
EGR symptoms?
Recently my 325 has developed some odd symptoms. When Iím cruising and I let off the throttle to coast then re-apply the throttle, it will hesitate for a couple seconds (2 or 3) between 1200rpm and 2000rpm. While accelerating from a stop it doesnít hesitate at all, only does it when Iím coasting. Itís a small problem but itís annoying as FK! At first I was just getting codes for bank 1 and 2 running lean and I just thought it was the o2s going bad but obviously not. Possibly the EGR? DISA wouldnít have anything to do with it? What do you guys think?
Shes not your average grocery getter. This 2.5L of fury doesnt mess around.
E21<E30>E36>E46>E90>F30
5TFUUU, If one more person tells me to sell my car and buy an ///M Im going to light their family on fire and make them watch.
*****BUY MY 330XI AUTO TRANS AND PARTS. CHEAP!!!******
GotVANOS? is offline   Reply With Quote
Old 07-11-2012, 10:35 PM   #2
jfoj
My Ride: 330CiC, M5, X5
Suggest you check the first link below in my signature.
It will cover most reasons you will be getting lean codes.
Also keep in mind the car usually shuts the fuel injectors off in coast mode as I recall, so there may at times be a slight hesitation when getting back on the throttle.
ICV may also be an item to consider, but you really need to work through the basics and get any and all vacuum leaks resolved.
The DISA could contribute as well.
disa valve, egr, egr valve, m54, vanos
