Mishimoto oil cooler - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-12-2012, 05:11 PM   #1
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Anyone has this on an m54 engine? Haven't found anyone doing this
Plan to install behind the kidney grills and getting the cap for the filter housing gasket as so:
Old 07-12-2012, 05:44 PM   #2
Iceman00
Banned User
My Ride: E90 6MT
Let us know how it works out.
Old 07-12-2012, 06:46 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
Looks like you just mount the cooler and run the lines to the filter cap and that's it
Old 07-12-2012, 06:48 PM   #4
Steven747
My Ride: 05 330ci
i would love this for my street driven car. i also wanna get that coolant snitch device. jake have you looked into that? not a bad idea .. better safe than sorry and its cheap ..
Old 07-12-2012, 06:56 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
Which device? Link me
Old 07-12-2012, 07:19 PM   #6
Steven747
My Ride: 05 330ci
http://zhpregistry.net/Tech/CoolantSnitch.aspx
Old 07-13-2012, 08:58 AM   #7
Steven747
My Ride: 05 330ci
solid thoughts?
Old 07-13-2012, 10:19 PM   #8
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I thought using the oil filter housing is a no-no to feed and return oil for coolers. I would imagine that you'd want a thermostat for a street driven car.
Here's a picture of my setup which uses the VAC billet housing and an inline filter. The filter element is reusable and filters pretty well. Easy to clean and not messy as long as you wait for the lines to drain...just need to let the car sit awhile.
If I didn't have the twinscrew compressor snout to deal with, I would have went with an S54 oil filter housing, spacer, p/s pump bracket, banjo bolt and -10AN line adaptor setup.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 07-13-2012, 10:32 PM   #9
B_Cyrus
Banned User
My Ride: Malfouf
you don't need a pump to run it?
B_Cyrus is offline   Reply With Quote
Old 07-13-2012, 10:39 PM   #10
bigjae1976
bigjae1976's Avatar
Yes...your oil pump runs it.
Old 07-14-2012, 06:32 AM   #11
Jackcat559
My Ride: 2003 530
Originally Posted by Steven747 View Post
ooo, I like that. Never heard of that anny device before. Might have to look into it later on
Jackcat559 is offline   Reply With Quote
Old 07-14-2012, 07:06 AM   #12
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Jake, why do I think you're preparing your car for the track...or maybe runway?
BigJae, I have to say that that's an impressive setup you have, and from your sig, I guess you do track, but I also have to say that I'd think that for all but a 12-hr. race, it wouldn't be necessary at all...and even then...our cars drive out of the factory showroom right onto the Autobahn at 100 mph (only during break-in, then 128) without an oil cooler.
I don't know which has a greater heat capacity, oil or coolant, but I'd worry a bit about adding any restriction to the radiator, which already has a condenser blocking it. I'm sure that's mostly just me and not a serious issue...if oil does have a greater heat capacity, maybe that restriction is more than compensated for with additional oil cooling.
So Jake, when you going to leverage your position to set up an E46 Fanatics runway drag race day?
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 07-14-2012, 09:57 AM   #13
jared_wiesner
My Ride: 1999 328i (M54b30)
The only thing with the autobahn is that the cars are not near redline as they speed along it. If they are at higher revs nearer to redline, they are going so fast that massive amounts of cooling air is making sure nothing overheats. But, when tracking, redline is always a hair away and at much lower speeds. The more revs, the more friction, the more heat.
jared_wiesner is offline   Reply With Quote
Old 07-14-2012, 12:38 PM   #14
Steven747
My Ride: 05 330ci
very good thing to have i would think so you would never need to look at the coolant temp needle again
Old 09-17-2012, 12:12 PM   #15
darksideracer69
My Ride: 01 325ci
did you ever pick that up jake?
IMAG02051
Old 09-22-2012, 07:09 PM   #16
acpstunts
My Ride: E46 330ci / E53 X5
Im about too order one, been looking all over for an oil cooler solution. Cant believe i didnt see this until now.
acpstunts is offline   Reply With Quote
Old 09-22-2012, 07:16 PM   #17
darksideracer69
My Ride: 01 325ci
^keep up posted on fitment, I would like to see how it all works out.
Sent from my Dell Streak
IMAG02051
Old 09-23-2012, 11:53 AM   #18
Solidjake
Zero. Leaks.
Solidjake's Avatar
Darkside, I haven't. In for acp's review.
