Engine & Performance
Old 07-13-2012, 11:27 AM   #1
clintjg
My Ride: '02 M Coupe
S54 Plasma Coil Packs
Set of 6 Ignition Solutions Plasma Coil Packs. Used for about 15k miles. According to RealOem these should fit any S54, N54, N62, N73, and apparently some Rolls Royce engines.
In perfect working order when I pulled them. Had to switch them out when I went to stand alone. These coil packs plus denso iridium plugs really woke my S54 up from 5k rpm to redline. It pulled noticeably stronger with no adverse side effects anywhere in the rev range.
These things are $1200 new retail, $1100 if you can find a sale.
I'll sell them for $700 shipped anywhere in the lower 48.
I'm not here all that often but there's a similar thread on BF.C where I usually post.
2002 Alpine White w/ Black 368 ()
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/Cerametallic M5 Clutch, SS Shift Knob
clintjg is offline   Reply With Quote
Old 07-16-2012, 11:08 AM   #2
clintjg
Obro
coil, coils, ignition, spark
