Old 07-14-2012, 04:09 AM   #1
Ewil
My Ride: E46 325i
Swap eletric power steering for hydraulic ?
Hi
Does anyone know if it's somehow possible to swap electric power steering for hydraulic ? I have 325i with electric power steering and while the steering is still good, it's nowhere near as good as on my previous 320d with hydraulic power steering. Wouldn't just simple power steering motor replacement (the one right behind dashboard) be enough ? I mean, there is power steering fluid reseirvoir (ATF oil only). I'm no mechanic, so I'm not really sure how the power steering works, but if it's doable for some reasonable money, I'd go for it.
Thanks.
Ewil is offline   Reply With Quote
Old 10-01-2012, 02:28 AM   #2
Beamer Creamer
My Ride: 2005 bmw m3
Just drive it for what it is. Especially if your no mechanic
Beamer Creamer is offline   Reply With Quote
Old 10-02-2012, 01:47 AM   #3
TerraPhantm
My Ride: M3 & ZHP
As far as I'm aware, all E46s came with hydraulic power steering. Did you retrofit the Z4 electric system or something?
Old 10-05-2012, 12:50 AM   #4
sunnyjay
My Ride: 01 330i
He's from overseas, maybe they got something special?
sunnyjay is offline   Reply With Quote
Old 10-05-2012, 01:57 AM   #5
Beamer Creamer
Is there no way to trick the input signals to do whatever you are looking for? What exactly is your issue with it? Is it because of diesel had heavier steering?
Old 03-20-2013, 05:42 AM   #6
Ewil
My Ride: E46 325i
Sorry for late reply, I forgot about this thread. The "problem" is that my car is equipped with electrical power steering like all modern BMWs except M cars, so the road feel is nowhere as good as with hydraulic, so I was just wondering if it's possible to swap it.
Old 03-21-2013, 06:14 AM   #7
paraklas
My Ride: ESS TS2 320ci
ALL BMW E46 come with hydraulic power steering, including M3 E46.
Old 03-21-2013, 06:53 AM   #8
Ewil
My Ride: E46 325i
Not if you have servotronic, then it's eletrical. It's that kind of steering that is light at low speeds and stiff at high speeds, but the wheel feedback is not that great, especially in center position.
Old 03-21-2013, 07:22 AM   #9
paraklas
never seen such an option, good luck with the swap, be sure to post some pics of the electric steering
