Old 07-14-2012, 08:49 AM   #1
Deeps1987
My Ride: 2003 (FL)320D Sports
BMW E46 Xenon not working
I have a BMW E46 320D Sport 2003 Facelift.
A few years ago I bought a set of OEM Xenon headlights to replace the stock headlights (non-xenon) and fitted them myself.
Last night, I got a warning on the dash saying the left side (passenger) headlight was not working. Turned the lights on and off and the car on and off, no difference.
Checked the lights and the lefthand side was not working but the righthand side (drivers) was working.
I changed the bulbs around to make sure it wasn't a faulty bulb, but it worked in the drivers side headlight, so both bulbs work fine.
I have been doing some research and it seems to be a faulty ballast or ignitor? Is there a way to check which one and a place to get my parts fixed or a replacement part at non BMW dealership prices.
Would buying a second hand xenon headlight for parts be cheaper than buying a ballast/ignitor be cheaper?
Thanks guys
Deeps1987 is offline   Reply With Quote
Old 07-14-2012, 09:18 AM   #2
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Keep running the lights until a light goes out again. Then we can determine if it is something else rather than the bulbs.
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 08-10-2012, 06:19 PM   #3
caleb6
My Ride: 2005 330XI
That doesn't even make any sense.
I'm trying to research an issue with one of my xenon lights and came across this. What does this even mean? Provides no help whatsoever, none.
OP - go to realoem.com and look up your part number (AL vs ZKW) and search in google. I found a ballast and ignitor for under $190 total.
caleb6 is offline   Reply With Quote
