E46 Xi Forum
Old 07-14-2012, 12:13 PM   #1
cliff101
My Ride: 02 330xi w/sport pkg
Exclamation Diamond Key won't RE-program HELP !
I did the replace you key fob batt. DIY and as far as having the car start it works, but programming it is where it is not. Like the DIY said I turn the key to position 2 (where all the dash lights come on) and within 1 second I remove it and then press and hold the unlock button and press the lock button 3 times. What happens is all the doors lock but only the driver door lock comes back up, all the others remained locked, I pressed the buttons on the key to see if it took and nothing happens, I do the same procedure over and over and the same thing happens, the doors lock but only the driver door unlocks, the programming does't take. Does anyone have any idea what might be causing this ?
cliff101 is offline   Reply With Quote
Old 07-14-2012, 09:32 PM   #2
Bobby330xi
My Ride: '02 330 XI Auto
Yes. It is either the door lock actuator or the GM5.
There is a module for the central door locking system in our cars called the "GM5". It has the relays for the central locking system inside. These relays are very overrated Tyco relays that easily burn out if your door lock actuator is starting to go bad.
I had mine burn out the first 2 weeks I owned my car I ended up replacing the whole module after finding out the board is double-sided epoxy and coated in a thick layer of silicone. Its very hard to clean and solder to, and I solder for a living. I suggest getting yours repaired by this guy: http://www.bmwgm5.com/GM5_Repair_Service.htm
Also make sure your door lock actuators are working fine or it can blow out the GM5 relays again. It actually shorted out my module and caused the wipers to go crazy high speed and all kinds of functions to not work properly until I replaced the whole unit.
Bobby330xi is offline   Reply With Quote
Old 07-15-2012, 09:50 AM   #3
cliff101
ok so you changed the gm5, did they key just start to work or did you have to do the re-programming steps ? (turn to pos 1, hold unlock and press lock 3 times)
Old 07-15-2012, 01:53 PM   #4
Bobby330xi
No programming needed. I just made sure I bought one with the exact same part number as what came out of my car.
My driver's door actuator is bad (doesn't always work) so I don't bother using the central locking system until I have a chance to replace it. I don't want to go through this hassle again anytime soon. The rest of the doors work fine.
Old 07-16-2012, 06:42 PM   #5
cliff101
ok cool thanks
Old 11-22-2012, 01:55 PM   #6
scottjoh
My Ride: '99 323i & '02 540i
I know this thread is a little old, but, I wanted to comment anyway.
There is nothing wrong with the key sync procedure you did. The procedure worked and the key is syncing fine. You are getting the correct lock then unlock confirmation. Just because only the driver's door unlocks does not mean it didn't work. Whether only the driver's door unlocks or all the doors unlock can depend on how the CKM was programmed. For example if key #1 was programmed for only unlock driver's door on first press of the remote then that's what will happen during key sync. If you have other problems with the door locks then that's a completely separate issue from key sync.
scottjoh is offline   Reply With Quote
Old 11-22-2012, 03:47 PM   #7
cityjohn
My Ride: 2001 M3
Maybe it's a TUR-key
cityjohn is offline   Reply With Quote
