Old 07-14-2012, 12:29 PM   #1
graemma1
My Ride: bmw 330ci
bmw 330ci cut out today
A few days ago the battery warning light started to flicker on the dash board, I assumed this is likely to be related to the alternator failing. I started the car today and it stalled which has never happened before but restarted first time. i then went to the local shop and back without any problems. 1 hour later i went out in the car and managed to get 200 metres and the car felt as tho there was no acceleration as if no fuel and cut out and would not restart. So now ive had to leave the car until i get it recovered. I can hear the fuel pump and there is 1/4 of a tank of petrol but it wont fire at all. Whilst on the side of the road i swapped the fuel pump and horn relay but made no difference. Any ideas. Camshaft/crankshaft sensor or the could it still be the fuel pump even tho i can hear it or is there something else it could be.
graemma1 is offline   Reply With Quote
Old 07-15-2012, 02:01 PM   #2
graemma1
My Ride: bmw 330ci
UPDATE, i recovered car today, using a bit easy start into the maf sensor the car fired straight away and ran for around 1 minute then cut out and would not start again. So i removed the fuel pump only to find the tank was empty but i had just put fuel in that same day. i then removed the pump from the other side of tank and found the other side of the tank to be full. For some reason the secondary pump isnt pumping fuel to the other side and when i recovered on back of lorry some fuel must have spilled over onto the other side. Is this likely to just have failed or is there something else that could be causing the problem
