Old 07-14-2012, 02:52 PM   #1
aeorozco
My Ride: 2000 323i
Send a message via Yahoo to aeorozco
Front windshield trim replacement
Hey guys,
I just bought a new front window trim piece and I didn't want to but the removal tool, what other ways can I remove the wiper arms with out messing up my glass?
I tried to search and didn't come up with much, but I know there was a diy out there.
Sent from Droid Charge
2000 323i ........Stock for now
aeorozco is offline   Reply With Quote
Old 07-14-2012, 02:53 PM   #2
PH03NIX46
My Ride: 2003 M3
Pretty sure Delmarco has a DIY on the windshield cowl replacement (which is what I think you mean?).
Just Google "e46 windshield cowl DIY" and I'm sure you'll get something. If that's what you're looking for.
Eibach | Sportline | OEM Euro Headers | TTFS
PH03NIX46 is offline   Reply With Quote
Old 07-14-2012, 02:54 PM   #3
kondzik
My Ride: 330i
Get the removal tool, i paid for mine like $14 and it works awesome, makes the job much easier
kondzik is offline   Reply With Quote
Old 07-14-2012, 02:56 PM   #4
aeorozco
My Ride: 2000 323i
Its pretty much like a pulley puller right, anything special I need to know?
Old 07-14-2012, 02:59 PM   #5
kondzik
My Ride: 330i
yeah, i have this kind http://www.ebay.com/itm/Pro-Wiper-Ar...item19cf3973f9 and it works great
Old 07-14-2012, 07:13 PM   #6
The_Don
My Ride: 2001, 325Ci
I picked up a battery terminal puller at my local auto parts store to do this. Worked great and only cost a few bucks.
- UUC Stg. 1 LTW Flywheel - UUC SSK + DSSR - UUC TM +TME - UUC Rear Adjustable Control Arms - UUC Swaybarbarians - AST Sportline II -
- RE Underdrive Pullys - RE FCABs - BMW Performance Control Arms - Shark Injector - EMP High Flow Water Pump - TMS Adjustable Endlinks - K&N CAI -
- M3 Motor Mounts -
For Sale
The_Don is offline   Reply With Quote
Old 07-14-2012, 10:06 PM   #7
aeorozco
My Ride: 2000 323i
cool I will try that tomorrow, I didn't buy it because I didn't want to wait for shipping
Old 07-14-2012, 10:58 PM   #8
bimminge46
My Ride: 323Ci, 89 325i ETA
Since when did you need a tool to replace your windshield cowl? I replaced mine in about 15 minutes. The wipers are held in by a nut. After the nut is removed wiggle and pull up. Use your HANDS to pull the cowl up. Here is a DIY http://forums.bimmerforums.com/forum....php?t=1334705 oh and you don't need to take the ventilation filter box all the way out, just enough to snap the new cowl in place.
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 07-15-2012, 01:50 AM   #9
The_Don
^The tool isn't to pull up the cowl, it's to help help pull the wiper arms up. My wiper arms wouldn't budge by hand - and believe me I tried- so I picked up the terminal puller. I figured it was cheaper and easier than having to replace a wiper arm if it ended up breaking or bending from pulling on it.
- M3 Motor Mounts -
For Sale
Old 07-15-2012, 06:50 AM   #10
tran330cic
My Ride: Estoril Blue M3 Vert
Thanks for the DIY Link! A must do on my new, old M3 vert.
tran330cic is offline   Reply With Quote
Old 07-15-2012, 01:37 PM   #11
bimminge46
Spay some PB on it. Let is sit for a few hours. Move the wiper arm up and down while wiggling it. Mine was seized up too.
E30 in progress.
Old 07-15-2012, 04:18 PM   #12
tran330cic
aeorozco,
Where did you buy the cowl trim piece? Need to buy one asap.
Old 07-15-2012, 05:16 PM   #13
kondzik
My Ride: 330i
bmw dealership, it's pretty cheap
Old 07-15-2012, 07:14 PM   #14
aeorozco
My Ride: 2000 323i
Tried to pull mine today and the wiper arms are on pretty tight so I might try spraying sone lube on then and let them sit and see if thats Doesn't help.
Im pretty sure I got the cowl from Bav auto, want to say it was like 75 shipped to my door
Old 07-15-2012, 09:48 PM   #15
Crestwood1001
My Ride: 2001 325xi
Took mine off the other day to clean them up and paint them (small rust spots), came off no problem at all.
Crestwood1001 is offline   Reply With Quote
Old 07-15-2012, 10:24 PM   #16
kondzik
My Ride: 330i
OEM at the dealer is around $75 also
Old 08-15-2012, 09:28 PM   #17
gerbs325i
My Ride: 325i 2001
hey guys i am a little new to this and new to owning a bmw, i resently do the cowl swap on my 325, the only problem is a previous owner lost one of the pressure washers that go in the arm. do you know where i can get a new one
gerbs325i is offline   Reply With Quote
Old 08-15-2012, 09:56 PM   #18
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
gerbs...realoem.com for PN...bmaparts for cheap parts...or any number of other places. Bavauto and Pelican will have what you want, but I expect a dealer won't be much more expensive.
I thought we all had squirters from the hood...guess not.
Facebook.com/DMAXstandup
Mangofy your E46!
Old 08-15-2012, 10:01 PM   #19
gerbs325i
My Ride: 325i 2001
i looking for the piece that isw pressed into the arm itself that you need to use the tool to help pull the arm off. for some reason my passenger side is missing that so it does work when using the wipers. its the ppiece right under the nut that holds on the arm
Old 08-16-2012, 07:24 AM   #20
dmax
dmax's Avatar
Oh...'that' pressure washer. Got ya!
Hang on...brb with some help I hope!
#5...get PN...call dealer for part--probably a special order item, but maybe they have it.
http://realoem.com/bmw/showparts.do?...65&hg=61&fg=45
Mangofy your E46!
