Old 07-15-2012, 10:46 AM   #1
Mannydog
My Ride: '02 330Xi 5spd
Strange suspension noise scenario
My apologies if this has been covered, but I haven't come across it after multiple searches.
When I pull up to my house, I make a medium sharp, slow speed right turn onto the concrete pad in front of my driveway. There is a lip that's 1-2" higher than the gravel surface I'm coming off of. When I hit the lip with my right FRONT tire, I hear a clunk from the REAR of the car. I can't tell if it's from any particular side.
I've also heard it pulling off the street into a particular parking lot in town where there is a similar geometry.
I've only tested a couple of times, but I doesn't seem to happen if I do the same thing making a left turn.
I recently replaced broken springs With Supplex HDs from Pelican. Changed the pads also.
Rear shock mounts look OK.
Car is an otherwise stock '02 330xi, 5 speed with around 93k.
I have some front end suspension clunking (most noticable on speed bumps and other low speed bumps) that I haven't had a chance to diagnose yet.
I'm gonna try to do a rear sub frame inspection ASAP.
Any thoughts?
Mannydog is offline   Reply With Quote
Old 07-15-2012, 10:57 AM   #2
///MPR77
My Ride: 02 ///M3 Tri-Ped
Your struts are shot!
Refer to e46mangos write up.
http://forum.e46fanatics.com/showthr...te parts list.
Old 07-15-2012, 11:25 AM   #3
Mannydog
Thanks. What makes you think struts as opposed to all the other possible candidates?
Old 07-15-2012, 11:28 AM   #4
trippmann
My Ride: E30
Send a message via AIM to trippmann
well these are all guesses but are all very possible. front swaybar end links, rear trailing arm bushings (RTAB) "i just changed mine due to a heavy clunk when ever the rear wheels would hit a bump or go over a ledge."
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is offline   Reply With Quote
Old 07-15-2012, 12:38 PM   #5
///MPR77
It might be all of the candidates except rear springs, because that's what you mentioned replacing.
I am on my 3rd e46, and 4th BMW, based on my humble experience.... I would bet your struts, and shocks are bad.
It could be endlinks, which are likely bad too, and will cause clunking in the front.
You will likely need to replace struts, and shocks, mounts links, 4-5 times throughout the 300,000+ mile life of the car.
Normal people will ignore this preventative maintenance, and let it go to a point where it becomes noticeable in the most mild conditions. "Tiny bumps, and seams"similar to what you have described. At this point its safe to say your suspension is in dire need of a refresh....
Once your suspension is shot, things like your control arms bushings, and outer ball joints in the control arm start to see a lot more shock, and impact, which begins to wear, and in the case of ball joints literally tear open like a tin can.
It's the all too often case, of one problem directly creating other problems.
GL
Old 07-15-2012, 01:47 PM   #6
bimminge46
My Ride: 323Ci, 89 325i ETA
push down on the fender/ rear bumper and try to replicate the noise. jack up the rear of the car and inspect the sway bar links, strut, strut mount, rtabs.
E30 in progress.
bimminge46 is offline   Reply With Quote
Old 07-15-2012, 02:02 PM   #7
Pixxy
My Ride: 2001 BMW 330CI
I think a rear sub frame is the biggest concern...once you rule that out everthing else is cake. Worn bushings will cause clunking noises
Pixxy is offline   Reply With Quote
Old 07-15-2012, 02:24 PM   #8
///MPR77
Not too common on 02's though.
Never rule it out though.
