Old 07-15-2012, 12:47 PM   #1
SJP
My Ride: 2004 325ci
Squeak while reversing.
My car sits on a hill, whenever I put it into reverse and then let my foot off brake I get that loud squeak so I'm guessing I need new brake pads. But when I'm down at the bottom on the street ready to drive and I shift it into drive I also get that same squeak. I can feel the squeak while pressing on the brakes also if that helps to clarify. Any clues as to what it is ??
SJP is offline   Reply With Quote
Old 07-15-2012, 02:07 PM   #2
doggy
My Ride: 330ise
you need to service your parking brake
doggy is offline   Reply With Quote
Old 07-15-2012, 02:59 PM   #3
Pixxy
My Ride: 2001 BMW 330CI
A squeak when reversing is most likely the parking brake...squeaks and grinding when you brake during normal driving is probably worn brake pads and/or rotars
Pixxy is offline   Reply With Quote
Old 07-15-2012, 03:10 PM   #4
MercForHire
My Ride: M235i 6MT
When the rotors get wet, they rust a bit. Reversing + braking will make a loud grind noise for the first time.
Old 07-15-2012, 03:13 PM   #5
SJP
My Ride: 2004 325ci
It only chirps when I shift from reverse to drive, not while in the process of reversing if that was what you were saying.
Old 07-15-2012, 03:44 PM   #6
Pixxy
Ok i was thinking it was doing something else...hmmm interesting im not sure what would cause a chirp when you shift from reverse to drive..be curious to see if it sounds familiar to somone else on here
Old 05-04-2014, 12:42 PM   #7
Fivemane
My Ride: 02 330ci
Hold on I have the same problem but it's all the time when I'm reversing even when I am not applying the brakes. Sometimes it doesn't do it when I repetitively and lightly use the brakes
Fivemane is offline   Reply With Quote
Old 05-04-2014, 01:08 PM   #8
SJP
My Ride: 2004 325ci
What fixed my problem was replacing all my rotors and pads. Hope that helped
Old 05-19-2014, 11:51 PM   #9
Fivemane
My Ride: 02 330ci
The other day I noticed my car squeaks while I'm going up to 20mph on SLIGHTLY uneven roads.(still haven't replaced rotors)
