Old 07-15-2012, 03:58 PM   #1
swaggerwagon
My Ride: 2005 330i
Fcab help
I installed new fcabs on my 330i and used soap and pressed them on by hand. Long story short soap dried and I looked and they are not pressed on far enough. Can I just 3 arm pull them and try again or will this do damage they have not been driven on yet
330i ZHP
3 Pedals FTW
BMW level 2 Tech
Ebay headers | Long tube CAI | modbargains ///M pedal covers | SS clutch line | CDV removed | Turner camber arms | Meyle HD FCABs | uuc poly motor/trans mounts | Eurospec Muffler | Clutch masters Stage 2 with aluminum flywheel | Coilover kit | CSL front bumper | Z4m shift lever | VISracing CF hood | Depo HID w/CCFL halo rings
swaggerwagon is offline   Reply With Quote
Old 07-15-2012, 04:37 PM   #2
ryansteel87
My Ride: 2000 328i
How can you tell they're not pushed in enough? If they bolted to the frame, you're fine. The weight of the car and the motion of the suspension will push them the rest of the way in. The soap is only to help us push them onto the control arm because we can't put hundreds of pounds of force on the fcabs like the control arms can.
ryansteel87 is offline   Reply With Quote
Old 07-15-2012, 05:49 PM   #3
doggy
My Ride: 330ise
read here:
http://forum.e46fanatics.com/showthread.php?t=841749
try press them on with something
if you had to hammer the bush make sure you dont hit the wishbone would not be good for ball joints
doggy is offline   Reply With Quote
Old 07-15-2012, 06:11 PM   #4
swaggerwagon
My Ride: 2005 330i
Thank you that thread really helped I was concerned because my meyle hd did not go on as far as the oem( not as much protruding out rear)
330i ZHP
3 Pedals FTW
BMW level 2 Tech
