Old 07-16-2012, 12:46 PM   #1
Hokie11
My Ride: 2004 325ci
Tips for installing o2 sensors?
Planning to replace one of my o2 sensors that gives an error after my exhaust install...
Any tips on getting these on/off?
Shop quoted $250 just for labor, so I am expecting a long afternoon
2004 325ci Steel Blue, UUC TSE3, Gruppe M Intake, ZHP Shift Knob, ECS Strut Bar, H&R Rear Sway, Shadowlined, LEDs Swap
Hokie11 is offline   Reply With Quote
Old 07-16-2012, 01:13 PM   #2
Steven747
My Ride: 05 330ci
stock or aftermarket headers?
Old 07-16-2012, 01:15 PM   #3
Hokie11
My Ride: 2004 325ci
stock
Old 07-16-2012, 01:19 PM   #4
Hokie11
My Ride: 2004 325ci
these are the ones under the car... downstream sensors, not pre-cats. i see plenty of diy vids on youtube on the pre-cat ones, but the ones below were a pain to maneuver around for my exhaust install. i am dreading getting those in and out
Old 07-16-2012, 01:21 PM   #5
SeanC
My Ride: 330i
Post cats should not take more than a couple of hours including driving the car up on ramps, etc.
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Alpine WhiteTanSand High Gloss e46 330i SlickTop/5MT - Sold
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
SeanC is offline   Reply With Quote
Old 07-16-2012, 01:43 PM   #6
Steven747
My Ride: 05 330ci
it would help if you had the 02 sensor tool
Old 07-16-2012, 01:46 PM   #7
Hokie11
My Ride: 2004 325ci
yeah, i definitely plan to get a o2 tool
just came across a diy on this forum as well http://forum.e46fanatics.com/showthread.php?t=293116
pretty much answers most of my questions... worried about how much they seized though.. the bolts that were on my stock exhaust had to get torched off
Old 07-17-2012, 01:01 PM   #8
Guest021715
Account closed.
1) Raise car on ramps
2) Disconnect sensors
3) Soak with PB Blaster for 30 min
4) Use a ratcheting S-wrench to remove by running it through the wire
Simple procedure. The shop you mentioned must be run by extortionists, because this is a 1hr job at home.
