Old 07-19-2012, 07:43 PM   #1
Many330i
My Ride: e90 M3
Brake bleeding without power bleeder
I'm not very happy spending money on a bleeder that I know will use once in a blue moon but my car could really use a bleed. I was wondering if there is a way to accomplish brake and clutch bleeding without the motive tool or something expensive like that. Specifically, is there a manual process that someone can direct me to. This will be a one man job!
Many330i is offline   Reply With Quote
Old 07-19-2012, 07:54 PM   #2
voidopolis
My Ride: 2004 M3 SMG Vert
I'm planning on building this.
http://www.bmw-m.net/TechProc/bleeder.htm
voidopolis is offline   Reply With Quote
Old 07-19-2012, 08:00 PM   #3
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
you need two people to do it without a power bleeder.
Old 07-19-2012, 08:06 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Even with a Motive bleeder, manual bleeding is really the only way to go in my opinion.
Some will say you will over stroke the master cylinder and cause it to fail, if over stroking causes it to fail, it needs to be replaced anyway. If you have a brake hose or caliper fail, your master cylinder will need to over stroke and you do not want to find out your master cylinder is bad at that point.
So a compromise is to get some phone books or scrap wood and put them under the pedals so they do not stroke much further than the normal pedal movement.
You then pump the pedal 3 times, hold the pedal down and have someone open a bleeder screw, let the pedal drop, hold it there until the bleeder is closed and repeat as many times as you want. Just make sure you check the brake fluid level often so you do not drain the master cylinder.
As for the clutch, not sure the E46 is the same as my E39, but to bleed it correctly, you have to remove the clutch slave cylinder, but a clamp on it and turn it so the bleeder screw is at the 12 o'clock position. Again, make sure you keep the master cylinder topped off during bleeding.
I am sure you will get a lot of other opinions, but this is the old school way that works and is still used today, even with Motive type bleeders. The Motive unit and similar are flushing systems and not bleeders in my opinion, not enough pressure!
Old 07-19-2012, 08:19 PM   #5
M6BrokeMe
My Ride: 2001 330 ci, 1988 M6
This will make it even cheaper and simpler ... just like me.
That's pretty good but this will make it simpler and cheaper if you already own a bicycle pump with a pressure gauge on it:
1. Substitute bicycle pump for sprayer.
2. Used a valve stem from a bicycle tube for the valve fitting. Go to the bike repair shop and get an old tube for free. Ask for one with a regular schrader type valve that is threaded on the outside over its complete length They are very common and fit all bike pumps. You must also get a nut for the valve stem. Just cut the tube and take out the whole stem with a little circle of rubber around it. put it through a hole in the cap and secure it by using the valve stem nut to keep it secure. It will be air tight that way.
Enjoy bleeding away!
M6BrokeMe is offline   Reply With Quote
Old 07-19-2012, 10:07 PM   #6
jgold47
My Ride: 2004 X5 3.0
I used a motive. Loved it. Bled great. took no time at all. well worth the 50 bucks or whatever it was.
Religion, Politics, and which oil is the best to use. Three things never to be discussed in polite company...
my about me link
http://forum.e46fanatics.com/showthread.php?t=791566
jgold47 is offline   Reply With Quote
Old 07-19-2012, 10:09 PM   #7
CheddarCheeze
My Ride: 2005 330i ZHP
I used a syringe to pressurize the line while another was pumping the clutch pedal when I replaced my slave cylinder on e36 325is. Worked first try.
Life is better with Cheddar.
CheddarCheeze is offline   Reply With Quote
Old 07-19-2012, 11:08 PM   #8
Brinkley
My Ride: 99 328i, 07 z4 3.0
I agree with JFOJ, manual bleed is still the best option. Get a friend to pump the pedal for you, or even better to do the legwork/getting brake fluid on yourself part of the job while you pump the brake pedal.
Brinkley is offline   Reply With Quote
Old 07-20-2012, 03:37 AM   #9
Vandyinc
My Ride: 2000 323 Cic
Although I haven't used them on my vert, ... I have had satisfactory results using "Speed Bleeders" on other vehicles that i have worked on.
Done:H&R Sport Springs Koni STR Shocks & Struts, Lower Control arms, FCABs, OFHG, CCV, Cooling Sytem refresh, Coolantsnitch. Yet to do:Transmission fluid & filter, VCG
Vandyinc is offline   Reply With Quote
Old 07-24-2013, 09:32 AM   #10
Hogan773
My Ride: 2002 325xi
Why is manual the best option? I'm thinking of building a DIY Motive clone and it seems many people have good luck with them. I can see that as long as one makes sure to use the block of wood or phone books, the manual way should work fine, but I'm wondering why it is BETTER than using a pressure bleeder. I mean if I take it to the shop are they really gonna have two guys on it with one pumping the pedal and the other opening and closing the bleeder screw over and over?
I'm just trying to figure out today what is the best and easiest place to get a dummy reservoir cap that will screw on tight. Some of the posts are older and refer to an ATE Master Cylinder Cap or some aftermarket clone that fits GMs, but then other posts said they no longer sell it. If anyone has done the DIY Motive Clone using a sprayer bottle recently and they have a good tip for which store sells the cap, let me know. I live in the burbs so I have everything - AutoZone, OReilly, Advance, Napa, Carquest, WalMart. I'd prefer not to order it sight unseen from Ebay or something if possible. Would also prefer not to go to a junkyard and go hunting around for old BMWs and Volvos to get my $5 cap.
Hogan773 is offline   Reply With Quote
Old 07-24-2013, 09:40 AM   #11
Custom3
My Ride: HellRot 330CI
Harbor Freight sells a cheap bleeder pump that connects to the bleeder if you dont want to waste money on a fancy bleeder....bleeder bleeder
Old 07-24-2013, 10:11 AM   #12
WDE46
My Ride: '13 128i, '04 330Ci
The bleeder is worth it IMO. I did a fluid flush in 30 minutes with it easily by myself. I broke all the lugs free, then removed the wheels one by one and bled the brakes. Go Rear Right, Rear Left, Front Right, Front Left, done.
Since you asked for a manual process, JFOJ's process is the standard one. That is how it's always been done since the beginning of hydraulic brakes.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 07-24-2013, 10:19 AM   #13
Hogan773
My Ride: 2002 325xi
Not sure I can envision that but I'll look. The DIY I was looking at is only gonna be 15 or 20 bucks I think, using a 1 gallon plastic sprayer which is coincidentally all that the "fancy" Motive uses for more $$$.
I still am curious (posted also in the DIY forum) as to why several people have said that the manual method is "better" or gives a "firmer pedal". Doesn't make sense to me. There is fluid in all the lines at the start, you change the fluid and so there is also fluid in all the lines at the end. It's not as if the system now has MORE fluid or something that would give it a HIGHER PRESSURE so I can't see why the pedal would now be "firmer" by using the manual method than if you did it with a Motive-type pressure bleeder.
Thoughts? I'm assuming it is normal urban legend/placebo/lack of ability to actually compare one vs the other at the same time on the same vehicle as I can't see the technical reason why this would be a possibility.
Old 07-24-2013, 10:38 AM   #14
WDE46
I think it's the fact that you're actively moving the pedal so any air in that piston and the master cylinder will be more effectively removed.
Old 07-24-2013, 10:58 AM   #15
white46
My Ride: e46 323ci
one man = power bleeder or some kind of home made bleeding tool
two man = old fashion way. one person pumping pedal, other person bleeding.
Since you've asked this will be a one man job, there is no way around it other than using power bleeder.
Also, when I tried bleeding clutch by pumping clutch pedal method, it didn't quite work. Fluid drained out, but new brake fluid didn't suck in, therefore clutch pressure was gone.
I had to do reverse bleeding to get the pressure back.
Next time, I'm getting power bleeder for sake of easiness.
white46 is offline   Reply With Quote
Old 07-24-2013, 12:14 PM   #16
Hogan773
My Ride: 2002 325xi
Aha - that could make sense (I knew someone smarter than I might be hanging around)
That said, I'd think you could also just lightly pump the pedal a couple times while doing a flush to dislodge the air in there, if any. I realize that could be a little more challenging in a one man operation. I envision 1) making sure your reservoir is full 2) make sure bleeder is pressurized 3) open bleeder screw so fluid is flowing 4) run over to brake pedal and give it a few light pushes.
Who knows - we're probably obsessing about a couple small bubbles of air here. I don't think my car has been flushed in at least 5 or 6 years so any method will probably yield some positive benefits.
Old 07-24-2013, 12:21 PM   #17
bee-em-dougle-u
My Ride: 2002 BMW 325i
I second the Speed Bleeder recommendation. They're $7 apiece, simple bleeder nipples with a built-in check valve that replace the calipers' original nipples. Loose a quarter turn, pump the pedal until there's no bubbles, tighten. Done and done.
They're great...I've had them on the last five cars I've owned. You'll never need to find a helper to bleed the brakes again.
bee-em-dougle-u is offline   Reply With Quote
Old 07-24-2013, 12:53 PM   #18
Hogan773
My Ride: 2002 325xi
You still have to do the "block of wood under the pedal" to ensure you don't overstroke the master cylinder I assume.
If you really want to be cheap can you take them off the car when you sell it and put back on the original bleed screws I'd think?
Old 07-24-2013, 02:36 PM   #19
Sedan Hussein
My Ride: e46
http://www.turnermotorsport.com/p-17...ple-bleed.aspx
Sedan Hussein is offline   Reply With Quote
Old 07-24-2013, 06:39 PM   #20
sunsetcoast
My Ride: '99 323i & '00 323iT
^ x3. Have used them for about 15 years now on a number of vehicles. Just $7 a corner makes for a clean, one-person job...although you're still running back and forth to know when the fluid is coming out clean. They now sell a hose/bleeder bag combo that removes the mess element entirely.
sunsetcoast is offline   Reply With Quote
