Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
Rating:
Display Modes |
#81 | |
![]() sold&missed S54 Block & Crank in hand ::evilface:: Teddy Eurotechniks |
#82 |
For those running 17s in rear I've been informed to try a 11.5 wheel for 315/35/17 and it should alleviate most of the cornering issues
#83 | |
I dont see that you are FI. Stay with the Star Specs. I am loving my set now on my other car as much if not better than the RE-11's. The Dunlops are great street tires, perfectly suited for any HPDE as well. Track compound tires can be scary. I have not spun out on my track only BFG R-1's (yet). They barely make a sound when they are stressed. You have to really concentrate hard and pay attention to the smallest things when you are pressing competition compounds to their limits. They give almost no warning when they are going to loose grip. Use R compound in the street only if it's absolutely necessary.
#84 | |
2001 M3 - Phoenix Yellow - 03/01 production
#85 |
When was the last time you drove your car Bdave?
#86 |
LoL
#87 |
#88 |
Cant wait til he can drive it. So he wont have as much time on forum to write huge post. Instead he'll be out driving
Sent from my PG86100 using Bimmer App
#89 |
Bumping this thread back to life.
I'm currently in the market for 18s.. Most likely Apex Arc-8. I'll be going with 18x9.5 et35 up front. My question for you tire/wheel gurus is what size in the rear? 18x10 et25 or 18x10.5 et27? I plan on running 255/35/18 and 285/35/18 front and back respectively. Or 265/295 depending on my tire choice and what's available. I would like to run Nitto NT05 but 255 is not available. So I would be left to run 265/285. Anyways, what are your guys recommendations for the rears? My fenders are cut and sealed so I will not have to do any fender mods. Should I go with 10.5" just in case I decide to go with 295 in the future? I know m5chas ran 295 with a 10" wheel. Feel free to chime in
![]() 2006 BMW lllM3 SilverGrayMetallic/Cinnamon/OEM 19" llHPF Stage 2 w/6766 and Open Dump Last edited by nnacpil; 12-14-2012 at 03:19 AM. |
#90 |
You and I are pretty much in the same boat in terms of finalizing what tire size to run on 18 inch wheels. I also ended up with the same debate of 255/285 or 265/295 and after seeing 295's on a M3 it pretty much sealed the deal on which rear tire size to go with especially with Boost! I'm currently running an 18x11" wheel and awaiting my tires so I'll definitely have some feed back soon on that tire size.
#91 | |
Edit: nvm found your post above with your wheel specs
![]() 2006 BMW lllM3 SilverGrayMetallic/Cinnamon/OEM 19" llHPF Stage 2 w/6766 and Open Dump Last edited by nnacpil; 12-14-2012 at 11:00 AM. |
#92 |
This has alot of good info...http://www.m3forum.net/m3forum/showthread.php?t=428513
I'm still undecided atm what I'm going to get but most likely ARC8's 18x9.5et35 up front and a 18x10.5et27 rear with NT05 265/35/18front and 285/35/18 rear ...295's have my interest.
#93 | |
It's funny the 285 is cheaper than the 265 on nt05 from Discount Tire Direct
![]() 2006 BMW lllM3 SilverGrayMetallic/Cinnamon/OEM 19" llHPF Stage 2 w/6766 and Open Dump |
#94 |
Honestly I'm not sure of my offset i bought my wheels a while ago and been through a few sets but never gave these up. I'm getting them refinished so once I get them back I'll report back my offset. As a side note onlinetires.com has the nt05's cheaper than discounttire
#95 | |
#96 | |
i wonder if anyone here tried nt05r in rear yet |
#97 |
Got me confused with someone else...I have been limited with my 380mm brembos...won't fit on the 18" APEX ARC8's and I dislike the EC-7's. So sooner or later I'm going to be getting new 355mm brakes and ARC8's.
#98 | |
rear rotors 355 mm / 18 " wheels I dont think a 11" will fit under e46 M3.
8 seconds 1/4 mile & sub 3 seconds 60-130 mph AWD M3X coming soon
4,23 s 60-130 mph E46 M3 TT 4,49 s 60-130 mph E36 M3 TT, 3,49 s coming soon RWD mode 8,45 s 60-130 mph 997 Turbo |
#99 |
#100 |
Cw, I'll be getting rid of my oems once I get arcs. Do you need tires for the mean time before you go 18s? NT05s. In your specs
![]() 2006 BMW lllM3 SilverGrayMetallic/Cinnamon/OEM 19" llHPF Stage 2 w/6766 and Open Dump Last edited by nnacpil; 12-16-2012 at 11:27 AM. |
