Closed Thread
Old 07-20-2012, 04:15 PM   #1
HPF Chris
Past Site Sponsor
My Ride: 2002 M3, 2006 530i
Thumbs Up Sal's LSB M3 Comes in for HPF Stage 2!!!
Sal's LSB M3 Will be morphing into an HPF 600rwhp Beast in the next couple weeks. He's getting our HPF Stage 2 Installed with the new 6766 Turbo. He's also getting the subframe reinforcement done while it's in here (very smart move) and our Stage 2 Clutch. For improvements to handling and stability he's getting the Powerflex Bushings and the HPF Front Under Brace....
We will have dyno results on his car coming soon.
HPF Chris is offline
Old 07-20-2012, 04:19 PM   #2
Commanderwiggin
My Ride: 900rwhp Turbo M3
Nice! IMO skip on the yellow powerflex bushings and get AKG subframe bushings...there are several threads digging into this. I have the Yellow Powerflex bushings...I will be changing to AKG
900+RWHP, PT6870 w/ Custom FSR Turbo Kit, AEM Infinity, Lab22 Motor
Commanderwiggin is offline
Old 07-20-2012, 04:27 PM   #3
Forcefed M3
My Ride: HPF Stage 2.75
you should have raced the guy in the scooter!
Forcefed M3 is offline
Old 07-20-2012, 11:21 PM   #4
BDUB328I
My Ride: bmw 328i S54 sedan (
interesting, i just installed the yellow busings on my diff carrier.... maybe ill switch to the akg before i install the carrier in my car and have to do it all over again.
BDUB328I is offline
Old 07-21-2012, 02:11 AM   #5
Bdave
My Ride: M3 HPF Stage 3
My shop now recommends AKG over Powerflex for applications like subframe RTABS abd FCABS. I see many other cars now running the AKG line. Red or Black durometer. My subframe are the Blacks and my RTABS are Red.
Bdave is offline
Old 07-21-2012, 04:33 AM   #6
E85head
My Ride: E46 M3
I swapped to akg 75d (red) bushings for the diff, subframe and rtabs, dont regret one second. Tiny bit of drivetrain noise, but that actually just puts a smile on my face and is only noticeable with the stereo turned of. A few cliks and clunks when drivetrain slack is absorbed, but from what i understand, all m3s does this more or less..
I went with the akg's because i know of a few that has had fitment issues with powerflexbushings leaving a tiny bit of free space between the bushings and underside of the car where the subframe sits..
E85head is offline
Old 07-21-2012, 10:20 AM   #7
MaverickM3
My Ride: gets badge
Ihave the black powerflex. Never had a problem. I think it was only the yellow ones that were bad.
MaverickM3 is offline
Old 07-21-2012, 10:27 AM   #8
Commanderwiggin
I don't necessarily have a BIG problem...there is a small gap between the bushing and the body where the bushing is supposed to be in contact with...about 1mm gap last time I looked. Not good.
Old 07-21-2012, 10:46 AM   #9
330Cole
My Ride: 01' 330Ci
what kinda lip spoiler is that?
330Cole is offline
Old 07-21-2012, 05:19 PM   #10
MarcusLSB
My Ride: X5, CT200h, CLK63 BS
LSB Vert.. Kinda wish I had a vert with a 6466.. that would be a fun daily driver.
MarcusLSB is offline
Old 07-21-2012, 06:32 PM   #11
Dreikraft
My Ride: slow m3
Looks like a hamman
Dreikraft is offline
Old 07-22-2012, 07:08 AM   #12
Bdave
Yep. I started a thread last year called" Ripped a Sub Frame bush...a POLY one!!! "
http://forum.e46fanatics.com/showthr...635&highlight=
Some members brought to light the reason why...Ill fitting (all of them)Powerflex Yellow sub frame bushings.
It's an interesting thread with several good close up photos.
I tore a yellow Poweflex Subframe bushing with 435rwhp. It may have even happened while I was NA at only 300rwhp.
The bushing did NOT last very long.
Bdave is offline
Old 07-22-2012, 07:12 AM   #13
Bdave
Perfect!
Any progress on your all out drag car?
Bdave is offline
Old 07-22-2012, 08:02 AM   #14
Maditalian232531
My Ride: 02 LSB vert M3
its a hamann lip, i need to repaint it. Thanx Marcus, congrats on your 10 second M3, thats prob fun to drive as well!!
Maditalian232531 is offline
Old 07-22-2012, 03:50 PM   #15
MarcusLSB
Originally Posted by Bdave View Post
Perfect!
Yes and no.. been insanely busy with some stuff and hope to get back on the wagon with that build very soon.
Thanks! It is when I'm not breaking things!
Old 07-24-2012, 07:54 PM   #16
HPF Chris
Past Site Sponsor
All washed and ready for the transplant.
Old 08-15-2012, 02:44 PM   #17
HPF Erik
Past Site Sponsor
So here's a little update on Sal's stage 2.
Sal's car came in with some issues that we had to take care of before we got into turbo charging his engine. we found that his car was making low compression on a few cylinders due to a blown head gasket.
so the head had to come off.
We sent the head out to the guys at M&B to get cleaned up and decked. we then cleaned up and straight edged the block to make sure we would get a good seal on the new gasket. i tried to get a few pics of the cleaned up head but by the time i found out it was here Chris K had it back on already. good news is that Sal is getting a new OEM head gasket and our L19 headstuds to make sure this doesn't happen again anytime soon.
after that Chris K put in his Stage 2 clutch and got to work on his subframe reinforcement
subframe out and bushings installed.
Chris K welding the plates in. ooooooooh fancy action shot!
some of the finished product. this will get a layer of undercoating put over it before the subframe goes back on so that it doesn't rust.
while we had the subframe out we noticed that Sal's differential mount bushings were toast.
so hes going to be getting a set of solid aluminum diff mounts so that this will never happen again. yay for upgrades!!! .
thats about all we have for now on this car. heads back on except for the vanos unit (which is at doc vanos being repaired). as soon as we get that back we will be putting his turbo kit on the car. Sal has also opted into the HPF Ti exhaust instead of his current setup.
more to come!!!
HPF Erik is offline
Old 08-15-2012, 03:07 PM   #18
Bdave
more to come!!!
Why not poly bushings? I have heard reports of pretty bad NVH with the solids. Are the AGK poly bushings not very strong?
Bdave is offline
Old 08-15-2012, 03:24 PM   #19
7to3_enthusiast
My Ride: '02 AW 6spd M3
nice. subscribed. Chris, do you recommend the ARP stud kits for all stage 1 and 2 kits? That's the only issue I've seen with those kits are the heads lifting.
94 VR R2 Rx7 SOLD
02 AW M3 The daily / looking for FI
14 CW 1.8T Beetle - Wife's dream car
02 4.6is X5 - The Work Horse
04 LSB M3 SOLD
7to3_enthusiast is offline
Old 08-15-2012, 03:29 PM   #20
02black330ci
My Ride: spaceship
I stand corrected......
http://forum.e46fanatics.com/showpos...6&postcount=15
02black330ci is offline
Closed Thread
