Old 07-20-2012, 07:18 PM   #1
xecure
My Ride: 2002 325xi, 5MT Swap
Any one ever clean the boot of their ignition coil?
Just ordered a set of slightly used ignition coils for my car. Was wondering if I should clean it before installing it. Any particular solution/fluid I should use?
** Too much for a sig - tim330i **
OMG LOOK AN E46!
xecure is offline   Reply With Quote
Old 07-20-2012, 07:24 PM   #2
NOVAbimmer
My Ride: E60M
I would get a new set of boots. They're pretty cheap
NOVAbimmer is offline   Reply With Quote
Old 07-20-2012, 10:31 PM   #3
xecure
I was scared someone was going to suggest this. Actually I was only planning on running on these coils till the end of the year. I'm at 93k miles now, and I have a new set of ignition coils on my 100k to do list. I actually bought these 6 coils from a wrecked 325i for $50 bucks.
OMG LOOK AN E46!
Old 07-21-2012, 01:36 AM   #4
Pixxy
My Ride: 2001 BMW 330CI
Unless it looked dirty inside the boot especially on the metal connector i wouldnt worry about it. What as wrong with your original coils/boots?
Pixxy is offline   Reply With Quote
Old 07-21-2012, 02:59 AM   #5
xecure
Cylinder 1,2 and 3 were misfiring. When I changed the coils around 2 of the misfires moved with it. I'm assuming the coils wen't bad.
OMG LOOK AN E46!
Old 07-21-2012, 06:15 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I would just buy new ones. Over time the tips crack and break off.
Old 07-21-2012, 10:18 PM   #7
xecure
That's the plan. But I'm planning on making a huge purchase from my supplier in a few months for my 100k maintenance so I haven't purchase new coils yet. Saving that for my large purchase for some extra discounts.
OMG LOOK AN E46!
Old 08-18-2012, 04:15 PM   #8
Steve855
My Ride: 325xiT
Can you buy just the rubber boot for the Bosch coils? I have one that's torn and I don't want to replace the whole coil if it's not necessary. If someone has a link to them, please post up.
Thanks,
Steve
DIY or walking since 1986
Steve855 is offline   Reply With Quote
Old 08-18-2012, 06:14 PM   #9
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
Buy new ones! I had misfiring at around 70k miles and it was the because of the boot. Just because they look like new doesn't mean they're not going to fail. Mine looked great, but, there was a tiny arc trail that went up the plug, under the boot to the high voltage side. The boot was suppose to prevent that!
scottjoh is offline   Reply With Quote
