///M3 Forum
Old 09-30-2012, 03:54 AM   #21
Beamer Creamer
My Ride: 2005 bmw m3
Looks like your car should pull to the right? I doubt it was from wheel torquing. I believe rotors are thicker on better brakes not just bigger diameter. Also doesnt make sense rotor grooved the way it is. I wouldnt leave it as is even after retorque. And just clean wheel studs( no anti seize. Might not hold proper? ) pull your caliper off and change rotor. Take a look at real issue. Even if rotor somehow got overtightened that severely it wouldnt drag the pad evenly on whole rotor causing ridges like those. Minimum i would make sure slide pins on caliper move freely. Is rotor worn like that only on the outside? Or both sides?
Beamer Creamer is offline   Reply With Quote
Old 09-30-2012, 03:49 PM   #22
Westrace
My Ride: 06 G35, 04 M3 Coupe
Hm... that's interesting though I don't know how that's related to rotor uneven wear, but my car does pull a bit to the right most apparent on the freeway. I thought it's has to do with the old shocks and springs on the left side being weaker due to high mileage . I plan to replace them very soon. I have a G35 and it also pulls to the right slightly.
Will find out soon once I remove the wheels to replace the struts.
Westrace is offline   Reply With Quote
Old 09-30-2012, 09:30 PM   #23
Beamer Creamer
I just figured would pull to right bcuz brakes would be grabbing more when roughed like your right side is. Wheel alignement could be a seperate issue but checkout your brake calipers first. Replace rotor and pads.if still pulls too much, check alignment. U prob know all new alignments are set to slightly pull to the right so when u fall asleep you hit ditch instead of school bus. Lol
